AFTER 10 MIN OF TURNING THE HEATER ON OUR POWER OUTLET TURNS OFF WHAT COULD BE THE PROBLEM?
    Problem Solver:
  • 18 Answers
Not knowing what kind of heater this is, I will assume that you are referring to a small plug in 110 volt room heater since you mention power outlet. Check the amp rating of your heater verses the breaker. Remember if it is a wall plug that there are other plugs on the same breaker. Breakers work two ways, as an over current (amps) and thermal protection (heat). It could range from too close of a current draw for the breaker and heating it up or a loose wiring connection at the breaker or wall plug. Loose could also be the problem for a central unit. After it runs a while place your finger on the front of the breaker to see if it feels hot, it should not get warm
Posted on Apr 25, 2008
What is defrost overheat?
There is defrost heater which comes on in defrost cycle. defrost heater stays on certain time(lets say 15 min), but lets think it came on to defrost and melted all ice of the coils during 5 min, but we still have 10 more min design for heater to stay on. if heater will stay another 10 min it will warm up your stuff in the freezer, so everything will start to melt. to get around this, all freezers have limit thermostat(defrost thermostat), when that thermostat feels heat from heater, it will shut power off to the heater, so it still in defrost cycle, but heater will be off for another 10 min. When that thermostat get stuck in closed position(does not shut power to the heater when all ice melted out), you will have defrost overheat. so most likely that defrost thermostat needs to be replaced. here is the video how i replaced it on subzero pro series.
Apr 07, 2014 | Sub-Zero 650/SRH Stainless Steel
My pump pressure will not adjust down...no matter how much I back out the screw....What could be my problem
WHAT TYPE OF HEATER BRAND & MODEL#? ARE YOU CHECKING INLET OR OUTLET PRESSURE AT GAS VALVE? IF IT CALLS FOR 3.4LBS. IT'S A NATURAL GAS UNIT CORRECT?
Dec 24, 2012 | Heating & Cooling
Seiki tv keeps turning off how do I fix it
try plugging your tv directly to the wall outlet and bypassing your power strip. let me know if this helps !
Jun 13, 2012 | Televison & Video
My phillips 51pp9100d wont powerer on, the powrer button blinks nine times thats it
Try turning the power on using both the remote and the power button on the front of the set. if the set turns on using the power button on the front of the set, there is a problem with your remote.
If the set turns on using the remote but not the POWER button on the front of the set you may
If the LED light on the front of the set blinks but does not turn on when you press the POWER button on the remote or front of the set If the LED light does not blink when you press the POWER button try unplugging the set from the power outlet for 10 seconds. You should also try plugging a lamp or other electrical appliance into the outlet to make sure there is not a problem with the outlet. Sometimes an electrostatic discharge may cause the set to lock up and disconnecting the power resets the set. If problem persist, If using a surge protector, try plugging the set directly into the wall outlet. An electrostatic discharge could have tripped the breaker in the surge protector.
Sep 01, 2011 | Televison & Video
When you switch the TV set on, the picture comes up for a second or two then the set turns it's self off onto standby
It sounds like you have a power / short issue. You will probably have to get it looked at and serviced, but you could try plugging it into another power outlet in the house, but first leave it unplugged for about 10 min.
Chris
Aug 15, 2011 | Computers & Internet
1993 pontiac sunfire turns over but wont start.I can hear fuel pump working? help!!
This works for a 96-98 grand am for sure. Maybe help ou out? You could try resetting the computer. The car maybe in lockout mode. Try turning your car over….leave the ignition on. Wait exactly 10 min. Then try turning over again….again leave the key on. Wait exactly 10 min and do it a third time….this time the car should start…maybe run a lil rough while it relearns the processes of your vehicle again. It is important to wait the exact 10 min each time. You will probably need a battery charger or a set of jumper cables because if your car goes low during this process it will not work. Good luck and I hope this works.
Mar 30, 2010 | 1993 Pontiac Sunbird
My car want start it turns over but want start
Mar 27, 2010 | 1994 Pontiac Grand Am
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
GE D52GW12 turns off
I have the same problem, what the heck. it's over for it
Jun 09, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
