Dishwashers Logo
Posted on Aug 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water no going into dishwasher smell coming out like burning
Anonymous
Level 2:
New Friend:
  • Expert 50 Answers
  • Posted on Aug 01, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
50
Questions
0
Helped
13000
Points
153
Check your voltage at water solinoid. if volatage present. replace valve. if none check level switch or vater level sensor. most likely if no voltage will be control.
Why is there a burn like smell eminatting from back of new dishwasher
1. Damaged or frayed wiring that can overheat and cause a burning smell. You should check the internal wiring of the dishwasher for any sign of damage, such as burns, exposed wires , or melted insulation . 2. malfunctioning or worn-out motor or pump bearing that can create friction and heat, resulting in a burning smell. 3. Residue from the manufacturing process that heat up when the dishwasher operates, creating a fishy or rubbery smell
Why is the dishwasher smelling like electric burning and smoke coming out of the door vent?
Hi friend, thank you for your post!
I understand that your Frigidaire dishwasher is giving off an electric burning smell and you are seeing smoke coming out of the door vent. It could possibly be an issue with your control panel or door vent, both have electrical components inside of them. Since it could be either one of these underlying issues I would recommend having a technician come out to your home and diagnose and repair the dishwasher. Hope this helps. -Matt
Burning Smell inside siemens dishwasher
Most likely the smell is coming from a motor that is having a hard time turning, so it's overheating. Don't run it or it might catch fire!
Bosch dishwasher smells burning rubber
Certainly could be a pinched wire in the door panel. I would remove the panel and see if anything is pinched or being interfered with like the rinse dispenser solenoid.
Dave
Cycle runs but dishes are still dirty. No water.
Sounds like an inlet valve. If there is no water in the pump when it runs you can burn up the rubber seals. After fixing the fill problem you should check underneath for any leaks.
1helpful
A burning smell and steamy smoke come out when we open the door.
Normally, the last part of any cycle involves using the heater element inside, and at the bottom of, the dishwasher to give dishes a final hot rinse. Possibly some small plastic-type material has become melted and stuck to the element - which will remain hot even after all water is discharged. Hence the smell.
WATER NOT FILLING
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
Built in ge dishwasher push button
Mine is doing the same thing. I just removed the motor & it is definitely where the smell is coming from. Mine is about 3 years old.
Top Beko Dishwashers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
