Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have a fan left over in reassembly. It is attached to a 90 degree flat perforated piece that has to go somewhere on the chassis. But I am totally stumped. I would attach a photo but I don't know how.
  • joetom27 Aug 01, 2010
    Here is a photo for what I am trying to find a home.
  • 8,197 Answers
On service manual link below has a picture of the fans. Fans are on pages 11, 13-14, 15,
http://www.techlore.com/downloads/file/7714/Mitsubishi_WD52525,_62525,_52725,_62725,_52825,_62825.pdf
Good Luck
Posted on Aug 01, 2010
  • 2 more comments
    This is what I need to know. I have the manual. Where does this go ?
  • Jyackle5
    Jyackle5 Aug 01, 2010
    Look On page 9 of the link above. The link above Is the service manual and it shows you all the parts inside the TV
  • Jyackle5
    Would like to know why you gave me a 2 thumb ratting when I gave you pictures of the inside of the TV. If that is not the right TV then can I get the righ make and model # to help you more.
    I gave you no rating. I wanted more info from you. This still is a problem. I have the manual, the service manual, and I do not know how this part attaches. It is nearly impossible to slide the chassis into place as it is. So if this goes on the chassis, how does it go ??
    Thanks for your help.
    Genius:
  • 1,112 Answers
Hi this fan and assembly sounds like the exhaust fan and duck, it is usually located on the right hand side of the chassis looking at it form the back.
  • Lavell Turner
    Lavell Turner Aug 01, 2010
    Sorry Joe I am not seeing you photo.
I had the coolant refilled and now the compressor fans are not working
radiator fan only working when the coolant temp over 90 degree check coolant temp on your instrument display using multifunction switch left side group on steering wheel get it hot over 90 degree and have a look is the fan working or not if not check fuse for radiator suction fan fuse chart in boot on the spare wheel with tools and fuse .
Sep 02, 2010 | 2001 Mercedes-Benz S-Class
I have a fan piece left over from reassembly. the fan is mounted on a bent 90 degree piece of metal that is perforated and probably goes on the chassis somewhere. I am stumped. Here is the piece
HI Joe, The piece you are referring to slides into the top of the chassis. if you are sitting in back of the television and the chassis is removed, the piece with the fan slides in from the top. The perforated piece slides in between the left support bracket and signal board. The fan will cover the top of the signal board, DM module and Fmt board. Once it is in place you will then plug in the usb and firewire cable at the top of the chassis. The connector for that fan is connected to the wire harness that is coming from the chassis near the dvi connection. Does this help?
Aug 01, 2010 | Televison & Video
I would like to know hao to get the manual on a fedder aeqo72bg. My ac started aknocking noise 2 days ago. it sounds like a fan belt is going and I would like to know if they even have belts?
The blower is direct drive. What has happened most likely is the blower fan center hub has most likely cracked. That results in the fan tipping as it rotates and starts dragging on the Styro-foam ait ducting... or the rear condensor fan fails (very rare) and is dragging on the plastic air shroud.
To gain access to the blower fan you must remove the AC from its mounting by removing the center bottom earthquake mount and sliding the unit out of the outer chassis.
Unless you want to make a mess you should use a wet or dry vac and remove all of the water and debris from the chassis tray.
Set 2 blocks of wood equal size at least 18 inches long about 24 inches apart on the ground and rest the airconditioner on the wood.
To gain access to the blower fan you must remove the UPPER Styro-foam air shroud. This is accomplished by removing the 2 screws and bracket between the fan motor chassis bulkhead and the condenser air shroud. Some models also have 1 more screw and bracket on the top right front of the upper Styro-foam shroud.
Now check to see if the front blower fan teeters on the motor shaft or feels loose onthe motor shaft. (my bet is yes)
To change the blower you will need to follow the steps below.
You will have to remove the 4 screws in the condensor fan air shroud on the fan motor side of the condenser. Next you will need to remove the control box and disconnect both the compressor and the fan motor from the control assy. There are at least 3 screws in the control box enclosure and you must remove them all. One of the screws has the power ground attached to the chassis. MAKE A personalized DIAGRAM especially if there are terminals vs connector plugs. Also make sure to ground the run capacitor with a screw driver several times to remove any residual charge BEFORE removing termnals. (Diagram Capacitor also!) Then remove all of the screws for the air box chassis including the rear screw under the motor. There should be at least 5 screws on the rear bottom of air box metal chassis with one of them having the blower motor ground under the head. Remove the 4 screws on the sides (2 per side) of the air box chassis. WAIT... there are 4 more screws on the left side of the evaporator coils that need removed. 2 on the air shroud chassis and 2 on the evaporator assy. Then slide out the metal piece between the air shroud and the evaporator. NOW you can lift out the blower motor with both fans attached.
