Question about Brother IntelliFAX 4100 Laser Fax
HOW CAN I DELETE MEMORY FOR A BROTHER TELLIFAX 4100E WITHOUT PRINTING OFF HARD COPY. RUNNING LOW ON TONER
  • 4,323 Answers
Hi
Go to Fax settings and delete all the remaining jobs from the remaining job queue. After this turn off the machine, unplug it and wait for 2-3 min.s. Restart the fax machine and check. If the jobs are still pending then You can set the machine to print activity reports at specific intervals (EVERY 50 FAXES, 6, 12, 24 hours, 2 or 7 days). If you set the interval to OFF you'll not be asked to print the faxes.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Posted on Aug 01, 2010
  • Daniel Scott
    Daniel Scott Aug 01, 2010
    Hi
    Go to Fax settings and delete all the remaining jobs from the remaining job queue. After this turn off the machine, unplug it and wait for 2-3 min.s. Restart the fax machine and check. If the jobs are still pending then You can set the machine to print activity reports at specific intervals (EVERY 50 FAXES, 6, 12, 24 hours, 2 or 7 days). If you set the interval to OFF you'll not be asked to print the faxes. Please check the User Manual Page# 93(10-2) on how to do this---
    Brother TELLIFAX 4100E User Manual
    Daniel
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
My Intellifax 4100e has 22 faxes in memory. How do I print these ones in memory and then clear the memory?
Hi Veronica, try this: press "menu" then "254" then "fax start". This should print out what is in memory.
Sep 04, 2013 | Brother IntelliFax-4100e Fax
2" black band prints on right-side of every page
print a report, any report, from your control panel. if it looks good and your band is only on copies and transmitted faxes, that would be your Contact Image Sensor going bad. its located under your document feeder and looks like a sinny piece of glass that runs left to right.
hth,
razors
Nov 14, 2011 | Brother IntelliFax-4100e Fax
Brother intellifax 4100 e display says to replace toner but cartridge is not empty. Is there a reset for the toner?
There is no reset for the toner. It uses an optical system where light shines through the toner. Shake the cartridge gently left to right to even out the toner and try again.
Jul 01, 2011 | Brother IntelliFax-4100e Fax
Fax machine says: Printing Online on its LCD readout but won't print anything. We have replaced the drum and the toner. We can't get the message to clear either
Press "Menu" & "Mode" keys. Display should clear. Then press 0, enter 91. Hit stop after completion. THIS WILL CLEAR ANYTHING IN MEMORY.
Aug 17, 2010 | Brother IntelliFax-4100e Fax
Going through toner too fast. Changed toner two days ago. Asking to be replaced and have to shake toner. Yes, we are sure it was a new one :-)
TN -430 toner cart. 2500 copy count.
TN -460 toner cart. 4000 copy count
These are the two units that fit the 4100 modles .
You must be receving all lot faxs to use up the toner that fast.
You can go in to setup and change the toner to use less. Will need service book that came with the unit. Hope this helps
Aug 12, 2010 | Brother IntelliFax-4100e Fax
Black streaking down one side
You need to open the front cover of the machine and remove the cartridge (drum and toner) On the top right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 10, 2010 | Brother IntelliFax-4100e Fax
May the tellifax be used for copying only?
http://www.brother-usa.com/manuals/default.aspx?ModelID=455&ProductGroupID=2
This is the link to the manual, and yes you can make a copy, put your original in as you would to send a Fax, but press the copy button, and then the start.
Hope this helps
Ed
Apr 14, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Toner cartridge message
Nearly all Manufacturers now only give you "starter cartridges" in new machines.
Nov 13, 2007 | Brother IntelliFax-4100e Fax
Brother IntelliFAX 4100 Laser Fax Logo
280 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
