Question about Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black
My Scotsman is making ice but the level at which the bin retains ice is getting to be less and less. The drain is clear and the hose is connected. thoughts? TK
    Problem Solver:
  • 7 Answers
Clean condensor and evaporator. Check spray nozzles clear. If you can lower the room temp and it produces better then likely a dirty machine, low on charge or weak compressor.
Posted on Aug 23, 2010
Dce33a1bb ice maker makes ice but doesn't stay frozen
Poor draining of water in the ice bin will cause a high rate of ice melting, Remember this is not a freezer but an ice maker. If the machine is making ice OK but it is melting to fast then check to make sure the bin is draining all the melt off and not letting water stand in bin causing ice to melt fast.
Sep 05, 2014 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman ice machine
Check the water inlet valve water seeping through valve should be running over into bin. Replace or rebuild valve. the machine should have slowed down on production of ice also.
Jul 17, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman cme 1656 bill full stay on after cleaning
Ok did you damage the bin thermostat cap tube? The bin thermostat is what tells the unit the bin is full if so replace it.
Nov 14, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman model 806 ice machine bin full ight is on and no ice in bin,replaced bin sensor a month ago i cant think of anything else it could be replaced the board last month to and the water inlet valve...
Is there anything hanging down in the beam of the sensors? check sensor connections at the controller make sure there is no moister in it and are making good connections. is your water real hard a lot of minerals dirtying up the eyes. if all of this is clear and sensors are good then nothing else but the control board.
Oct 02, 2012 | Scotsman Ice Machine, Cuber, 1930 lb....
My cme 256a8 model scotsman ice melts to fast will not fill my 250 lb. bin in four days. What is the problem? in a hour run time it makes 7 lbs of ice and 4 lbs. water. in one dump cycle it makes 3 lbs...
There are a couple of things to check. The machine must be level. You can remove the front cover and the plastic sheet that covers the plate where the ice is made. Check to see that the water is flowing from the manifold at the top of the plate. You may have to pop the hose off the end of that manifold to clean the water holes out. It must flow evenly over the plate. Probably the most common problem is the radiator coil there the fan draws air through is clogged up so that it can't dissapate heat properly. You should be able to feel a lot of hot air moving through the coils. The fan cycles on and off periodically to maintain a certain pressure in the freon. That is normal. Clean the fan coils and level the machine.
Sep 16, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman DCE33A-1WB Residential Ice Machine Problem
Making good ice. Could be cube size control. Could be a weak compressor. Also these machines are household and meant to run in air conditioned space.
Aug 02, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Jun 28, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black Logo
373 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
John Tripp
John Tripp
Tim Whalen
Beto Flores
Beto Flores
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