Removal of either fan is accomplished by squeezing the mounting clamp and sliding the fan off the motor shaft.
If you so any coil cleaning DO NOT spray the coils from an angle it will bend the coil fins. Spray straight on with a semi diffused spray pattern. It will take much longer than you would think to clean the coils.
Reassemble in reverse order.
Thanks for using Fixya.
Kelly
Jun 19, 2010 | Fedders AEQ07F2BG Air Conditioner
My screen has rotated how do i switch it back?
You didn't mention by what degree has it rotated, Is it a 90 degree rotation or a complete 180 degree rotation. Anyways here's the solution to your problem.
Hold down Ctrl+ Alt and then press the Up or the Down arrow key to rotate it by 180 degrees.
OR
Hold down Ctrl+ Alt and then press the left or the right arrow key to rotate it by 90 degrees.
Nov 16, 2009 | Samsung NC10-14GW Notebook
Rearview mirror repair-The mirror just came off in my hand yesterday, leaving a circle of black film attached to the glass. In the past, I've repaired one with a small metal piece that hold the entire...
The small metal piece is just glued to the glass , and is probably still in the mirror assembly. You can buy the "special " glue at any auto parts store.
Glue the metal piece on , then after it has fully dried you can slide the mirror back on.
Nov 08, 2009 | 2002 Audi A4
1. calculation for excel spreadsheet macro for calculating the a right angle triangles hypotinuse and opposite side, angle given
Hello this is Baris,
First off all when you say hypotinuse I think it is a 90 Degree triangle. Total of the angles off a triangle is 180 degree. So it is a simple algebra question.
Hypotinuse is 90
Right angle is R
Left angle is L
Total is 180
Equation is 90+ R +L = 180
We are looking for R, so lets arrange our equation.
R= 180 - 90 - L
R= 90 - L
This is our formula for excel
Lets put it in the excel
Type in A1 "hypotinuse "
Type in A2 "Left Angle"
Type in A3 "Right Angle"
Type in B1 90
Type in B2 "whatever the value given for the left angle"
Type in B3 =90-B2
As soon as you change the value in the cell B2, B3 will change by itself. Hope this helps :)
Sep 27, 2009 | Microsoft Excel for PC
My Royal SovereignARP-3012 lower blower fan wheel broke
This is a difficult repair and no easy cake at all. The one internal part you can order from Royal Sovereign is the lower blower wheel. Perhaps this is because it breaks easily. Begin by draining the unit by removing the rubber plug at lower left. Remove 14 (count them) from the back. Remove additional positioning screws that hold the case side to the metal frame. Take out the two screws on the underside of the outer casing. Unclip the plastic tie that holds a temperature sensor to the rear radiator, and remove the the sensor gently. Spread the casing gently apart and push it away from the chassis a few inches. Reach into the front and unplug the three electronic connectors that link the display panel to the chassis. Note that the two leads that go to the lower part of the chassis go into positions 1 and 3 - the middle connector is not used. Now remove the casing entirely. Take a photo on all sides for reference and get some masking tape ready. You will see an upper blower casing and a lower blower casing, around which are arranged the condenser and two radiators, held in place by four press-formed metal chassis frames and two plastic chassis supports. Do not proceed until you mark where all the screws into the metal supports go. Failure to do this may end up with putting chassis support screws into holes meant for the back panel, making it impossible to reassemble the outer casing. Remove the grounding wire on the right side facing the rear. Tape the screws to the chassis part and note the color of the leads. Mark the location of the screw so you do not put it in wrong place on re-assembly. Do the same with the double green and yellow wires connected to the other side. Disassemble the bracket holding the white metal electrical condenser, noting carefully how the bracket is designed to clamp the condenser in place. Remove all the screws holding all four corner chassis supports, and mark exactly where the screws go. Stick these screws to a piece of tape and label it. Remove all screws holding the upper plastic chassis frame, marking screw locations carefully. Note that some of these screws hold the upper blower casing in place. Stick these screws to another piece of tape and label it. Working from the rear, and using a long phillips head screwdriver, remove two screws that hold the base of the upper blower assembly. Check gently to see if the assembly is now loosened and can be lifted but do not lift it yet. Remove any other screws that impede. Remove the uper chassis support carefully. This is a tricky move, take your time. Remove the tape that holds wiring on the middle plastic chassis support member and put it somewhere you can get it again, you will need it on reassembly. Once the upper blower assembly is removable, lift it EXACTLY vertically to clear the cleats at the base, then carefully rotate it towards you and place it upside down in front of the unit. There is just enough wire to allow you to do this. Remove and tape screws as needed to liberate the middle chassis support member. Remove and tape the two screws that hold the lower blower casing to the deck chassis support. This is where it gets tricky. Remove the middle chassis support but be very careful to support the upper radiator as you do so. Remove and record the location of any other screws that hold the lower blower casing. Tip the upper radiator as little as possible to allow the lower blower casing to be lifted up out of the chassis floor, and out to the side. tis is a difficult move and it is easy to damage the fins of the radiators. Remove the front of the lower blower casing, and remove the blown-up old wheel. Put the new blower wheel onto the motor shaft and make DAMN sure the nut is on tight. Otherwise the wheel will slowly travel up the shaft, rub against the radiator in front and you will have to do it all over again. Reassemble in reverse order. When you re-connect the wiring of the outer casing, be sure to connect the lower wires in front into positions 1 and 3, leaving the center blade open. You will be glad you recorded the exact location of every screw, trust me. It took me seven days to figure this out, even after worming out the service manual and an exploded view from the company (both useless for this repair except for debugging misplaced electrical connections). Easy cake indeed.
