Question about Motorola Mobility DCH3416 (160 GB) DTV Receiver Video Recorder
I have a DCH3416 comcast cable box. When i go
I have a DCH3416 comcast cable box. When i go from HD channel(720p) to standard channel(480p) it takes 4 to 5 sec to switch and same from standard to HD. Has anyone had this problem and why is it doing this? I had no problem with my other cable boxes. Is it a bad box or is this the norm with the DCH3416? Thanks!
My tv is a LCD 26in Samsung
Why is there sound but no picture?
According to the owner's manual page 2.7 (and this is an OLD [by HDTV standards] set), the TV can only handle input resolutions of 480p or 1080i on the composite inputs. Most HDTV programming today is 720p with some 1080i and 1080p on certain channels (like some Discovery shows about nature). It is possible that your set will not process the 720p signals being sent.
Nov 03, 2015 | Samsung TSL3294HF TV
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Hello could you please answer a question for me--is my 50gx49b hd compatable to watch hd channels-i just gotan hd box but the hd channels are all colors and lines -Thank You for your help Jim
change the hd output to 720p if that doesnt workt hen 480p othwerise your tv cant do it. if you are using hdmi try using component cables. also if you are using rca cables red white and yellow that is why
please let me know
Mar 17, 2011 | Hitachi 50GX49B 50" Rear Projection...
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
Two tvs off Motorola DCH3416
If you have different input options on your TVs, you could run the second TV with the Y, Pb,Pr component outputs along with the analog audio from the STB. However, remember the STB will only support ONE output video format. So both TV will have to be set to the same video format (720p, 1080i, 480p, etc)
Jun 20, 2009 | Arris DCT2608
HD feed problem
this tv can only process 480p and 1080i as hdtv signal. Check your motorola to see if it is outputing something like 720p....
Sep 17, 2008 | Philips 30PW850H 30" TV
Picture shifted to the lift
Press menu on remote and tab over to settings
Scroll down to tilt correction
Sep 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
HD channles
Hi Scan 1080: Enables you to receive the 1080i, 720p, 480p and 480i digital TV formats. By using the VIDEO 5/6 IN jacks, you can connect a DTV (digital television) receiver to view DTV programs. q DRC Multi-Function: Unlike conventional line doublers, the DRC feature doubles vertical and horizontal lines, resulting in four times the density for quality sources such as DVD, Satellite and Digital camcorder. q CineMotion: Using the 2-3 Pull-Down technology, the CineMotion feature allows you to obtain a smooth picture movement when playing back movies or other video sources on film. q Twin View: Using Multi-Image Driver (MID-X), Twin View allows you to watch two programs side by side with the ability to zoom in one picture and listen to selected window. You can watch pictures from two different sources (1080i, 720p, 480p or 480i) simultaneously. q 16:9 Enhancement: Vertical Compression technology that maximizes picture resolution on “anamorphic” or “enhanced for wide screen” sources, including selected DVDs. q Steady Sound: Equalizes volume levels so there is consistent output between programs and commercials. q Parental Control: V-Chip technology allows parents to block unsuitable programming for younger viewers. q Component Video Inputs: Offers the best video quality for DVD (480p, 480i) and Digital Set-top box (1080i, 720p, 480p, 480i) connections. q S-VIDEO Inputs: Provides a high-quality image for connected equipment. q Favorite Channel Preview: Preview up to eight favorite channels
Jun 02, 2008 | Sony KP-61HS20 TV
Picture shifts to left
I had the offset left issue for non-HD channels with my Panasonic 42" plasma, using Comcast HD cable box. Went into the configuration menu (to get there with the newer Comcast boxes, you have to turn the box off, then hit the menu button on the box immediately after). You will see on the menu a resolution (probably says 1080i), then below it a "4:3 override". Our said 480i. When I changed it to "none", so that it stayed 1080i, it worked! It also works by selecting 480p, but then the picture is stretched.
Mar 13, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Ilo 42" plasma tv
Go the the settings on the cable box. look for output resolution, then change it to 1080i and 720p. now turn the box off and back on your tv will now display the input of wither 1080i or 720p depending on the hd channel your watching.
Dec 26, 2007 | Televison & Video
Motorola Mobility DCH3416 (160 GB) DTV Receiver  Video Recorder Logo
230 people viewed this question
Top Motorola Mobility Televison & Video Experts
Marvin
Marvin
Are you a Motorola Mobility Televison and Video Expert? Answer questions, earn points and help others
