Question about DeLonghi DDE40E Dehumidifier
What does an E3 reading mean? - DeLonghi DDE40E Dehumidifier
  • roy4619 Aug 03, 2010
    Aug 01, 2010
    - The unit does not continue working no matter how long I wait for it to defrost. How do I know the problem isn't the condenser assembly ($77.71), the condenser ($9.97) or the humidity sensor ($51.64). Thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. E3 error indicates that moisture sensor has failed and should be replaced. The cost to repair this will be around $300 including labor however, prior to replacing the part take the unit apart (only recommended if it’s out of warranty), then check the back of unit and take the filter off. Once this is done clean the sensor (moisture sensor) with a brush and blow some air with the help of hair dryer. There is another sensor which is pushed into a copper tube which is part of the cooling tube; you’ll need to clean this one the same way. All this is only recommended if you have some electrical expertise. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 03, 2010
  • 2,272 Answers
"E3" code the condensor sensor is bad.It has to be checked and replaced. E3 error message which apparently means the air is working and it has internal frost. It then stops cooling the air and waits for itself to defrost.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 01, 2010
  • roy4619 Aug 01, 2010
    The unit does not continue working no matter how long I wait for it to defrost. I have turned it off and will wait to see if that does anything. How do I know the problem isn't the condenser assembly ($77.71), the condenser ($9.97) or the humidity sensor ($51.64). Thanks.
I have a Blyss WDH316DC dehumidifier with E3 in display. What does this mean?
What E3 Means? This is simply an error code with your dehumidifier please.
It s not clear whether you can attempt to reset your unit or fix it on yoir own. So sorry about this.
It appears yoir unit requires repair by a qualified dehumidifier service technician.
You can exploit the warranty if this is still valid. Simply return to point of purchase with your original receipt
Nov 13, 2017 | Dehumidifiers
E 3 keeps showing
I'll need a make and model number for that.
Jul 04, 2014 | Dehumidifiers
An E 3 error code comes up and I don't have a manual to determine what the codes mean.
An E3 error code is a Sensor Shutdown Failure. You will need to contact Haier Customer Support for an explanation on which sensor it is and how to solve the problem.
Jul 11, 2011 | Haier DE65EA Dehumidifier
Our delonghi de400p dehumidifier shows an E3 error message. Customer Service says its a sensor but can't tell us what sensor. Any help would be appreciated.
I have a 40 pint and a 50 pint that are very similar. The 40 pint has the e3 error. Experimenting with the 50 pint, I found if I disconnected a particular sensor I got the e3 error. That sensor is a little can with two black wires (smaller than a AAA battery but shaped like that). It is attached to the cooling coils so must be a temperature sensor. This is not the little circuit board sensor mounted in the middle of the radiator in a plastic box/clip thing.
I am now about to see that part to see if I can replace it.
Jul 09, 2010 | DeLonghi DE400 Dehumidifier
My kenmore de-humidifier is giving me code e3.
E3 code on panel, dehumidifier will not start
May 10, 2009 | Dehumidifiers
DeLonghi dehummidifer de500p when i first plug it in comes on
DE500P does not run and shows error code E3. What part do I need to replace and where can I get it?
Mar 24, 2009 | DeLonghi DE500P Dehumidifier
Delonghi Dehumidifier DE500P - Code E3
Hi Thomast5263,
I live in NJ and the nearest center is in CT. So you can imagine that I am not gonna to ship my unit! :-)
The one I got is from Hartford, CT Utility Electric Service: 860-246-7271; talk to Dana and he is very helpful. They charged me $25 and shipped me the part and it now works fine.
When I talked to Dana he sounded pretty sure it was the condensor sensor. Simply call Dana and tell him that you have an "E3" code. I do NOT know the part number or ID.
Don't open the unit until you get the new part ---- it will help you to identify the part to be replaced. After you get the part, make sure you mark down all the screws (they are not the same! so pay attention which one is where). There are two tabs on the top so be careful when get them separate apart ---- don't force it or you might break it. The sensor itself is attached/stuck in between the copper coils under a black cover. Plug another end to the control board and you are done. Apparently there are two kinds of plug-in end ---- the first part Dana shipped to me did not match the old part so he has to send me another one which worked.
The whole procedure is not that difficult, but when you are doing this the first time you just need to be patient to locate all the screws and sparate the covers. From my experience you do need to take all covers off, otherwise you can not see the part and the wire.
Good luck to you and let me know the good news!
Oct 22, 2008 | DeLonghi DE500 Dehumidifier
Lost owners guide to delonghi dehumidifier de400p showing code of e3
I am searching for a resolution to the E3 code (same init) and happened upon this request. The manual can be downloaded from DeLonghi.com but that advises you to call the service center.
Tom C
Jun 04, 2008 | DeLonghi Dehumidifiers
E3 error
I got mine fixed tonight! It was not that easy but can be done.
After my last post, I called the customer service of DeLonghi. The agent can only refer me to the authorized repair shops but she does not know what “E3” meant. There is no shop in NJ where I live, and the closest one is in CT! One of the two shops there knows right away the E3 is the fault of a condenser sensor. He mailed me the part ($25) and I took the covers off (be very careful to record where the screws are from ---- they are not all the same size/shape, and also there are two small tabs on the top holding two cover pieces together, so don’t force it to open or you will break it). There is only one part looks like the same as the replacement part I newly obtained and it has a metal clip attached on the copper coils. Carefully replace the sensor on the coil as you find previously and plug the other end to the control board. It sounds lengthy but once you open the cover it will all become clear to you. Be patient and this can be done. Very glad to see/hear it is working now again!
p.s., the store first mailed me the wrong part (on the plug-in end it has two ridges rather than one) so I have to call them again to explain and they mailed me a different one with a single ridge. Apparently there are two types (old and new model) for this model.
Apr 26, 2008 | DeLonghi DE500 Dehumidifier
DeLonghi DDE40E Dehumidifier Logo
283 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
