Question about Whirlpool Refrigerators
Icemaker not workin water dispenser is working fine
    President:
  • 1,099 Answers
Looks like your fridge is not very old. Common problem is a clog inside the ice maker. It's a pain to do, probably easyer to get it fixed unless you have a long time to wait for a service call or live in an area without service. Anyway clog is most likely about an inch from the in take line inside the ice maker.
Take out the ice maker or turn off the freezer untill it thaw's then use a tooth pick or THIN ice pick to push the clog through to the actual freezing tray, wash out the tray and re start the ice maker.
Good luck....
Posted on Aug 01, 2010
What this can be?
On the rear of the refrigerator, there is a water control valve, that controls the flow of water to the icemaker and the water dispenser, if equipped. Hard water is usually the cause for this to quit running. The icemaker and water dispenser, are two separate circuits, and each one has it's own water control valve.
Mar 13, 2015 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
The water isnt getting thru to the icemaker, i have used a hairdryer on the water valve and still nothing , i even changed out the water valve but alas no water is being pumped thru to the icemaker, what...
Does water dispense through the dispenser ok in the door dispenser??
If yes wate r dispenses through the door ok the problem is going to be with the icemaker itself and its not sending power to the water valve when its supposed to fill so it could make the ice
If water doesnt dispense through the door check that water pressure into valve is sufficent..even if water does dispense what seems to be ok check first that thier is good water pressure into the valve before replacing icemaker
GENE
Sep 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Automatic icemaker stopped working yesterday. No problems before that. Arm is down, no problem with water line, (water still works in dispenser) temp is fine.
there are two solenoids that control water input. One foe the dispenser and one for the icemaker.Its called a double valve
and you have to replace both. even tho the dispenser is working.
Check ice tray for water if it has none pour it full and wait to see if it ejects after it freezes if it does then you probably need th double valve replaced if it don't then probably icemaker replacement
Aug 24, 2010 | Maytag Refrigerators
Icemaker works but water doesn't dispense. I have
I think our water will dispense but our tab(arm) came off track and we don't know how to put it back on. Our icemaker works fine but can't see how the arm should be on. Let me know if you have any advice. Thanks, Shelby ~ Ohio
Feb 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker/water dispenser not working.
Just had to defrost the water tank inside the fridge for a few minutes. Using a waterproof heating pad with extension cord did the trick. Even a fridge needs a warm blanket from time to time.
Oct 21, 2009 | Jenn-Air JFC2089HE French Door...
Jenn-air side-by-side water dispenser leak
Check the fill tube to your icemaker and see if it has ice in it or in the fill cup to the icemaker. Most of the time when this problem happens it is the icemaker spraying the water. It could also be a bad module on the icemaker which can get stuck in the fill position and spray water all over the freezer.
Sep 14, 2009 | Refrigerators
Icemaker works; water dispenser not
You can get to it, it is just a matter of figuring which valve has gone bad. You may need to disconnect different lines and actuate the water dispenser to see if water comes out of the valve. You gain access to the valves from behind the machine by removing the access panel that is at the bottom
Jun 16, 2009 | Amana SXD524VW Side by Side Refrigerator
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
Water dispenser doesn't work but icemaker works fine
TAKE A HAIR DRIER AND HEAT UP THE RESEVOUR INSIDE OF THE REFFRIGERATOR BY THE OUTLET UNTIL THE WATER STARTS TO FLOW. GOOD LUCK
Jan 11, 2009 | Maytag MFI2568AE Side by Side French Door...
Refrigerators Logo
74 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
