Question about HP Officejet 5610 All-In-One InkJet Printer
My printer takes nearly half an hour to print our a text in an A4 paper. Please tell me what could be the problem. I have even changed the Cartridge.
This might be due to dust.
try to clean your printer, and use it regularly.
9atleast 2 prints per week to keep it in continuous working.
and cleaning is more important it should be dust free.
Posted on Aug 02, 2010
  • rishabhseth Aug 02, 2010
    this might be due to dust.
    at least 2 prints per week to keep it in continuous working.
I'm using half of A4 size paper and when I print my file on it, it takes 20 seconds after feeding the paper. Is there anything I can do to make it faster?
I fixed your capitalisation, punctuation and grammar. Half of an A4 sheet is an A5 sheet and should take half as long to print an A4 sheet. Print speed is dependent on a number of variables;
Density of colour, the more colour or more blocks of black take longer. Yours is monochrome and these are the specs. You should get 12 pages per minute. It may be that your computer is slow and also is low on available RAM memory. This is an old printer and you may think about upgrading. I had one of these 10 years ago.
Benefits
  • 12 ppm mono printing
  • Zero warm-up time from sleep mode
  • First Print Out Time in only 9.3 seconds
  • Up to 2400 x 600dpi print resolution
  • Energy efficient and quiet operation
  • Easy to use All-in-One cartridge
You should get 12 pages per minutes
Sep 16, 2015 | Canon LASER SHOT LBP-2900 Printer
Get the esp 2170 to not print light green instead of black ? I keep on replacing cartridge , to no avail !
replacing a cartridge, while the nozzles are blocked won't help.
Realise the printer will mix there colours to get "black" on the paper. So even a full cartridge, can't make the other colours black till the blockage is gone.
Please try this. If you have ink cleaning fluid, (only for printer ink) use that, if you dont have cleaning fluid, use clean water.
Open the printer as if you replace a cartridge. Remove the black one and look tot the bottom of the cartridge holder. There is a little pipe, where the ink should go in. put some drops water or cleaning fluid in there leave it a few minutes. with a tissue dry it and again insert some drops of water or cleaning fluid. Then put in a cartridge and give the printer a black and white print job. Like print a few A4 papers. Let it print till the black comes back. Can take up to 4 pages A4. I hope this will unblock the nozzles.
Please even if you don't need to print, switch the printer on at least once a week. And even better, let it do a bit of printing every week. This will save a lot of frustration.
Dec 03, 2014 | Kodak ESP Office Equipment & Supplies
My black cartridge was nearly out of ink and the printing was either ghost text on some lines and on others as if someone had drawn a thin white line thru the text. I have just received a brand new black...
There may be some dust on the contact on the printer, first thing you should do is get a q-tip and clean the contacts carefully to ensure there is no dust or other contaminants on the contacts where the cartridge connects.
Also please could you supply the printers make and model so I can look into this further
Jul 15, 2011 | Office Equipment & Supplies
Text and graphics not printing complitely Half Image and Half take printing from HP 1020 printer. If I give Print command only two or three line print come on paper after that four to five line black again...
Try another cartridge as it sounds like your drum is bad. If you measure the distance between the start of two sets of print I can tell you exactly what is wrong.
Mar 16, 2011 | HP LaserJet 1020 Printer
What is the replacement printer for HP Laser Jet
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions. Print cartridge life expectancy The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges. Changing the print cartridge Follow the below instructions to change the print cartridge:
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box. Figure 1: Removing old print cartridge c00028312.gif CAUTION: To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
  2. Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge. Figure 2: Gently shaking new print cartridge c00028313.gif
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling. Figure 3: Removing tape from print cartridge c00035442.gif
  4. Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door. Figure 4: Inserting new print cartridge c00028315.gif
Apr 20, 2010 | HP LaserJet 1010 Printer
Is only printing half of any page i have emails and even when i changed page to landscape it still only prints half
Make sure you use the correct paper type. For example if you want to print on A4 paper then the printer must be set to A4. To see this, go to Start- > Control Panel -> Printers and faxes.
Right click on your printer and choose Printing Preferences. Then go to paper type and set it to A4.
If you are printing through Outlook, double click to open the message and then select File->Print (don't use the print icon directly from the toolbar).
Then, on the print dialog click Preferences, and see if the paper is set to A4.
Regards,
nicolasiac
Mar 02, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Paper out message, wanting A4 size
Hi rmfgco2009
A4 paper is 8.3"x11.7" OR 210x297
Letter size is 8.5"x11" OR 216x279
So your paper is called LETTER size not A4
What you have to do is;
  1. On the LCD display of the printer, through the SETUP, change the paper size from A4 to LETTER. Save the settings and Exit.
  2. Also, From the Control Panel, printers, properties, preferences, features change the paper size to LETTER. This step can be done from EXCEl also through the printer menu.
  3. You may need to Turn the printer off and on again.
Hope this will work for you. If this solution is helpful, please give a rating.
Have a Good Day
luciana44
Nov 30, 2009 | HP LaserJet 4 plus Printer
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Using far too much ink
This came from brothers website:
The Yellow ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Magenta ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Cyan ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Black ink cartridge yield is up to 350 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
so it appears that what you are experiencing is not normal and you may have a leaking printer.
There is one thing you can check though, everytime you print, make sure that you are not printing at the highest quality option selectable as this almost certainly will fire out more ink than regular printing... choose a middle quality option or even draft option if you will be printing regular text.
Jul 02, 2008 | Brother Office Equipment & Supplies
I have a Canon S330 printer which I have had for over five years and it has always been extremely reliable. However, very recently, it has not been printing so well. I typed a full page A4 letter yesterday...
it could be that the page lenght or papaersize is incorrect, you could try to adjust the paper size to A4 / letter size depending on the paper that is standard
Apr 25, 2008 | Office Equipment & Supplies
HP Officejet 5610 All-In-One InkJet Printer Logo
118 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
