Question about McCulloch Garden
What does H and L mean on a chainsaw - McCulloch Garden
I need to find a oil tank for mcculloch pro mac 3505 av16
Do you mean a replacement oil tank for your chainsaw? The following link shows a parts breakdown for your chainsaw. http://s30387.gridserver.com/partsDiagrams/McCulloch%20Late%20models.pdf
Verify that part #14 is your tank (MC-300260). I will tell you this...it is a hard part to find. You may be able to get one here.
https://store.chainsawr.com/collections/mcculloch/products/mcculloch-mac-32cc-to-38cc-chainsaw-oil-tank
Nov 09, 2017 | McCulloch Garden
Will a Poulan 16 " chainsaw gear fit a poulan 18 " chainsaw?
If you mean the drive gear on the end of the shaft, the answer should be yes. The radius for the drive gear does not change as the bar and chain length increase (within a few inches of bar and chain length). The determining factor for a larger bar and chain, in any chainsaw model, is the hp of the engine.
Oct 23, 2015 | Poulan Garden
How to change the filter
I'm assuming you mean air filter? If so, here is a video on how to change the air filter on a Husqvarna chainsaw, and a Redmax chainsaw, all of them are pretty similar so hopefully this will help you out!
Replacing the Air Filter on Husqvarna Chainsaw
Replacing the Air Filter on RedMax Chainsaw
Jul 08, 2015 | Garden
What do all the numbers mean on the chainsaw sharpener kits?
Not all chainsaws are the same size, the numbers that you see on the kits are the size of the blades on the saw. You have to make sure that the sharpener you get is the right size for your saw.
Sep 17, 2013 | Garden
How do I tension the chain on a macallister chainsaw
David, did you mean McCulloch Chainsaw?
Sep 23, 2012 | Garden
Once chainsaw has been cranked what would cause it to cut off when you push in the choke
IF PUSHING IN THE CHOKE MEANS SHUTTING THE CHAOKE OFF THEN IT WOULD MEAN THAT YOUR CARBURATOR JETS ARE PROBABLY PLUGGED OR IF YOU HAVE A HUSQVARNA YOU MAY HAVE ROTTED CRACKED RUBBER FUEL LINE.
Dec 05, 2010 | Garden
When Checking resistance in a circuit open means electricity will flow or wont flow.and does closed mean electricity will not flow or does closed meanthere is alot of resistance
Think of a circuit as a circle. When the circle is closed, the electricity can make the complete way around. When it is open, the electricity is stopped. So an open circuit is not complete and the electricity will not flow, while a closed circuit will allow the electricity to come "full circle".
May 14, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Carb assembling question
Thanks Jerry.
The only that came to my mind is to try here:
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I did a quick search and saw nothing for a 61 carb but it does not mean it is not there. Someone at Arborists has rebuilt your carb. The hard part will be digging them out then dredging up the right memories. Good Luck. HTH Lou
Mar 05, 2010 | Husqvarna Chainsaw Piston Kit for 61...
I can unlock the brake from my 14" homelite chainsaw
Clarification Request
Posted by dontbother10 on Sep 05, 2009
Make? Model? What is the problem after you reset the brake? Lou
Posted by Kioat on Aug 19, 2009
What dor you mean unlock the brake? when you push the brake release forward?
Posted by youdoit on Aug 10, 2009
what is your problem? you are supposed to be able to unlock it if you can tell me what is up i may be able to help
Posted by obwhon on Jun 03, 2009
I'm glad you can unlock brake. It's pretty tiring pushing saw back and forth with brake locked.
Posted by obwhon on Jun 02, 2009
Do you mean you can't unlock the brake?
You must help us help you
Feb 27, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Chain come off chainsaw
i hate to say it but that usually means that the inside gear of the clutch is wourpt were the chain sits, if your still paying for it i would bring it back to where you bought it and get a new one.
Jan 05, 2009 | Garden
Garden Logo
204 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
