Question about Asko Dishwashers
Keeps running even when shut off and states "overfilling".
  • 50 Answers
Sounds like the water solinoid valve is stuck in the open position. look at the hole where the water comes in machine. alot of times it will be a slow dribble of water which overtime overfills the machine. just replace water valve if thats the case
Posted on Aug 01, 2010
Keeps beeping but its not overfilled
Check the temperature and how long the aggregate runs.
If it is not cooling check the thermostat and the aggregate. Perhaps you even lost the cooling fluid. (used to be called Freon, but freon should not used today)
Mar 15, 2015 | Refrigerators
I have a window air conditioner, Maytag, the compressor keeps running and will not shut off. I have tried turning it off and on, but it still runs. I tried to turn it off by the button on the AC, but...
The compressor is controlled by a contactor (relay) the relay is stuck (contacts burned or if a solid state relay the "smoke has leaked out" :) it may require a control board change if it is a modern unit
Apr 13, 2011 | Maytag Portable Air Conditioner M6P09S2A
Washer overfills, dosen't stop filling even after I cut washer off
bad water level switch or the clear plastic hose has a hole in it or popped off the water level switch or the pressure switch same thing.the switch works by pressure,if there's a hole in it or the line feel off there's no pressure and the switch keeps calling for water,shut the water valve off
Jul 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
Water overfills icemaker. Won't shut off properly
Good day,
There is a micro switch in the ice maker that turns on the water valve for approx. 7 seconds, and then closes it.
If the valve is hanging open, even though receiving no input from the ice maker then the water valve needs replaced.
Nov 30, 2009 | Kenmore Refrigerators
The water does not shut off even after it reaches the proper level it continues to run and it overfills and leaks out the bottom of the washer the clear hose is not clogged and we blow into it we can hear...
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Sep 14, 2009 | GE WVSR1060A Top Load Washer
Ice maker over fill, water keeps running
If water keeps running to the ice maker all the time even when it doesn't call for water , the water valve for the ice maker is leaking(located in the back of the refrigerator,bottoom right),but if overflow only when it calls for water(no more than 7 seconds) the problem is in the ice maker control board, you can replace it but it will cost almost as a new ice maker.
Apr 14, 2009 | Refrigerators
Hot water runs constantly - overfills
This is often, if not all the time, a faulty fill valve, the fill valve has mechanically stuck open and is not fully shutting off when not the washer is not in use. This normally will become worse and could flood over the top of the washer = big mess .... replace the fill valve. The fill valve is the part the hot and cold water hoses are attached to.
Jan 11, 2009 | LG WM-2277HW Front Load Washer
Ice maker keeps making ice
hi thanks for the question it looks like the water valve is not shutting the water valve completely i would replace the water valve thanks the appliance doc
Sep 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Bosch shu5313 pump won't shut off
danimaldds there are 2 pumps in this dw, a drain pump and a circulation pump. If it is the drain pump that is running, look in the base under the machine. Remove the kick plate and see if there is water in the base. If so remove the water and see if the pump shuts down. If not look to the left side under the machine there is a red plastic stick, lift up on it with a wooden or plastic spoon. Do this a couple of times. It is possible the overfil float is stuck. If the circulation pump keeps running, then the control unit is the cause. Hope this helps
Aug 11, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
My Maytag Washer keeps running water and won't stop.
regardless of machine being on or not???sounds like a faulty water inlet valve youll need to replace the valve..
If the water level just overfills and floods over the top of washer but turns off when the unit is shut off, then it sounds like a bad fill switch.
May 10, 2008 | Washing Machines
Dishwashers Logo
135 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
