Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer will not spin Part that stops the spin when the lid is up is broken
  • 50 Answers
If no children are in home or are responsible enough not to play in washer just bypass the switch. ther are two power wire usually gray or black and white. bypass the two power wire splice together. the washer will not stop spinning when lid lifted hence the reason you dont want little kids near them.
Posted on Aug 01, 2010
Washer fills and does the wash cycle then stops. doesnt rinse or spin
Most likely your lid switch is broken on the washer. I(t acts as a safety mechanism to stop the tub during spin should you open the lid.)
The switch is located under the top of the washer on the right side of the lid opening. It is activated by a plastic strike on the same side of the lid.
Jun 12, 2010 | Whirlpool LTE6234D Top Load Stacked...
Will not spin in the spin cycle
This is a typical problem. If the machine fills up and stops and makes absolutely no noise whatsoever, what you have here is a broken lid switch. The machine simply thinks the lid is open, and therefore does nothing. Naturally after cracking a machine open you may find uncommon things such as broken and/or burnt wires, but these are unpredictable and highly unlikely.
If the washing machine is making noise but just not spinning we may have other problems. The other problems may be a slipping break clutch assembly or a transmission. Those are the two most likely candidates other than the lid switch. Get me a model number and I can look up a diagram of your washer and give you more tips if it's not a lid switch.
May 29, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer wont spin
WASHER DON'T SPIN
normally if is filled with water an does not spin, check ur door switch may be bad or broken also check the lid make sure the smaill white tab is there too, the switch normally break when someone stands or slamms the lid hard or puts heavy baskets over the lid ,the switch mounting screws base is made out of plastic so is easy for it to split
the lid switch is a safety device that stops the machine while on spin cycle, in case you forgot your wallet u go back to get it stick ur hand in it, and is on spin cycle, as soon as u open the door, the door will deactivate the power tho the washer, and the basket will stop, when not going into spin mode is one of the main reasons
good luck leave some feedback!
Feb 01, 2010 | Washing Machines
WHDRR418G1WW WASHER WON'T AGITATE OR SPIN, NOT MAKING NOISES. FILLS AND DRAINS FINE.
sounds like you have a broken lid switch on the washer, maybe someone slammed the door or placed or stood on top of the washer, a broken lid switch won't allow washer to go into spin mode is a safety device so if is on spin cycle an someone sticks their hand it the machine stops an not breaks your hand.
broken lid swtich
good luck leave some feedback thanks!
May 28, 2009 | GE Washing Machines
Possible lid switch stopping basket from spinning
Lid switch is safety mechanism that cuts off power to motor when lid is open. If it is broken or faulty you will not get power to motor during spin. Hope this helps!
May 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer will spin but not with clothes in it?
Ckeck to see that the lid-switch activates when you put the lid down ,maybe the probe on the lid is broken off and then there won't be anything to push the switch down to make it spin .
Dec 28, 2008 | Whirlpool LXR6432JQ Top Load Washer
Washer stopped in the middle of a load
sounds as if yhou have a lild switch problem , lift and close the machine lid and listen closely for a "clicking " if hte machine doesnt think the lid is down it wonk spin/ drain for saftey reasons. common issue broken lid switch
Nov 13, 2008 | Washing Machines
Washer estate brand ETW4300SQ Model
If the washer fills and stops at the rinse cycle, and then will not spin or drain, you more than likely have a defective lid switch. If you open and close the washer lid and do not hear a “clicking” sound, the switch has probably come loose, or has broken. There are two mounting screws that hold the switch in place along the washer rim. Also, inspect the lid to ensure the small plastic piece that pushes down on the switch when the lid is closed has not broken off. This is called the “lid strike”. If the lid strike is broken or missing, the lid switch will not activate. If you diagnose the problem and need to replace the switch, you can click on the following link for advice on how to replace it:
http://www.fixya.com/support/r397101-replacing_lid_switch
If you need further assistance, such as where to get replacements parts, please let me know. I hope this helps you.
NOTE: You do not need to drain the wash tub to replace the switch. Once the switch has been replaced, the washer should spin and drain, which will prevent you from needing to bail water.
May 23, 2008 | Estate TAWB600JQ Top Load Washer
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
169 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
