Question about GE Profile PDW8600J Built-in Dishwasher
GE Profile Dishwasher Model GSD4330Y72WW is leaving dishes with a dry powder on them after a wash. Seems like the upper sprayer is not working.What do I look for to repair?
ngfam1
  • 639 Answers
SOURCE: GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dear friend,
ngfam at you service! happy to assist!
Sprayers or sprayer clogged and or pump weak!
Better call service
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
  • 677 Answers
SOURCE: GE Profile Dishwasher (5 years old); Leaving residue on dishes
There is a new product out that actually filters the water going into your dishwasher. My dishes came out amazing after the first load. No more cloudy glasses. I was very impressed. Who knows whats in the water cleaning your dishes so i thought this filter was great. It is very affordable and you can get it at www.dishwasherfilter.com. Hope this helps some people.
Posted on Jan 06, 2009
SOURCE: My GE Profile Dishwasher PDW7880 Soap dispenser does not empty
I had the same problem. After some investigation I found that the hose that brings water to the top arm was clogged. There was a piece of chipped china logged in there. I have no idea how it got there as it is at the top and facing the the back wall but once I managed to take it off it solved the problem.
Posted on Apr 09, 2009
  • 9 Answers
SOURCE: GE Profile Max Dishwasher
I,m not familiar with this make or model but all spray arms should be removable bottom normally pulls off top quarter turn and pull and the back water feeding tube can also be removed usually by clips.rinse through thoroughly and hook out food stuffs with needle from the eyelets.the cause is general build up but mainly pips seeds rice etc.solution is to rinse plates before going in machine also checking filter is firmly in place before wash cycle.remove and check filters regulary. hope this helps
Posted on May 18, 2009
venexcsd
  • 1185 Answers
SOURCE: Powder detergent not distributing in ge quiet power 3 dishwasher
Try storing your powder in the dryer cupboard or in a warm area
It is more than likely that it is damp when it is going into the machine which means it clumps up instead of mixing with the inflow of water
Other thing to check is is there is a restriction at the back of the dispenser drawer which is not allowing the powder to flush down into the machine.
Finally , dry the dispenser slots with kitchen roll and give them a spray with a good quality furniture polish, allow it to dry for a few minutes and then buff it with a cloth, the silicone or wax in the polish should help the powder to slide
Posted on Jun 02, 2009
I own a GE Profile Trition quietpower III GSD5940F00SS dishwasher. The dishes, particularly the mugs and cups, are not getting clean.
Your sprayer arms may be clogged. You can remove them by loosening the screws holding them in place. Flush them with the sprayer at your sink. If you can SEE residue (parts of paper labels, bone fragments, fruit peel pieces, etc) remove them with a tweezer.Reinstall the spray arms and see if that works.
Three more ideas:
(1) run a cycle without dishes OR detergent and use 1/4 cup of white vinegar instead. This will break down soil and "gunk" and help your dishwasher run more effectively.
(2) use an old toothbrush and clean the underside of the door INSIDE the dishwasher. The door will be open and you just brush the bottom of the open door on the INSIDE of the dishwasher. A lot of "crud" gathers there and can be redeposite on your dishes. We seldom think to check that area.
(3) the pipe that carries water to the upper sprayer arm MUST fit against the outlet in the back of the dishwasher. If it is dislodged or not seated properly, the water won't flow to the upper sprayer arm.
Hope one of these suggestions helps. If it does, please rate my suggestion. Thanks.
Jun 03, 2011 | GE Dishwashers
My dishwasher is leaving a white film powder on all my dishes. It appears the powder is in the dishwasher. How do I clean it out? How do I clean my Ge range profile rangetop?
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Mar 29, 2011 | GE Ovens
Dishes do not clean, whats wrong
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Please post back for any further assistance.
Daniel
Aug 21, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dry white powder on dishes after washing
Hard water maybe?Or your heating element in the bottom may need some cleaning. take pour some vinegar on it and see if the lime bubbles. if so get something like lime away or CLR and pour it on the element let it set for 5 to 10 min then run it through a cycle for rinsing it all out. If the problem goes away for a while then comes back within 90 days I believe you need a water softener.
Mar 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Dirt and residue left on glasses
wash glases alone ad a jet dry aditive to detergant  Vitally
Jan 26, 2009 | GE Profile PDW8600J Built-in Dishwasher
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dear friend,
Better call service
Aug 04, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Dishwasher
It could be a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle,it pushes the water out of the dishwasher. The motor and pump are located beneath the dishwasher. Look if the pump's impeller (a round plastic fan blade-type of device) spins around freely. In case it doesn't spin freely, look if it doesn't blocked or stuck from any other reason. Good luck!
Sep 10, 2007 | GE 24 in. Profile PDW7800 Built-in...
GE Profile PDW8600J Built-in Dishwasher Logo
43 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
