Question about Maytag Atlantis MDE7400AY Electric Dryer
How do you open the top? the padals inside the drum are coming loose
    President:
  • 1,554 Answers
The front panel needs to be removed first before the top cover can be lifted to the rear of the dryer to access the outside of the drum and re-tighten the screws attaching the baffles to the drum. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Posted on Aug 02, 2010
The things inside the drum are loose can they be replaced??
Wow, I've seen dryers with coins wedged in the space between the drum and the "speed bumps" but never very loose. It was always a chore to get the coins out, because it was so tight. I would open the top and check to see if the speed bumps can be tightened on the outside of the drum. If so roll it around slowly and tighten as you go. If your washer is not out of warranty I would have a Tech come and do the repair. To open the top is a little tricky, you have to get a thin blade, like a paint scrapper and slip it in the front right and left corners to open the inside latches. The easiest way to learn this is to do a YouTube search on how to repair your washer. there's lots of great videos there.
Feb 19, 2015 | Washing Machines
Zanussi washing machine
Open the door and grab the inside drum top and bottom, Wiggle back and forward, if it makes a knocking sound then either the bearings are worn or the drum has become detached from the bearing mount.
Mar 08, 2012 | Zanussi Washing Machines
The drum is moving front to back and making terrible noise
The retaining nut/bolt for the drum has come loose. Remove the back cover and check the drum axle and attachments.
Jan 21, 2011 | Frigidaire ATF6000ES Front Load Washer
Fins inside drumare loose
Open the top ... held down with spring clips ... remove the front panel ... probably 2 to 4 screws ... be careful of the wires ... unplug the machine of course. Remove the drum ... but first observe the belt arrangement so you can reinstall. Tighten the 'fins'. Reverse the procedure.
You can use a pry or large screw driver to pop the top. Be careful of the finish.
Mar 21, 2010 | Dryers
Loud noise that sounds like a train coming from drum
Check inside the drum for loose plastic bars that run front to back. You will need to release the top to tighten them if they exist. With top open, check the drive belt condition and replace it if it is cracked, pieces missing, or running loose. To release the belt, open a panel in back and release whatever creates tension in the belt (usually remove a large spring). With belt off, turn the drum by hand to check the rear bearing and whatever provides a bearing for the front edge of the drum--some dryers use plastic plates on the cabinet side for the drum to turn on, and others have actual rollers that the drum turns on. If rollers, check each one for missing pieces or warped surfaces of the rollers. If plates, check each one for wear through to the metal. Hope this helps.
Nov 17, 2009 | Computers & Internet
BAFFLE INSIDE THE DRUM IS LOOSE. HOW DO I TAKE FRONT OF CABINET OFF SO THAT I CAN GET TO OUTSIDE OF DRUM TO TIGHTEN SCREWS HOLDING BAFFLE?
Open the front door where you load the machine.
Look towards the top where the door normaly closes, there ususualy two screws that you can unscrew there.
Once loose the top pannel should come off, which allowes you to remove the front panel with 2 screws as well.
Nov 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Rattle inside dryer drum
remove the front cover and then you can access the top cover screws to open top then you can locate and tighten screws
Jul 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
Coupling loose
Dont know what you mean by coupling!!, usually the agitator comes loose on these machines inside the drum, to secure this, remove the softener cap in the centre of the drum by pulling, look inside and secure the bolt deep inside, you will need a socket and long extension 15mm I think.
Mar 12, 2009 | Admiral AW22 Top Load Washer
Maytag Atlantis MDE7400AY Electric Dryer Logo
596 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
