Question about Frigidaire FRS26H7CS Side by Side Refrigerator
Refrig clicks on and off continously for a certain time and finally turns on, the thing is it has no problem cooling or freezing but the clicking on - off thing will drive you nuts. I think it has something to do with a relay or contactor somewhere.
  • tiger4life Aug 02, 2010
    Well now the freezer seems to be working but the frig does not, the air is blowing in the freezer but not the frig and the damper in the frig is open. I was thinking the adaptive defrost module was bad but now I am totally confused is there another damper. I am a electrical contractor but NOT a appliance guy. I do have the schematics and wire diagrams.
    Now the freezer is working and the refrig is not, the damper in the refrig is open and air is blowing in the freezer but not the refrig. Is there another damper in the freezer, could this be a problem with the adaptive defrost module. Im totally confused now. With the freezer working it would seem the compressor is working, the clicking on and off has stopped but so has the refrig but not the freezer.
    President:
  • 949 Answers
You are correct in your assumption. The problem you describe are consistent with the start relay on the compressor. It will act this way then eventually quit all together if not replaced.
The relay is attached to the compressor. Pull the frig out and unplug the power cord. Take the lower panel off the back, the compressor will have a black plastic cover on one side of it. Under this cover is the relay.
The relay will go bad from overheating. Be sure the coils are clean and the fan by the coils is running.
Posted on Aug 01, 2010
MY GE MONO SIDE BY SIDE REFRIG,MDL ZISS480DRSS IS FREEZING THE REFRIG SECTION.THE TEMP READ SAYS IT IS NEARLY 80!I THINK IT MAY BE REACTING TO THE TEMPERATURE DISPLAY AND TRYS TO COOL IT DOWN.HELP!
Here are possible parts that could cause the problem
GE Refrigerator Freezing Food but the most common is the diffuser/damper that got stuck open and cold air from freezer continously coming in to the fresh food side.
Nov 22, 2017 | GE Refrigerators
Side by side ge refrig freezing food in refrigerator side temp control working since when turned to zero clicks off what could this be
Probably the temp control is defective and is defaulting to maximum. I would suggest replacing it to be sure.
Feb 01, 2015 | GE Refrigerators
Ge tv239461 freezer is cold but refrig is warm
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 27, 2011 | GE Refrigerators
Refrig and freezer not cooling and "clicks" at
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 24, 2010 | Kenmore 53642 / 53644 Side by Side...
Refrig not cooling and freezer not freezing. checked circut breaker. unpluged and repluged refrig: still nothing. Help!! hurry
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 16, 2010 | Refrigerators
Refrig not cooling and compressor hot short cycling
heatman101
ghddgkh
Mar 27, 2009 | Amana ARB2557CSR / ARB2557CSL Bottom...
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
Defrost issue
its the timer if you manually advance it and it heats the back of the freezer please rate my advice...
Oct 02, 2007 | Kenmore 71279 Bottom Freezer Refrigerator
Frigidaire FRS26H7CS Side by Side Refrigerator Logo
56 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
