Question about GE Kitchen Ranges
We just moved into a house with the Profile PGB9755EM1SS and we don't have a manual. Is there somewhere we can get one?
    President:
  • 949 Answers
Here is a link to your manual. the second 5 in your model number is a letter 'S' I believe.
Use and Care manual
Posted on Aug 01, 2010
How do I turn off the gas to my gas light? I don't want to turn off the gas to my house, just to my light. I don't know where the shut off valve is on the light. I have no manual, the light came...
Somewhere there is a supply line to the gaslight. It could be coming from your gas meter outside and there will be a valve on it. I would start at the first place that you can see your gas line to the house. You will be looking for any tee or line coming out of the main gas line. You will have to follow all lines that you see to determine what device they serve: furnace, water heater, etc. If you find a line that you can't follow or that appears to go toward the gaslight, light the gaslight then shut the valve to be certain.
Gary
Sep 04, 2011 | Garden
I have a 1990 Mazeda Capella Profile automatic car which is mis firing as if there is a block somewhere in fuel line. Once I get to a decent speed on the open road it is better, but can be very jerky...
I have the same problem few days ago and found my solution on Fixya Expert Sources website. Here you will get all the top sources of your problem. All the sources of this site provided by top Fixya Gurus. Have a good look at the sources of the page. Go through the sources to find your solution. Hope it will help.
View Count:6
Aug 11, 2011 | Mazda 323 Cars & Trucks
GE profile Mod DPSR610G0WT dryer shuts off multiple times during drying cycle, need to wait about 5 mins, then restart; have partially dismantled to vacuum lint around drum and controls
you need to check the thermostats,, they have limits that are preset , The cycle selected determines which thermostat is used. A cycling thermostat can be found somewhere in the path of air that is leaving the drum. It could be found on the blower wheel housing or inside the venting/exhaust system. Dryer thermostats are usually oval shaped and about an inch and a half in length. Also, there should be two wires leading to each thermostat. Label these wires before you remove them so that you are able to correctly reconnect them later.Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. if you don't have a meter, consult someone with one or call a repairman
Jul 04, 2011 | GE Profile DPSB619ED Electric Dryer
Blower does not blow on profile dryer GE Profile dryer drum turns heats but does not dry
the clip that holds the fan on the back shaft of the motor may have broken so the fan isn't turning, check that , but first check the duct and make sure that you don't have a ball of lint clogging the vent,, also check the venting all the way out of the house,, clean the overhang of the outside vent cover, they get moist and collect lint
Jun 21, 2011 | GE Profile DPSB620GCWW Gas Dryer
The refrigerator (GE Profile) is not making ice
the water; for ice, as you know; goes via a 1/4 inch plastic hose from your house water supply; the hose enters you refrigerator at the back then: internally the hose enters a filter located usually on your model: down by the left side of the front bottom kickplate.
check to see if the water valve for house service is closed next check your water filter (turn the water off first) if this checks out: check the electric water valve in the icemaker.
Sep 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
I would like to buy or get a copy of the manual
just look up the Toshiba air conditioner web site, there should be a download there somewhere
May 02, 2009 | Heating & Cooling
Lost the manual
This site has manuals for download for a price.
http://manualfox.com/link/vivitar.htm
Paypal
Hope this helps
Apr 10, 2009 | Vivitar ViviCam 5386 Digital Camera
GE Profile JTP56 Electric Double Oven: Turn on Fan?
Fan is automatically controled by a thermostat.
Please don't bother rating, as anything but a Fix-Ya lowers my scorel. Thanks.
Mar 15, 2009 | GE Profile JTP56 Electric Double Oven
STEP BY STEP INSTRUCTION ON HOW TO USE A DISHWASHER
Try kitchen.manualsonline.com I found registering is free and easy and you can read your manual for free online. Hope this helps!
Jan 06, 2009 | GE 24 in. Profile PDW7800 Built-in...
Kitchen Ranges Logo
63 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