Jun 04, 2009 | Royal Sovereign ARP-3012 Air Conditioner
HP d530 PC - SATA Harddisk - Chassis does not close any more
Martin,
They make SATA cables with a 90 degree connection on one end.
Hopefully this will solve your clearance problems with your case.
Here is a link to website that carries these.
Website Link
They work great and fit tight against the drive.
Hope this helps,
Eric
Jan 18, 2009 | HP Compaq d530 PC Desktop
Bad fan motor on DH504ELY5?
problem fixed with the fan motor not running.
heres how i did it for anyone who experiences the same problem
1.) open back of unit(6 screws and pop tabs)
2.) with back cover open youll have access to compressor and fan-locate the blower assembly and remove the nut on it i used a 3/8 wrench from dollartree and rotated the blower fan while turning-its plastic be careful and remember righty tighty lefty loosey)
3.) with fan assembly off youll see the motor with 2 phillips head screws-taking these screws out with a power screwdriver allows the bearing assembly closest to the fan assembly,shaft,armeture and motor assembly to come out leaving rear bearing assembly attached to chassis
4.) once the motor assembly is completely out gently rest it against the fan hole and cut the silver tape being careful to ONLY cut the silver tape and the first white tape strip.
5.) youll see 3 wires and some insulator sleeves covering them leave everything alone except the ORANGE wire this wire attaches to the thermal fuse than to the windings
CAREFULLY heat up your soldering iron and remove the orange to thermal fuse connection than carefully thermal fuse to windings its a bit of a pain but can be done with patience
6.) remove original thermal fuse noting EXACTLY where original is placed on windings-it will have a small tape strip on it. replace it with one of EXACT OR NEAR THERMAL RATINGS a good choice is radioshack 270-1322. this thermal fuse is ratyed 10 amps max. but remember thermal fuses go by degree of heat and not by amp rating unless the amperage is in excess to melt the thermal material inside-my original fuse was 2 amps and 130 degrees celcius new fuse was 129degrees but plus minus 2 degrees so its a good choice and costs under 2 dollars
7.) place a heatsink clip or needlenose pliers between thermal fuse and solder connections BEFORE YOU SOLDER IT IN PLACE this prevents your 700 degree f iron from melting the fuse(remember its thermal not amperage were talking about here)
solder orange to thermal fuse with plastic extension than flat end to winding wire exactly opposite of how removed
8.) tape fuse in ORIGINAL LOCATION AS OLD FUSE i used scotch tape,place the thermal white protector piece on orange to fuse wire and push everything back down in original places-there should be no contact with any other wires etc. it will cause a fire
9.) once fuse is in place push tape you cut earlier back on and put 2 or 3 small scotch tape pieces of good length to secure the innards, lube the rear bearing of motor using vasoline- a few dollups will do it do the same for front slide motor winding assembly holding it in place than replace armeture with front bearing attaches as they came out secure the 2 screws back in place, put fan blade assembly back on(its keyed) secure nut and reassemble back
if you did everything correctly it will work like new just remember this time CLEAN YOUR FILTER SCREEN REGULARILY lol its critical for proper fan cooling
that should do it:)
Aug 20, 2008 | Goldstar DH504EL Dehumidifier
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
