Question about JVC LT-52X579 52 in. LCD TV
I turn on the tv then it turns back off on its own, ill click the power button then the solid blue light comes on, then it just shutts itself off right after.
  • 608 Answers
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
Westinghouse ltv-46w1 hd
Test the various power supply voltages first if your able to be sure they're ok, if they are it could be the main or Tcon board that is bad
Mar 20, 2018 | Westinghouse Televison & Video
LG55LH40 LCD TV wont come on
The set will need to be properly diagnosed. It could be a defective main board or power supply.
Sep 01, 2012 | Televison & Video
Tv just went off in use. Power light blinking, will no turn back on
Set is in shutdown as a short somewhere.
If model indicated here is correct someone has to open it and check voltages in power supply first.
Apr 01, 2012 | Toshiba 36AF43 36" TV
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Olevia TV problem.
If you wish to get some details; visit the site linked here. Pull up older posts.
Apr 10, 2017 | Televison & Video
Insignia 42 inch TV won't turn on
The power supply is in the protect mode. There are many things in the set that can cuase this. Most likely there is a short on one of the circuit boards, or the power supply itself has failed.
You will have to have the set serviced in order to get it going again.
Jerry G.
Jun 03, 2008 | Televison & Video
Tv comes on and shutts off immediately
Well no, it won't exactly work with out the ICS which is an internal control relay card. He most likely was thinking it was a power distribution problem. My suggestion is to look at the power supply and make sure nothing is bridging any of the circuitry. Just like a computer the on and off button is attached to a set of pins, and just like computer motherboards the controls also exist for a reset. And if anything bridges these pins turning on the unit will just cause it to shut down again. Also look for water damage and heating damage that might have caused problems with the power supply unit.
Apr 29, 2008 | Philips 43PP9202 43" Rear Projection...
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Dec 19, 2006 | JVC PD-42WX84 42 in. HD-Ready Plasma...
JVC LT-52X579 52 in. LCD TV Logo
182 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
