Question about NetGear WNR2000 Wireless Router
Unable to get laptop too connect wireless ..saying codes /password dont match
  • susan_ann Aug 01, 2010
    thank you both...however the passwords and access codes were all written down and double checked. The access codes are the ones being rejected.. but another lap top connected with the same codes etc works.....and another which has been working all week has suddenly stopped connecting..go figure.
    President:
  • 2,571 Answers
Then put the right password in.
Is caps lock on?
was caps lock on when you set the password?
are you logging onto the right wifi network and not a neighbours?
Still no luck? log onto your router and change the password
Posted on Aug 01, 2010
    Scholar:
  • 104 Answers
You should check the password which you have given for the router. Either you are typing it wrongly or you have forgotten the correct password. Try resetting your password and then try to connect your laptop via that router. Your problem will get solved
I had the same problem and just press a tiny button that is next to the ethernet connection to restart the wireless router and it did worked
Posted on Aug 02, 2010
Can access internet to my laptop via ethernet cable but not wifi through Cisco Linksys router model no SPA2102 as I have lost network security code... tried to find number to call for support but dont...
ok well if you lost your security code then the only way you can connect to your wireless connections again is to have the correct credentials correct Passwords .in your case you lost your Password the only options you have is to reset your router and setup new Password for your wireless . ok lets reset the wireless router now . on the back of your router their is a tiny hole says Reset use needle or a pen to press the button for 40 seconds and release turn off your wireless from the plug and turn it on again . now connect to your wireless and you will not need password to connect Internet.
if you need help with setting up password on your router then email me zana_adil86@hotmail.com
May 02, 2011 | Computers & Internet
Have a d-link router with password. Ipod touch(8G) won't connect
Try remove the password on D-Link router, put it on open conditions (no security enabled).It should work.
If still won't connect, try using laptop or any wireless device to connect to router(without password), if connect, then there's something wrong with your Ipod.
Dec 08, 2009 | NetGear DG834G Router
Wireless light is lit on router (Westell 327W) but still unable to connect wirelessly. When I go to "connect to a network" it says security-enabled network.
You have somehow managed to enable security on your wireless (in my opinion should always be enabled) but if you dont know the passcode or want it disabled then in your web browser type '10.1.1.1' or '192.168.0.1' into the URL bar. Only one of those URL's will work.Then type your username and password (default username should be 'admin' default password should be '0000', it will say in instruction manual) then search through the configuration pages until you find the wireless security and change it accordingly. Sorry I cant give precise help because I dont have that brand of equipment, but you instruction manual should help
Oct 08, 2009 | Westell Wirespeed VersaLink...
My wireless settings got changed and need to re configure
You need to make sure that the settings on you laptop match settings on your router. You can log in to your router by opening your browser (from computer connected to router) and type 192.168.1.1 in the address. If you haven't been in it before the user name should be "admin" and the password is "password". Look for the wireless section and write down setting and enter them in the config for the wireless on your laptop. If you have a friend that may be a little more experienced ask for help. Not to infer that you can't do it I just don't know your expertise.
May 01, 2009 | Computers & Internet
Unable to connect wirelessly to my laptop
I assume you are running XP.
1) Click Start then Connect to...
2) Click Show All Connections
3) When this window opens, find your router and select it
4) Right Click and select connect.
5) If it already shows connected then your router may have some security settings in place.
6) If you are connected as I said in step 5 then re-plug in your cable, open a browser and type in 192.168.1.1 and hit enter
7) If you get the login screen for your router then enter admin and no password.
8) Look at the settings under wireless and set up your laptop security to match the router.
Good luck and thanks for using FixYa
Mar 21, 2009 | Gateway Wireless-B Router (wbr-100)
Unable to connect my wifi laptop to my existing wireless b/band
Your wife's laptop is setup to connect to another wireless network. It must be set up now for the wireless network that you are trying to connect to. This means that your wife's laptop is trying to connect to the wireless network somewhere else. You need to let the laptop look for available wireless networks. It should be able to see your wireless network. It will then require you to enter the password that you have set in your Zyxel. If you don't know the password, call Zyxel.
Feb 23, 2009 | Zyxel Prestige P-330W Wireless Router...
Wireless sgnal working but auable to connect to go online
You need to give the password of your modem in netgear settings .
Nov 25, 2008 | NetGear WGR614 Wireless Router
Wireless problems
HI,
do you usually connect to other wireless network with your laptop?if you don't I suggest trying to unistall the wifi network adapter ( control panel-> system-> device manager) and reinstall it.
Riccardo
Aug 03, 2008 | D-Link DI 514 Wireless Router (DI-514)
CANNOT CONNECT TO INTERNET
in the installation manual you have a url you can type in...its something like 192.428.111.1...ect about 10-12 numbers...type this number in the internet browser search window. this will tell you first if you have access to the internet. you should get the settings windows for your router. there you can make adjustments as needed for your rounter unit.once confirmed.
if you are having access to the wireless network you set up the password you set in is obviously incorrect when it was set up. first check the light on the front of the wireless router it should have various light on ..such as power,,usb...dsl...and internet..with the internet light flashing... as a precaution please do a repair connection on your internet access point on the computer ur using..right click the wireless icon at the bottom of your screen if ur using xp..sometimes this repair will be just enough to clear up issues.and allow access.
if this continues...you may need to reinstall the unit...there is generally a reset button (very small) on the underside of ur wireless unit and take the appropriate steps..
gl
K.
Dec 30, 2007 | D-Link 802.11g Wireless Router WBR-1310...
Cannot connect the wireless,. only cable
pls go to control pannel u will see wireless icon double click on it, follow the instructions, use it, it will help u to setup wireless network
Dec 14, 2007 | Sony VAIO PCG-K25 Notebook
NetGear WNR2000 Wireless Router Logo
410 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
