Question about Motorola Mobility RAZR V3
Bluetooth Problem??? My 18 month old V3 suddenly heated up while it was tucked in my waist band. It got really hot and then the battery died. I rechardge the battery but in a very short time it died again. I noticed the little blue light on the front that indicates the bluetooth function is turned on is lit. I have never used this function but I went into the menu to make sure it did not somehow get accidently turned on. It was not. I turned it on and then turned if off again hoping to reset it. Did not help. For what ever reason, I think the chip that has the bluetooth function is fried. If this is true, can it be fixed? If so, would it be worth the money? Do you guys repair cell phones or can you refer me to someone who does?
    Sergeant:
    Champion:
  • 283 Answers
Ok here's what you gotta do, this may solve u'r problem, go to menu, settings, initial set up, master clear Code ( 000000 )w8. phone boots, then go again to menu, settings, initial set up, master reset, Code ( 000000 ) then the phone will boot...and your fones restored to it's original settings, but the problem you had with this heating up thing, cant resolve, your phone is grounded, or your batt is no good... if you have multi tester put the pins on both side put to 0 value, in the battery terminal. then switch it both terminals again on both outer side of terminals , and if both after swicthing, cursor moves u'r fone is grounded, go to service center and they will replace yoour p.a. ( power ampli ) gud luck!
Posted on Apr 25, 2008
Boiler does not fire up sometimes and takes around 5 minutes to fire up when it does.
If you've had it for about 18 years it may be time for a replacement or, at the very least, a boiler repair. I had mine replaced three months ago and it was 15 years old. I think that it is important to make sure that you replace important things like this about every 15 years just to ensure that everything is working properly and is up to date. How long have you had issues with it? Because if it has worked really well up until recently then all you probably need is just the repair though. Bailey Plumbing and Heating and Air Conditioning
Sep 02, 2015 | Water Water Heaters
The heater shorted out, sparks, electrical smoke. Is it salvagable or should I replace?
Yes you could say it has died 18 years has been very good time to look for new . I don't think you will get parts for it now .
Feb 23, 2012 | Lakewood Oil-Filled Electric Radiator...
Put a hot pocket in for 3 min and it doesnt even
the unit inside the microwave that heats called the "magnetron" has gone bad or the circuits that power the magnetron have failed. if its under warranty still, send it back to the manufacturer. if not you can call some repair shops and see how much it would be to service it, but its most likely going to be cheaper to purchace a new microwave since they are relatively cheap these days
Jan 14, 2010 | Microwave Ovens
93 astro van suddenly died
Check that connections are clean and check battery voltage with a meter...If battery has less than 12v in it, likely you have a bad alternator.
Jul 18, 2009 | 1993 Chevrolet Astro
Motorola Razor V3xx has frozen keys except on/off button
Take the battery out and set it under a hot laptop for a half hour.
Jun 12, 2009 | Motorola Mobility RAZR V3
Car dies if accelerator is not engaged
the starting problem could be head gasket if it got really hot..... black smoke wouldn't be oil, and gas would stink but not black smoke if it's old, it wouldn't really matter if it had been sitting for 4 months. black smoke is probably caused by a gas mixture problem, or maybe a stuck fuel injector.
Feb 20, 2009 | 1990 Ford Taurus
Bluetooth module not attached !
try this,., delete old pairing for ur bluetooth, and re- pair it again...gudluck
May 10, 2008 | Motorola Mobility RAZR V3
Razr Inop
you need to take the phone back and have it replaced for a new one.
Mar 19, 2008 | Motorola Mobility RAZR V3
Dying battery
first fully discharge the battery then place it in a plastic container and put it on the freezer overnight, just make sure that no moisture will enter on the cointainer. after taking it out on the freezer let stay at room temperature for 5 minutes, then charge it. I always do this with my old batteries and it works well.
Sep 26, 2007 | Motorola Mobility RAZR V3
Battery charge
Make sure that your bluetooth is still not powered on. It tends to drain the battery, but you probaly have another problem as well. Perhaps you should invest in another battery, to make sure thats not faulty.
Nov 01, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
75 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
