Question about Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A
Freezer is constantly running and sides seem to be caving in on outside
We purchased a used 1998 upright freezer (auto defrost) and as far as we can tell it has been running since we plugged it in 1 month ago. Now when we look at it it seems the sides are being sucked in/caved in 1/2 inch. We have the freezer in our basement in a tight spot with only an inch clearance on the sides and 6 inches in the back. Unfortuately after we bought it we noticed that it said "3 inches of clearance must be provided on all sides of freezer for air circulation" Could this have anything to do with it? It is keeping the food frozen. It does not have coils in the shelves; are they in the walls, like a deep freezer? The refrigeration lines in the back seem to be very frosted.
This morning we pulled it out from the tight spot and unplugged it for half a day. After plugging it back in, it is inconclusive as to whether this is helping. We did hear it go on and off once today.
Thanks!
  • 36 Answers
Most likely there is a defect in the coolant system, you might want to get a repair man to help. What i think is happening is water is getting in the sides and when it expands/ contracts it causes the sides to cave in.
Posted on Apr 25, 2008
Why are the sides of my frostfree freezer so hot?
check to see if you have a fan down by the compressor if so make sure it is running. if no fan you are starting to loose freon
Jul 25, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
My Fridgidaire upright Gallery freezer is freezing my food but the appliance seems to be constantly running and the temperature control on the outside is reading 29 Celsius when it obviously isn't
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Nov 22, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
After loading freezer a loud buzzing sound started
Is it coming from inside the freezer or outside? If outside either the auto defrost timer is a problem. If the noise comes from the compressor, almost certainly the starter relay inside the electrical cover needs to be replaced. It can be purchased at most refrigeration outlets. If coming from inside, you need to defrost the freezer properly for 12 hours then restart. The noise should go away then.
Jun 12, 2011 | Whirlpool 19.6 cu. ft. Upright Freezer...
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Upright freezer not cold enough
IF THE FREEZER IS AUTO DEFROST, DO YOU SEE A FROST BUILDUP ON THE BACK WALL? IF SO, YOU NEED TO DIAGNOSE THE DEFROST FAILURE. THERE ARE THREE ITEMS TO THE DEFROST CIRCUIT. THE TIMER, HEATER, AND BI-METAL. FIND THE TIMER, USUALLY ON THE BACK OF THE FREEZER DOWN IN THE CORNER NEAR THE COMPRESSOR. IT WILL HAVE A CONNECTOR WITH FOUR WIRES ATTACHED TO IT. IT HAS A KNOB THAT CAN BE TURNED TO PUT IT INTO A DEFROST CYCLE. WITH THE FREEZER RUNNING, START TURNING THE KNOB UNTIL THE COMPRESSOR STOPS. THAT WILL BE THE DEFROST CYCLE. THEN WAIT 5 MINUTES AND LISTEN IN THE FREEZER FOR A SIZZLING NOISE AND LOOK FOR A GLOWING FROM THE BACK BOTTOM. IF THE HEATER IS ON, THE TIMER IS THE PROBLEM. IF THE HEATER IS NOT ON, THE HEATER OR BI-METAL IS AT FAULT.
IF THE FREEZER IS NOT AUTO DEFROSTING, CHECK TO SEE IF THE COMPRESSOR IS RUNNING. IF IT IS, ARE THE SHELVES ALL FROSTED? IF NOT, YOU HAVE A SYSTEM FAILURE. IT COULD BE A LEAK, RESTRICTION, OR FAILED COMPRESSOR.
Apr 02, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Freezer is running constantly and sides and top are hot.
first whirlpool makes a good product as far as the sides being hot good sign the condensing coils are in the sides are supposed to be hot worry if its running and they are cold then not working right ok as far as running modern units useing 134a do have long run times but are not using but same enegry as 100watt light bulb otay
Dec 30, 2007 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A Logo
207 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
