Question about Minolta DiALTA Di520 Laser Printer
I have a Minolta Dialta Di520 that shows an error code of c-0110. The machine was working fine before being moved. It may have been bumped along the way. Also, the FN3 finishing unit is not connected at this time.
  • Minolta Master
  • 6,696 Answers
Image Transfer/Paper Separator Wire Cleaning Motor M8's failure
to turn · Faulty Transfer/Separator Wire Cleaning Home Position Sensor PC17
would be in the middle section, under the drum assy that has to very fine wires a device that looks like it would clean them, will the cleaning device is jammed or the motor that run it is jammed burned out, or the control board is bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Nov 21, 2015
SOURCE: minolta di520
es el pote fraSCO DEL TONER
AT THE TONER WHERE IS
Posted on Sep 30, 2008
kamal1984
  • 1383 Answers
SOURCE: I need driver for Windows xp for Minolta Dialta Di350
click here
you can downlaod install in computer
Thanks please let me know.
Posted on Jul 27, 2009
  • 1297 Answers
SOURCE: I REPLACED MY TONER COLLECTION Minolta d520
Press Utility key and press in this order STOP-0-STOP-0-0-1,select COUNTER windows,select waste toner windows: for SET press C(cancel 10 keys pad) introduction 320000; for Counter press C.press Exit too quit,back the basic menu.
Posted on Jul 30, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Hiam looking for laser unit for minolta dialta di
Precision Roller has them listed for $595.00 IF you sign up with an account as a service person which is easy to do. www.precisionroller.com
Just put "di181 laser" in the search box.
The part number in case you want to search elsewhere is 1177-0550-02
I have a couple of parts machines so holler back if non of this works out for you.
Thanks for using Fixya.
Posted on Jun 14, 2010
  • 1297 Answers
SOURCE: minolta dialta Di 470 donne code c 0210 puis
C210,transfer/separation corona malfunction.Change or clean the corona wire and the corona holders(white Assembly).
Posted on Jan 23, 2012
0500 error dialta cf 2002
open front door lay on your back look for the small hole on the right side touch the small switch with a screwdriver to reset the machine must be on
Jan 16, 2014 | Minolta DiALTA Di520 Laser Printer
Minolta DiALTA Di520 Laser Printer code 13f1
Replace the print head the device that houses the machine LASER, or the J or A printed circuit boards. Go with the LASER first if you can find one the Di520/620 are legacy machines from Minolta now Konica Minolta. Reset is Power off the Power on.
Jan 22, 2013 | Minolta DiALTA Di520 Laser Printer
My copier minolta 520 was not working error code c13f1
sir/mam Replace the print head the device that houses the machine LASER, or the "J" or "A" printed circuit boards. Go with the LASER first if you can find one the Di520/620 are legacy machines from Minolta now Konica Minolta. Reset is Power off the Power on.
Nov 18, 2012 | Minolta DiALTA Di520 Laser Printer
13f1 code problem
PRINTHEAD which houses the machine LASER is bad or the control board that control is bad. But number one is Check all connections between the both of them
Minolta di520 error code C0990
Large capacity draw bottom draw lift problem. gear might be bad or the cable snapped.
Aug 13, 2012 | Minolta DiALTA Di520 Laser Printer
In spanish por favor como puedo instalar fiery 620, en una fotocopiadora minolta dialta di520, en una Computadora con windows 7, para poder utilizar la función de impresión de la...
NO!!!!!!!!!!!!!!!!!!
Di620/520 is a legacy Minolta Machine NOW Konicaminolta, at best you can use Windows 95/xp try this web site Konicaminolta will show you. Self Help Product Support Konica Minolta Business Solutions Inc
Jan 12, 2011 | Minolta DiALTA Di520 Laser Printer
Hi, I have a printer Minolta DiAlta Di520, when i turn on the power swich apear the message : codice errore c-13f0 Can you help me? Thanks!!!
Print head is bad that is what houses the machine LASER or the J or A board is bad. check all connections to the print head first I would replace that first if you can find one, then go with the boards if you can find them.
Oct 06, 2010 | Minolta DiALTA Di520 Laser Printer
Feb 27, 2009 | Minolta DiALTA Di520 Laser Printer
Minolta di520
COF 34 is a code to refer T/C recovery failure as detected by ATDC sensor.Change ATDC sensor,if problem persist,change developer(starter) and then run F8 and F5 function operation in that order.Developer change every 1000000 copies.
Nov 08, 2008 | Minolta DiALTA Di520 Laser Printer
Minolta di520
Jul 17, 2008 | Minolta DiALTA Di520 Laser Printer
133 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
