Question about Toro Co M/R Blwr/Trmmr Rear Bag Kit
Need plug gap for a weedeater plug NGK CS2 - Toro Co M/R Blwr/Trmmr Rear Bag Kit
What is the gap for spark plugs for fiat punto grande 1400
If it's an 8 valve engine and not the 16 valve:
Bosch Spark plugs have a gap of 0.8mm
NGK spark plugs need a gap of 0.9mm
16 Valve engines have a 0.9mm gap on each type of spark plug.
Mar 05, 2015 | Spark Plugs BR4HS Plug 10/BX #3322
Spark plug gap for 06VW Passat 3.6L
dude, so simple, go to any parts store or call, if you go in person and need plug gap info, it will say on the box, have the store guys give you the gap info, NGK has many different types of plugs for the 3.6 and each may require different gaps. The NGK spec for that motor is a gap of 0.043 in. for the IRIDIUM spark plugs.
Dec 09, 2014 | Cars & Trucks
I need the gap for a 2006 VW Passat 3.6 ngk...ILZKR7A
The vw ngk plugs are pre gapped. If you have a misfire it's more likely either a coil, bad fuel, or a faulty ecm.
I’m happy to help further over the phone at https://www.6ya.com/expert/stephen_3312f315a96e2956
Dec 09, 2014 | 2006 Volkswagen Passat
Ngk spark plugs gap chart
In your owners manual
Maybe under the hood on label
On all parts & plug mfg sites
They come gaped
NGK shows .052 I found it,need to use the internet better
Aug 17, 2014 | 2005 Mazda 3
NGK spark plugs are when new pre gaped .
if your using the old ones, gap them to be on the safe side 0.9 mm
Aug 02, 2014 | Ngk BKR5E-11 14mm x 5/8 Hex ISO Type...
Ngk spark plug gap for 2005 hummer h2
check Gap: .040
Bosch Spark Plug: Part Number: 18594-05120685
PLATINUM -- Original Equipment is Iridium. Gap is Preset
OE Fine Wire Platinum -- Do Not Gap, Gap is Preset
OE Fine Wire Iridium -- Do Not Gap, Gap is Preset
Sep 22, 2013 | Spark Plugs BR4HS Plug 10/BX #3322
Spark plug gap setting for 1995 Honda Shadow VLX 600
.031 - ,035 Ngk plugs come per gapped from the factory so you don't typically have to reset them.
Jun 20, 2012 | Ngk Spark Plugs DPR8EA9 #4929 SPARK PLUG...
What is the spark plug size and gap? ryobi weedeater 700r
The "Champion" spark plug for your item is #RDJ7Y
Or another brand, "NGK" #BPMR6F/130-769
You can set the gap to .020"
Hope this helps...
Sep 25, 2009 | Garden
Toro Co M/R Blwr/Trmmr Rear Bag Kit Logo
70 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
