Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Have a Raypak RP2100. When I turn it on the pilot lights fine but after a few minutes (~30 minutes) the heater turns off and PLT is indicated on the control panel. If I recycle the power it lights fine and repeats after about 30 minutes. It is about 10 degrees below the set point. I had some work done in the house (had to shut gas off at main and replace a line) about two weeks ago. I am wondering if there might be air in that line and it needs bleeding?
  • 3 Answers
If your Raypack (mine is a 2100 but most have the same electronic ignition pilot) lights and runs for about 2-5 minutes an then shuts off, you need to clean the pilot sensor. The pilot sensor tells the unit the Burners are running. If the pilot sensor becomes corroded, carbon, etc. the unit will light but will shut off after a few minutes as it thinks the unit is not operating properly. The unit will try to re light, but fail, and then PLT will show on the main programming screen. To fix the probelm, shut off the unit power. Remove the pilot assembly which is located at the bottom right of the unit. There is one screw holding the pilot assembly in place. Gently remove the pilot assembly. There is a fork like probe sensor (not the one with ignition and gas feed) that needs to be cleaned. Take some rough sand paper and clean it thoroughly. Re insert pilot assembly and fire the unit. If this fails, clean the sensor again. Problem solved!
Posted on Sep 25, 2010
Is there a power reset button?
You may want to make certain that the pump is running ( moving water into the heater ) in order to activate the heater. The heater will not try to fire without water moving through it. PLT code means that the Pilot is trying to ignite. If you see nothing on the display, you may want to verify voltage.They are typically wired on the same circuit. Therefore if one has correct power ( activated ) than so should the other.
May 29, 2014 | Raypak RP2100 DIGITAL POOL HEATER R206...
What part do i need when plt code comes display ?
spk I think means spark for ignition and plt means pilot so i assume the heater tried to light but the pilot light is not staying on. could be dirtly contact on the ignition spark plug or dirty pilot flame need to be cleaned and the unit serviced.
i hope this was useful.
May 28, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
Plt code comes on display ?
Plt means pilot light failure. the heater has failed to ignite. either the ignition unit needs cleaning or replacement or the pilot light valve where the flame is, has got dirty and needs a service.
recoment you get a heating service engineer to have a look at it.
Raypak RP2100 Model P0127NCO spa heater with a problem.
Cycling on/off like that can be a number of things. One of the more common problems is a "flow" problem. Try cleaning out your filter. If it is this type of problem, the flow switch is not sensing proper amount of water flow.
Jan 15, 2013 | Raypak Pool & Spa
How to replace a pilot
Probably no need to replace pilot. Just clean it. If your Raypack (mine is a 2100 but most have the same electronic ignition pilot) lights and runs for about 2-5 minutes an then shuts off, you need to clean the pilot sensor. The pilot sensor tells the unit the Burners are running. If the pilot sensor becomes corroded, carbon, etc. the unit will light but will shut off after a few minutes as it thinks the unit is not operating properly. The unit will try to re light, but fail, and then PLT will show on the main programming screen. To fix the probelm, shut off the unit power. Remove the pilot assembly which is located at the bottom right of the unit. There is one screw holding the pilot assembly in place. Gently remove the pilot assembly. There is a fork like probe sensor (not the one with ignition and gas feed) that needs to be cleaned. Take some rough sand paper and clean it thoroughly. Re insert pilot assembly and fire the unit. If this fails, clean the sensor again. Problem solved!
Sep 21, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Just bought a used RP2100 P-R265A-EN and after hooking it up I following the operating instructions in manual but pilot does not light and after 2 minutes the LCD screen reads PLT (top left corner it shows...
Be sure to open the gas line at the heater and turn on at local valve to bleed the line. Let run for a few seconds till you smell gas. Close valve and close line then let sit for a few minutes till gas clears and try to light again. Let me know how you do and good luck.
Apr 23, 2010 | Raypak RP2100 DIGITAL POOL HEATER R265
Raypak pool heater
Is it a cartridge filter? If so, get a new element.
Aug 30, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
My raypak rp2100 electronic seems to light the pilot light but then it takes a while to light the gas and when it does it shoots flames out the top of the heater. I'm thinking its the gas valve or the...
It is probably something much more simple than that...Turn it on and stand back until it finally ignites, then look, using a mirror, at the burner tray from below. You will probably find a lot of the tubes, especially those near the pilot area, are not working or are burning bright orange. If that is the case, something, probably spiders, are blocking the gas from getting into the tubes. That will cause the big burst at ignition as the gas builds up for a bit before it finally reaches the pilot area.
Aug 13, 2009 | Raypak Rp2100 Digital 336k Btu Propane...
We had a power outage. now the spk keeps buzzing but furnace wont start. There is flame at the pilot, I can see it. But it won't start the main heater. eventually the PLT message comes on.
The 'thermocouple' might not be working. Is the pilot light staying lit? The therm. sends a millivolt signal to the control insuring a pilot is lit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 09, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
RayPak 2100 pilot won't light heater. I'm getting PLT message.
Well your right it is your ignighter the spk is spark the plt piolet light this pc is about 200 .
THANK YOU FOR USEING FIXYA
RATE ME
Mar 29, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
660 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
