Question about Sony Handycam DCR-DVD105 DVD Camcorder
The dvd I record with my handycam will not play on my computer
The dvd I record with my handycam DCR-DVD105 will play back on the camera, but not on my computer? Any ideas?
  • ronsundberg Aug 01, 2010
    Yes I was able to play the dvd after finalizing it. Thanks, Ron
    President:
  • 1,197 Answers
There could be any number of different problems that you are encountering in this situation:
First, are finalizing the disks? In order to use the disks on other players the disk must be finalized, something that might not be necessary for the Sony player itself.
Second, most, but not all DVD players or drivers will play DVD-R. Look in the users manual to see what formats yours will play. (My friend's unit will play -R but not +R and I have one that will play +R but not -R). If that's the problem, double check whether it can have its firmware upgraded (go figure) and then play DVD+-R discs. You could also try using DVD+R or DVD+RW disks to see if that makes a difference.
are you making Video-CD's (VCD) in the transfer process? VCDs will only play on certain DVD player equipment.
Are the disks you are using able to support the recorders write speed? Using disks that do not support the write speed will cause unreliable results. These disks may or may not work on the recorder but will not likely work on other devices.
Will the disks play back in the recorder once finalized? if yes and it won't play on your computer see if it play son the computer of your friend's.
If all the of the parameters are met, i.e., it's the right right speed, format and it is finalized the disk should work in a player that supports the format.
there are two more possibilities as well
1. The DVD-R is burned with errors that the cam and the DVD player can handle but your DVD drive in the computer cannot. This one is kind of unlikely since computer DVD readers are generally more forgiving.
2. The DVD drive in your computer does not support mini DVDs or -R DVDs so does not detect the presence of a disc. You may be able to handle that by going to the manufacturer's website and downloading the latest firmware for the DVD drive. If you do get new firmware follow the instructions TO THE LETTER! Shut down any program that may "spring to life" during the process. Otherwise it's like you give your DVD drive a brain transplant and half way through you stop. DVD drive with no brain!
So even after checking all this ///// if it still doesn't work, then you might want to talk with Sony support.
Regards
Posted on Aug 01, 2010
    No, I guess I am not finalizing the disc....can't find my manual...what exactly is involved? Thanks, Ron
Sony Handycam camcorder model DCR-DVD105 door not stay closed
Something not latching is usually spring related. If you feel like taking it apart you can probably find out what is keeping it from latching.
Mar 14, 2014 | Sony Handycam DCR-DVD105 DVD Camcorder
Unable to play or down disc from my handycam DVD105?
Are you facing problems with playing only the recorded discs?Or all the discs in your PC.
Nov 29, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Jun 28, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony DCR-DVD105 Error message C:13:02
I´M HAVING THE SAME TROUBLE WITH MY HANDYCAM, PLEASE, IF YOU ALLREADY GOT A SOLUTION SHARE IT ! I´LL DO THE SAME IF I GOT IT FIRST !!!
GOOD LUCK
Jun 27, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony dcr-dvd105 no sound
Try this:
Play back a recently recorded scene through the viewing screen. Make sure any "mute" setting is turned off and turn the volume up. If you can hear the sound, the problem is not in the camera. Also, run through your menu's audio settings to make sure that they are set correctly.
If you can't hear any sound, repeat the process with an external mike attached. If this gives you sound, the camera's built in mike is defective. Time to hand it in for repair.
If you still can't hear any sound, something else is wrong with the camera. Again, send it in for repair.
Jan 09, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
I mistakenly taken out my DVD out of the sony 605E without finalising it. I am not able to playback it in the PC or even see it in the Camera........
Try this - Put the disk back into the camera and try recording a further short clip. If that works then finalise and try playing back in camera/on PC. It may help.
Jan 02, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
My sony dcr-dvd105 handycam camcorder all of a sudden shows only
There is 2 possibilities, either aperture of camera jammed and doesn't open or CCD Imager got defective in your Sony DCR-DVD105 camcorder.
Let me know if you have little experience of camera repair to guide you further.
Our DCR-DVD105 records dark pictures
Dear Momena,
If problem still exist in you camera, please initialize it. Hope this problem would be solved.
Apr 13, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony handycam dcr-dvd105
dear tonimo
if you was finish your recording, select menu and choose finalize
it can make your dvd can play in dvd prtable
oke
cropp
Dec 26, 2007 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony Handycam DCR-DVD105 DVD Camcorder Logo
82 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
