Question about Dryers
Whirlpool Frontload Gas Dryer
Intermintent Dryer Ignition Failure--Removed Front Panel, Clean With Air Hose--Burner Started & Ran--Next Time Ignitor Glows, No Burner--When Ignitor Glow, Sounds Like A Washer Is Rattling In R.R. Corner--Didn't Rattle When Dryer Has Burner, Only Rattles When Failure--Don't Know Which Part Is The Problem--PLEASE ADVISE
    Genius:
  • 1,028 Answers
Suggest change both soleinoid coils can sometimes cna be very intermittant
Posted on Apr 27, 2008
Whirlpool clean touch dryer is not heating up. The drum turns, the filter is clean and there is suction at the filter. the dryer is running cold on all temp settings and dryer settings. The gas line has...
If you are handy you can do it yourself. There should be an ignitor near the burner. It gets red hot when you turn on the dryer. There is a bi-metal switch "looking" at the ignitor, which will cut off the ignition and at the same time energize the gas valve(s). If this is not happening, either there is no power going to the burner assembly, or the ignitor is broke (split).
May 08, 2011 | Dryers
Dryer wont stay hot
Assuming you have removed the lower access panel (two or three scres all the way at the bottom of the lower front panel) to view the glow plug (ignitor), if you see the ignitor cycle on but the gas does not ignite after the machine initially heated in the beginning of the cycle you will want to replace your gas valve coils. They are the round black things mounted to the top of your gas valve.
This should solve your problem.
Good luck to you!!
Jul 13, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Model SGDS800JQ2 gas dryer getting no heat
Check to make sure the burner ignitor is not burned out. Check all the other parts you mentioned........ pull one wire off each part(one at a time) and check with with with an OHM meter.... should all be in the closed position.
Mar 16, 2010 | Whirlpool Dryers
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Dryer blowing cold air
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the ignitor attached to the burner. You can try and replace the ignitor without removing the burner. Sometimes it is just as easy to remove the burner. Make sure the gas is shut off before removing the gas fitting on the gas valve. Be carefull and DO NOT touch the black part of the ignitor with your hand. It could ruin the ignitor with the oil on you hand.
If I can assist you further, please let me know.
Thanks
Vic
Jul 05, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer runs ,heats up flame goes off after 30 secs won't relight
Seems to be a problem with the bas valves....you shouldve seen them in front of ignitor...will show similar signs of ignitor. part#306106 AND 306105. come off easily with a few screws and just slide over valve assembly.
Jun 08, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
Dec 15, 2008 | Whirlpool LGR7646E Dryer
MY DRYER BLOWS COLD AIR
Check your exhaust vent first to make sure it isn't clogged. Remove the vent at the dryer and run it for a moment to see if the air out is warm. If it's not, you've got to pull off the access panel to access the back of the unit. There should be a thermal fuse/cutout right near the burner tube. Ohm it out, replace if open. Next, you will have to try to run it without the back on to see if the ignitor is glowing hot. Also, check the gas valve for voltage when the unit is running (carefully) and see if the valve is getting voltage. If it is, replace it.
Oct 28, 2008 | Whirlpool LER4634J Electric Dryer
Gas dryer
hi
In a gas dryer, heat is provided by a gas heater that is controlled by an air shutter. The gas heater is generally the source of no-heat or drying problems. You can often correct such problems by adjusting the air shutter on the gas burner, which is located along the bottom of the dryer.
To adjust the shutter, take out the screws and remove the panel that covers the gas flame. Turn on the dryer so the flame is burning. If the flame has a deep blue color and you hear air whistling around the burner, the air/gas mixture is receiving too much air. If the flame has a yellow tip, the mixture is not receiving enough air. Turn the thumbscrew or loosen the two screws slightly to increase or decrease the flow of air to the burner. Keep turning until the flame is a light blue color, without any yellow, and the whistling stops.
Gas dryers use an electric ignition device rather than a pilot light to light the gas heater: An element becomes hot and glows like the filament in a lightbulb. Electric ignition systems are always sealed; you can't adjust or repair them. If an electric ignition device fails, call a professional service person for replacement.
In a gas dryer, heat is provided by a gas heater, controlled by an air shutter.
Electric dryers have self-contained electric heating elements.
Sep 14, 2008 | Dryers
Gas dryer
be sure burner is firing off every time it is supposed to if ignitor glows then shuts off without burner firing replace the coils on burner (2 black round things) if burner ok remove rear vent hose and try load without connected if works ok suspect flattened hose behind dryer or line to outside restricted
Jul 16, 2008 | Whirlpool LGR5636PQ Gas Dryer
Dryers Logo
224 people viewed this question
Top Dryers Experts
