Question about Vehicle Parts & Accessories
Need to remove cobra 0802t immobiliseras i have broken the only tough key
How to remove key from 2000 jimmy ignition
Is it broken off in the ignition switch? If so, you will need a locksmithing key extract tool. It is a small strip of metal with teeth in it. You try and hook the broken key and gently pull it out.
Good luck as these are tough to do if you haven't done on before.
Sep 13, 2014 | 2000 GMC Jimmy
Toyota immobilisera
I don't know which corolla do you have, but in general Immobilizer can be fixed in the following ways:
1. By key programming. You must be having one working key.
2. By virginising.
3. Editing EEPROM data.
4. Using the key programmers specifically made for the purpose.
Dealing with the immobilizers call for professional experience and resources as well.
Oct 22, 2013 | Toyota Corolla Cars & Trucks
My cobra ltd wont transmit
sub the mic first as a broken wire inside it can cause this, does transmit light come on when keyed?
Oct 15, 2012 | Cobra 29 LTD CB Radio
Cobra 29 ltd classic someone messed with all the lil screw ins and gave it to me, problem its having is , you hear some background white noise, try to key up but no TX? the dead key drops altho talkback...
That will need an oscilloscope to get it back right. we can fix for you. wouldn't cost much if all it is just out of alignment and nothing is broken...
Jan 02, 2011 | Cobra 29 LTD CB Radio
Cobra 25 ltd wx classic
the mics on these cobras have a receive wire in them so the transmit will still work even if the receive wire is broken,if this wire is broken the unit will not make any sound...........remove the plug from the radio end of the mic and check the connections on the 5 pin connector.....(could be a cold solder or broken wire) or try a new mic or one that is proven work on another radio
hope this helps.................good luck!
Dec 18, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Dec 04, 2008 | Cobra 29 LTD CB Radio
Cobra immobiliser key
After ages searching finally found this on the Cobra site.... A8510 KEY PROGRAMING Ensure the immobiliser is disarmed :- 1) Switch the ignition ON and OFF three times then back to the ON position within seven seconds. 2) The LED on the dashboard will light up signaling the unit is in programming mode. 3) Touch an already programmed key onto receptical, the LED will extinguish for one second 4) Repeat step 3 for all other keys (Max of 4 touch keys) 5) To exit programming switch off the ignition key (unit will automatically exit programming after four keys) NOTE :- 1) Programing procedure can only entered with the system disarmed. 2) If all keys have been lost the system will need to be replaced
May 24, 2008 | 1994 Land Rover Discovery
No sound
The Cobra 25 requires the mic to be working for any sound to come out. My suggestion is that you first try a new mic. If this doesn't work, look real close at the board on the soldered side ( around the if section, thats the area that right under the waxed area on the component side of the board ) for cold solder joints ( broken lead solder) You may need a magnifing glass. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 17, 2007 | Cobra 25 LTD 40-Channels Base CB Radio
Vehicle Parts & Accessories Logo
228 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
