Question about Dishwashers
User Manual of Asea Cylinda 1200 Dishwasher
We have moved into a house that has an ancient dishwasher - but i am unable to find instructions on how to use it. also need to know if this particular dishwasher heats the water itself or is it used from hot water service?? Dishwasher is Asea Skandia cylinda 1200. I am wanting to know what the A, B, C, D, & E cycles are etc Thank you
  • Anonymous May 29, 2008
    My parents (elderly) have moved into a house with the Asea Cylinda 1200 dishwasher, no operating manual. Have no idea what the cycles are and it runs for 5 hours when my mother tries one of the cycles. We need some type of instruction manual.
  • Anonymous Mar 16, 2014
    frizer and normal fridge
One of these was in my house when I moved in, still have the manual. Very efficient dishwasher.
A is a prewash (machine will stop after it). Manual says it's meant to rinse stuff while you wait until you've filled the machine to run a full wash.
D is economy wash. Water is heated according to the switch you select on the front.
C is a prewash that will continue on to D (normal cycle). Water is at incoming temp.
B is another prewash that will continue on the C etc (heavy cycle). Like C, water is at incoming temp.
E is dry cycle. Heating element is on/off depending on switch on the front (dunno why you'd turn it off..)
While turning the dial, push it in and it will stop exactly at the start of theach cycle.
Mine has stopped emptying, think the pump has died, looking for a replacement..
Posted on Jul 05, 2008
We have just taken out our Asea Skandia 1200 dishwasher and cut the copper pipe at the machine end, we are getting a new Lg dishwasher, will the new connections be ok ?
We have a spare instruction manual if anyone is interested.
Posted on Oct 26, 2009
After some 20 years of using an ASEA Skandia 1200, i am quite sure that your parent's five hours long term wash derives either from a faulty temperature switch (if the heating element is ok) or a wasted heating element itself.
In the first case, the water gets hot and hotter, but none of the two switches for 55 and 65 degrees Celsius
tells it to the rotary clock control until the third one, a safety device interrupting everything slightly below
boiling temperature, starts running the clock's motor. Try running the machine at low temp(55). You may be lucky finding everything working properly afterwards.
In the second case, the water won't be warmed up and the heating element has to be changed
Posted on Oct 21, 2008
I have no manual either, but the B and C programs seem to run fine for me. I suspect the B program does some "pre-washing". The cycle is not long at all. I know that this washer can be connected to hot water (as opposed to most modern washers?) and this is what I have done. Overall I am very pleased with this washer and the results it gives.
Posted on Jun 15, 2008
Can anyone advise on how to disconnect the supply of electricity to the heating element, please?
Posted on May 21, 2010
Need a timer motor for asea cylinda 1200 dishwasher.
Standard appliance parts, Appliance parts incorporated, even Sears will have parts available generally.
Nov 09, 2015 | Dishwashers
Asea Cylinda 1400 dishwasher not filling. Keeps waiting for water to fill. Continues normally if manually add water. Tap is on and water available.
The incoming water valve is faulty. Look at the back of the machine where the hose connection runs into the machine, there should be a solenoid operated water valve there. Check that out or replace it.
Dec 05, 2014 | Dishwashers
Asea cylinda
go by manual so you dont mess up
Aug 08, 2013 | Dishwashers
OUr ASEA Cylinda dishwasher doesn't seem to have any power. The manual suggests the fuse might be blown. THe circuit breaker is fine. Is there a fuse on the machine that can be replaced?
You need to trace the power cord into the machine to confirm this case. It will lead you into the circuit and if power is not present to the controller section there can be a fuse before the circuit.
Remove power to the machine and remove panel to check.
Jan 24, 2013 | Dishwashers
Where can we obtain an instruction manual for the above dishwasher please Bosch Classixx SRS55CO2 GB/13
Hi and welcome to FixYa, I am Kelly
Go to this link:
http://unitedkingdom.boschnew.en.nectar-farm.com/customer-service/download-product-manuals.html
The click on download manuals and a new window will open.
You must enter ONLY this model number in the search window center page:
SRS55C02GB Find your manual /13 on the list and download the manual.
Thanks for choosing FixYa,
Kelly
Jul 14, 2011 | Dishwashers
Manual for Asko ASEA 1400 dishwasher
You can get the manual on the link below. It is uper right corner next to the man under the pdf. You will have to click on the stars to download.
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/1400-_E
Good Luck and please rate 4 thumbs up for the freee answer
Apr 24, 2010 | Dishwashers
Asea skandia cylinda 1200 manual
Dear Sir!
After almost 27 years since when I bought dishwasher machine type Cylinder 1100(during my post graduate of doctor engineer training - work in Finland haveproblem with manual programmatic. Because we have no chance to find in Poland,I would like to ask about possibility to buy and import it. If in case when itis similar like at Cylinda 1200 so I could update it. In the same time I coulduse and connect by adapting existing electric wirings. Please be so kind and help me solvingproblems. I am very satifited from good product done by your company. It is forme and my wife very urgent. Other way I will have only way to make all work inkitchen me. If you decide, please present quotation and all information fortransferring many. Best Regards
dr eng. Roman Lamentowicz.
roman@krola.com.pl
+48 602 211 746
Oct 16, 2009 | Dishwashers
Removing a built in Asea Skandia cylinda 1200
Its normal to have the water supply from under sink to dishwasher 3/8 soft copper. If there is a water stop under sink for dishwasher go ahead and shut it off. If not you will have to shut water off at main. Now you can unscrew supply at dishwasher, it's close to the front on left side. Its a 3/8 compression nut, you can use a small cresent wrench.
Sep 30, 2009 | Dishwashers
I push the start button on my Asea Cylinda 1500 dishwasher and nothing happens. Could it be the solonoid?? If so where would I find it so I can replace it?
Had the same problem. After years of opening and closing there is a risk for one or two cabels to be cut inside the door. Easy to fix.
Apr 13, 2009 | Dishwashers
Dishwashers Logo
3,844 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
