Question about HP Pavilion dv9620us Dual-Core Mobile Technology TL-58/2048MB DDR2/240GB/17 WXGA+ High-Definition Br... PC Notebook
HP DV9500 has start problems.
I have a DV9500 that displays appropriate blue charge lights whenever it is plugged in. However, sometimes, when I try to start it, it won't do anything. I'll remove the cover around where the power button is and press in the actual target button manually with a mechanical pencil. But, it still won't start. Then, if I mess around with it, particularly the screws inside the battery mount; it may start back up find. Does anybody have a clue what is up with this? Or, what I need to do to remedy this issue?
    President:
  • 2,600 Answers
Here is a fun fact about this HP laptop....the keyboard want to be grounded before the laptop will fire up in certain situations. Make sure that the three screws are secure in the battery compartment that secure the keyboard and there is another screw inside the memory compartment that has to be secure. You can tell its the keyboard screws by the keyboard icon embossed in the plastic. Also the ribbon cable that carries the input signal tend to go bad in these, especially around the fragile ends. You can get these cables on ebay for under 7 bucks.
Posted on Aug 01, 2010
How do I solve a problem with starting up windows in my hp pavilion g6? Whenever I start windows a blue screen appears and the computer restarts.
Sounds like your hard drive has either failed, come disconnected, or someone performed a full format of the drive which wiped out the partitions or the boot sector of the drive. Worst case you will need to replace drive and purchase reinstall disk from hp. Best case you will only need to purchase reinstall disk from hp. If you do need a new drive, I recommend purchasing it from hp directly, as it will already be prepared with hps proprietary boot configuration files which must be present for hardware to be recognized by system bios.
Dec 31, 2016 | HP Computers & Internet
I have a laptop dv9500. The monitor is black and no bios or any sign of picture,nothing is on the screen just faint blue light. where is the problem?
The HP Pavilion dv9500 is one of the Pavilion dv9000 series of Notebook PC's.
This is the problem, and the possible solution,
http://www.youtube.com/watch?v=bnkQNmKauEc
(TIP: I would use a Heat Gun instead of a torch)
Dec 02, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
HOW TO FIX POWER MODULE PROBLEM ON hp pavillion dv9500. The power cord is ok, but the module must be broke because the blue light goes on and off depending on how how move the cord at the connection site....
yes thia is right,and these a electronics tech. area. try to go repair shop, to change-it. Dont try to replace, bacause you dont have necessary tools. there is 6 to 8 layer motherboard, normaly you damage the motherboard, if you try.
Jan 02, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
HP DV9500 screen blank, suspect graphics card gone. any way to check/test?
Can you try plugging some external monitor to a d-sub in the back and see if the picture is displayed properly on it?
Based on my experience with these issues, 90% of times it is caused by the malfunction in the laptop monitor and not the gfx card...
Kind regards,
Mark
Dec 26, 2009 | HP nVidia GeForce 8400 GS, DH PCI Express...
Hi, my DV9700 battery does not charge, adapter works but does not charge or run the computer on its own. I have had it checked and everything seems fine, they suggest the motherboard but I explained that...
This may sound stupid but try this, for some reason this seem to work on 6 and 9000 units with charging problems.
With the unit running, disconnect the battery and allow the unit to run for 60 seconds, then plug the battery back in, again with the unit running.
Nov 30, 2009 | HP Pavilion dv9500 dv9600 and dv9700 FF...
I have an HP Pavillion dv9500 laptop. After shutting down, all the keyboard lights to the right of the power button stay lit. This shows the power is not shut off but should be. Any solutions?
First of all, is the laptop on charge? Usually when the laptop is on charge there is a light somewhere that remains on until it is charged. After charging, the light goes of and if the laptop is not used for a long time, the battery usually discharges a little and the system senses this and recharges it as top-up and the light comes on, then goes off once charged. If your laptop is not on charge, then there is 2 things that could be the cause. 1) It is not shut down properly (on stand-by). 2) It may be downloading updates and it would probably shut down later, depending on the size of the update, it may take a few minutes or up to 1 hour. If in 1 hour the light is still on, then there is a problem with the laptop and need to be checked by a professional, or, altermnatively, turn it off a second time and see if the light still remains on. Lastly, you did not state what kind of lights remain on, Power, Charging, Standby, etc. it is difficult to help you with your query as the problem could be the laptop itself. There are other things that could keep the laptop on, and that may be if your laptop is connected to a network. Regards.
Sep 27, 2009 | Computers & Internet
Nvidia graphic driver problem
Sir,
This is the problem with XP. Your nvidia graphic drivers is not supported by XP. So go to manufacturer's website and download the appropriate driver for XP.
Thanks
Good Luck
Aug 17, 2009 | HP Pavilion dv9500 dv9600 and dv9700 FF...
HP Dv9500 not charging battery
Sounds like the AC port is faulty, these can be a real pain to get hold of replacements and a complete nightmare to replace if you are not very experienced with a solder iron! my advice would be take it to your local computer centre to have the port replaced but expect to pay around £70. if you do attempt to do this yourself you will need solder wick to soak up the solder holding the port in, a very steady hand and time.
Jul 02, 2009 | HP Computers & Internet
HP Pavilion dv9500t Vertical Line Issue
try connecting an external monitor to the unit. if you get the same or similar issues on the external monitor then you have a GPU issue on the motherboard. It will need to be REFLOWED or replaced. If you do not get the same issue on your external monitor, then you need to replace your LCD. Our shop replaces these LCDs for 140-180 so i imagine you should be able to find something similar in your area!
Good Luck!
Ruben
Dec 18, 2008 | HP Pavilion DV9500T Notebook
HP Pavilion dv9620us Dual-Core Mobile Technology TL-58/2048MB DDR2/240GB/17 WXGA+ High-Definition Br...  PC Notebook Logo
179 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
