Question about Whirlpool Refrigerators
My ice maker is frosting up. Why is this and what can I do?
    President:
  • 1,099 Answers
There can be a number of reasons from an unlevel icemaker (I like to adjust to lean a little towards the wall or backside) to high water pressure, bad fill tube, or low water pressure (low fill).
The most common is making hollow cubes that break open and the water freezes up the rest of the cubes in the bin. In that case you will have lots of shards or hollow cubes.
This is caused most often by a low fill but can be because of a bad icemaker thermostat.
The thermostat is located in the front end and most icemakers fill starting in the rear. If it is not filling all the way to the front where the thermostat is located it cycles before the cubes are fully frozen putting water in the bin that settles in the bottom.
That is most often due to a tap valve or icemaker outlet faucet that is getting plugged up.
Turn it off and after the cubes are frozen check to make sure it is filling all the way to the head end where the motor is located. You should have ice in all the sections.
But if otherwise,
Usually when that happens it means you have an air leak in your ice door flapper, get a flashlight and shine it down in the ice maker chute, if you see light on the other light, you will need a new ice dispenser door.
Hope this helpout.....
Posted on Aug 01, 2010
Ice maker ice jam
Not a whole lot you can do but to keep the frost down.
If you are able to move the items in the freezer to another freezer and let it sit overnight, all your problems will melt away....
Until a couple months later when it builds up
Make sure to double check your freezer is sealing correctly, bad gasket causes moisture to be sucked in.
Here are some basic ways to slow the buildup
How to Avoid Freezer Frost
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Feb 10, 2016 | Samsung Refrigerators
Our ice machine is making too much ice. When we open the door, ice spills out - so for some reason, whatever triggers the machine to know that it has enough ice made, seems to be malfunctioning. Any...
When frost builds up on the little flapper at the top of the door above the ice maker it can get stuck. It tells the ice maker to keep making ice. Try cleaning the mechanism of frost and make sure it operates freely.
Oct 17, 2013 | Electrolux Stainless Steel Under-counter...
Frigidaire ice maker always crushes the ice
Solenoid that switches blades from crushed to cubes is most likely not working and should be replaced
Sep 05, 2017 | Refrigerators
Ice maker works, fills door but doesn't come out
You have a bad dispensor flap solenoid . Frost due to flap not closing completely and ice will catch in the shoot .
Jul 25, 2009 | Whirlpool GS6SHAXLS Side by Side...
The ice dispensor is frosting over. Ice maker
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Jul 14, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker dispenser and frost
outside moister cause making frost, probably you can not do it youself,if you know , do it.
Jun 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frost on ice maker
look at the chute where the ice comes out the door and see if the door in there is sticking open and leaking air in some times it helps to hold a flashlight on the out side aimed up the chute while lookin down on the inside
Dec 31, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
102 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
