Question about Frigidaire PLES389D Electric Kitchen Range
I have a model ples389ce one of the control knobs
I have a model ples389ce frigidare one of the control knobs for burner top large eye has came off it look it is broken in the controller that is built on front of oven is this assembly easy to install.Im fairly handy and dose anyone know part #
  • skippybayou5 Aug 05, 2010
    the controller that secures the knob is broken
    the kob is useable but the controller stem is the problem.
  • 11,896 Answers
This is fairly simple to install. You can pull of the panel, and dismount the control.
daysappliance . com and partselect . com has manuals and parts as well as diagrams.
Posted on Aug 05, 2010
  • 677 Answers
Hi,it's why easy to replace control knob for burner.
First get a replacement knob from any kitchen range store around you or from the particular company that made the frigidare you are using, contact the customer care service center for help on how to purchase parts from their company.
How to Replace Knobs on a Gas Stove.
The most common repair to a gas stove involves replacing the temperature control knobs. Do this when the knobs are sticking, making it difficult to use the burners, or when you can no longer read the temperature indicators on the dial. Most major appliance manufacturers have replacement knobs available for sale in hardware and home supply stores as well as through the manufacturer's own website, the best choice for an uncommon stove. Note the manufacturer and model number prior to shopping to ensure you obtain the correct knobs. Older stoves may require universal knobs made to fit any make and model.
Things You'll Need:
  • Pliers
  • Cleaning agent
  • Replacement knobs
Turn all burners to the off position before removing the old knobs. Grasp them with your fingers and pull to remove.
If the knobs are sticking due to an accumulation of food or grease, spray the base of the knob with window cleaner, oven cleaner or spray lubricant. Use the pair of pliers to grasp the knob at its base and pull off if it resists removal.
Take the replacement knobs and line them up with the stem. Push them on. In most cases, the knobs feature a D-shaped fitting and will only fit with proper alignment to the stem.
Pull out the rubber gasket around the stem to have the correct foundation for push-in style knobs, if necessary. Use the pliers to help with this task.
Test the knobs to ensure they access the ignition switch by turning each burner on. Adjust the gasket as necessary.
Tips & Warnings
  • Replacement knobs are available as original equipment manufacturer or universal parts depending on the age, make and model of your stove. Knobs for older or unusual brands of stoves will probably require the universal type.
  • If your replacement knobs came with a temperature indicator ring permanently attached, this will help you line up the knob with the stem; the "off" position on the ring will be the top of the knob.
  • Be careful when replacing knobs that you do not inadvertently turn on the ignition while you are working.
Good luck.
Posted on Aug 01, 2010
Ceramic stove top large element on high and won't shut off until turned all the way off
The range surface burner control switch, that the knob is attached to, needs to be replaced. The link is an example, as I don't know the model. They are mostly similar between manufacturers.
Range Surface Element Infinite Switch Part Number 3148952 SAME DAY SHIP...
Feb 03, 2016 | Frigidaire Kitchen Ranges
Frigidare FEFL79GSA burner stays on all the time even when you turn the knob to off,it still stays glowing on high.
you will need to replace the control for that burner, this is a very easy fix, locate the make, model and S/N for this unit order the correct control, turn off power or unplug unit , when you open up the unit where the control is watch what you are doing cause there are many wires here the way i do the wire change is to pull off one wire at a time putting the wire on the new control then when all wires are change over replace the switch
Oct 04, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Whirlpool electric range RF263LXTQ2- 2 yrs old-it gets so hot that the large burner pans are both charred black. Had it looked at about a year ago and couldn't find any problem-top and front of...
Since you are having problems with multiple elements the problem is probably the circuit board that controls them. This can be ordered and replaced. Be sure to unplug the stove before getting into the circuit board though.
Mar 13, 2017 | Whirlpool RF263LXTQ Range
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Hi, my GE glass top oven has a bridge burner that won't work.
the bridge burner is 99 percent chance that it is blown. turn the power off and take that burner out and see if you can see a break in the burner. then replace.
Nov 30, 2008 | GE Spectra JBP78 Electric Kitchen Range
Frigidaire PLES389D Electric Kitchen Range Logo
83 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
