Question about HP Photosmart 7450 InkJet Printer
How do i check how much ink left thank you - HP Photosmart 7450 InkJet Printer
    Brigadier General:
  • 10,406 Answers
Click Start
Click Control Panel
Click Printers
Right-mouse click on the HP Printer
Click Properties
Use the HP Toolbox software to "show ink levels".
Posted on Aug 02, 2010
Hi. Our 8560MFP has come up with the error code 07,010.43:93096, plus the message "power down error - head not parked" - is this something we could look at ourselves or do we need professional...
7,010.43 Printhead is stuck or is not tilting properly over the cam.
Initial Actions
• Check that the Process Drive gear train is properly homed.
• Check for obstructions or ink spills around the Printhead.
• Verify the Printhead travels smoothly from left to right.
• Check the Printhead Restraint Arms.
• If the problem persists, follow the procedure below.
Table 1 7,010.4x through 7,015.4x Troubleshooting Reference Table
Applicable Parts Wiring and Plug/Jack References
Process Drive, PL 4.0 Right Side Harness / I/O Control, Figure 8
Head Tilt Solenoid, PL 4.0 Left Side Harness (2/2), Figure 5
Head Tilt Gear, PL 4.0
Restraint Arms, PL 2.0
Head Maintenance Clutch, PL 4.0 I/O Board (2/2), Figure 10
Table 2 Printhead Restraint Fault 7,010.xx through 7,015.xx Troubleshooting Procedure
Step Questions or Actions Yes No
1 Reboot the system.Does the error persist? Go to Step 2. Complete.
2 Check the Printhead Lock Arms. Go to Step 3. Repair or replace Do the arms rotate correctly? the Printhead Restraints
3 Check for ink spills around the Printhead Go to Step 4. Remove ink spills or obstructions.
and Printhead Tilt Gears. The Printhead
should move when pushed left or right.
Is the area around the Printhead clean
and unobstructed?
obstructions.
Jul 04, 2011 | Xerox Phaser 8560MFP Laser Printer
How do I know how much ink is left in my c3135 printer
Welcome to Fixya.
Here's how to determine the ink levels for your inkjet printer :
HPC3135 Ink Level check
Please see my additional reminders :
  • If the printing quality diminishes, it's a good time to check your ink levels.
  • Change your cartridge often for good printing quality.
  • If you refill the cartridge, the ink level indicator may not be accurate.
  • Don't wait until the last minute to change your cartridge.
Thanks for using Fixya.
Jun 05, 2011 | HP Photosmart C3135 All-In-One InkJet...
Hi Folks: I would appreciate any help and suggestions: HP DesignJet 1055CM error 0A0020 006501D1 Thanks, Paul
"Error in calibrating the APS sensor"
APS= Air Pressure System - it provides air pressure to pump in to the ink cartridges, thus pumping ink to the printheads through the ink tubes.
First things to try
- Remove all Ink cartridges.
- Power down printer.
- Power on.
- Place cartridges in ink supply station, check if they are recognized.
- Replace the one cartridge that is almost empty.
- Check all cables and air tubes in the ink supply station. (you need to remove left cover of printer)
Make sure they are all properly connected and not damaged.
Make sure the air tubes are free running - NOT pinched or bent!
- Lastly,
When all above fails, replace faulty APS sensor and / or pressure valve.
Oct 30, 2010 | Computers & Internet
Cx6600- I have run nozzle check, changed ink and run head cleaner, re run nozzle check but the paper continues to run through the machine without printing. Can you help? Thank you.
try to reseat the ink cartridges, meaning take it out of the printer then out it back,
press set up, press the top left button until you see replace ink, press the color button. take out the inks and return it. close the cartridge cover
Feb 11, 2010 | Epson Stylus CX6600 All-In-One InkJet...
How do I check levels of ink on my HP Photosmart c6300 all in one. Thank You CJ
There are two ways to do this:
Method 1 Check the back of your computer to make sure that the printer is appropriately connected to the computer and is plugged in. If the printer is not plugged into the computer, find the printer jack on the back of the computer and plug it in before you move on to the next step.Click on the "Start" menu button which is located on bottom left hand corner of your screen. Click on the "Settings" bar and notice that a list of functions pop up to the left of the settings button. Click on the control panel icon.Look for the printer/fax icon in the control panel window. Double click on the printer icon.Find the icon for your printer in the opened window and right click on the icon. Now click on the "Preferences" option.Look for the menu box pop up with tabs near the top of the box. Click on the "Services" tab.Click on "Service this device." You will find the button on the Services menu that you just activated.Click on the estimated ink level tab and a graphic will appear indicating how much ink is left in the cartridge.OR Method 2 Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Figure 1: Estimated ink levelsc00677193.gif
Dec 24, 2008 | Computers & Internet
How do i check ink supply left in cartridges
Hi there
Thanks for posting your problem on fixya
the cartridge will be seen moving left and right whenever you take any print out... just open the flap you will see the cartridge.. try to pull out slowly some printers doesnt have flaps..in such cases just put your hand inside the printer and try to pull it out. Take out your cartridge and see the ink level if your has ink it means your ink supply is correct otherwise refill it
Is this solution helps you then please vote for me
Thanks
Robert
Sep 26, 2008 | HP Office Equipment & Supplies
3 issues, Will not print black but says still ink, now page shows amt gone and cannot find the ink when I open it.
Here are several documents that i want you to check to somehow solve the issue.
Step one: CLEANING THE INK CARTRIDGE: DOCUMENT
Step two: Checking Ink level : DOCUMENT
Setp three: Try replacing the BLACK INK CARTRIDGE.
adonscott
Jun 28, 2008 | HP Photosmart C3180 All-In-One InkJet...
Faded left hand copies
Pleas check that you inserted the K toner correctly, check, that transfer belt and/or drum cartridge is installed correctli. also check that 2transfer roller, its one big black roller.
Jan 23, 2008 | Konica Minolta magicolor 2400 Laser...
HP Photosmart 7450 InkJet Printer Logo
254 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
