Question about Sharp AR-168D Copier
Message: add paper to paper tray
We get a message and a flashing light that says there is no paper in the
tray when there is. Tried a different drawer, still is happening.
Also the bypass feeder is not working.
Well, unfortunately I do not know how to replace that one thing...BUT, I found a
different way to fix problem.
Rubbing alcohol on the rollers.
Doesn't help the bypass feeder, but it also has averted either buying a new machine
or spending $300-$500 or getting it fixed. (It was a $900 maching to begin with and
is only a year old with about 25,000 copies.
Thanks anyhow!
Posted on Apr 29, 2008
    Problem Solver:
  • 6 Answers
Clean photosensor or replace actuator on feed roller assy , try to use caned air to blow off sensor located above tray , if you reach in tray slot after removing tray you can feel a black actuator that swings. look there !
Posted on Apr 25, 2008
My Xerox Phaser 6128MFP printer flashes a red light with a "Load paper in Tray" message, when the specific paper size and type are already same in the tray.
If the paper size is correct in the printer and the printer and it's possible to print off a test print in both the printer control screen or directly from the print driver utilities if that works then the only thing I can suggest is the item you want to print is defaulted to a different size. i.e. Check that the word processor your using is set to the size you have in the printer. Imperial size pages will look very similar on screen as does the A4. Printers don't automatically fix paper print sizes you just have to check and recheck for differences. Removing the tray only reafirms to the printer that the size might be incorrect and your going to fit the correct size.
As for the red light all printers behave differently in certain error conditions. Have you also tried to print out something you printed at a time the printer was working correctly. In other words try printing out a different file. Maybe, trying to print off a test print of one line of the alphabet, and then go from there.
Good luck,
Apr 02, 2015 | Xerox Phaser 6125 Laser Printer
SCX-4216 "No Paper" message
Check this link it has a step by step solution that you can try
Hope that helps..........
Aug 07, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Paper tray empty error message
no could be your drivers are shot..turn off machine, and let it sit for 10 minutes..unplug from computer, turn on, then tray a test page from front panel
Apr 18, 2008 | HP Photosmart C6180 All-In-One InkJet...
Bypass tray has correct paper size but gives error message to add correct paper size. Won't print
Once you have the message, try removing the paper from the bypass tray, then introducing it again. Alternatively, leave the tray empty then send the data, when it asks for paper, introduce your 11 x 7, and it should work.
Mar 19, 2014 | Konica Minolta Di3510 Copier
"add paper" message but full of paper
jaha par paper laga rakhe waha ki paper tray select karo
Aug 01, 2012 | Toshiba 2060 Copier
Message keeps paper tray is full and it is full.
pull cassette out and look inside the cassette bay on the left side. there is a white gear that lifts up your paper. that might have come unseated. make sure its seated in right by pushing it back in. last but not least, make sure you don't have your rear paper stopper in cassette pushing paper too hard against the front of cassette preventing paper from raising up.
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
Tray 1- load plain letter
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
Error message for Ricoh C410DN
When that message is displayed, the printer thinks the output tray is full of paper and it won't print any more because there is no room left to spit pages out. If the output tray isn't full of paper, the sensor that detects paper there might just be dirty or dusty.
That sensor is a black sensor that should be located just at the point where the paper exits the machine, above where the paper comes out. Blow some compressed air on the sensor to try to clean it off and see if that clears your error message.
Oct 30, 2007 | Ricoh Aficio CL2000N Laser Printer
Paper not feeding
Is this a top feed - that is paper loaded on top at the back bottom feed from a tray underneath? Top feed take one sheet of paper and gently push it down whilst the printer is trying to grab it. Tray feed - take tray out make sure no paper fragments are in the tracks and find a nail board and gently abrade the pick up rollers.
May 13, 2007 | Brother MFC-620CN All-In-One InkJet...
Sharp AR-168D Copier Logo
112 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
