Question about HP w1907 LCD Monitor
Black screen my monitor keeps going black?
  • 94 Answers
Check the connectors. They may be loose else your power cable is giving trouble.
Try connection another device to the socket you are using and check if that is the problem.
Mark this problem as solved if you manage.
Posted on Aug 01, 2010
My acer flat screen monitor thats brand new keeps going black on me
It sounds like the inverter is on the way out and hence the black screen. It needs that unit replaced. However if it was mine and new I would insist on a replacement monitor.
Jan 19, 2011 | Acer AL1715 17" LCD Monitor
The monitor keep going to black when its still on.
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but black screen, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 10, 2010 | Dell E228WFP LCD Monitor
Screen on laptop keeps going black
please explain further. keeps going black from where? after turning on the laptop? of after windows logo? if after windows logo screen turns black if a no boot issue where laptop cannot load system files. if screen is black after turning on no manufacturer logo and windows logo or anything then it might be the LCD or video card / motherboard. to isolate try connecting your laptop to an external monitor and check if you will be getting the same problem. if no display from the external monitor then its a video card issue, if video card is integrated needs to replace motherboard.
Oct 01, 2009 | Computers & Internet
Monitor keep going to black screen while viewing.
Disable the Screen Saver in the Display Properties from Control Panel of your Computer.
A Black ScreenSaver is active in your Display Settings. Change it to "NONE" and your problem will be solved.
Apr 22, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Check video cable keeps reading and go off, but the power is still on
the screen on most monitors will go black if the cable connecting them to a device is lose or disconnected altogether. try the cables in the back the ones other then power cable
Apr 15, 2009 | Neovo F 415 (Black) 15" LCD Monitor
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
bad capacitors you will need to replace the "blown caps" and resolder new ones in.
Feb 01, 2009 | Star Logic 17" LCD Monitor
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP w1907 LCD Monitor Logo
232 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
