Thermostat reads in recovery - Heating & Cooling
Dear mr/miss
Want to know how the current consume
Posted on Apr 26, 2008
How to take out system in auto recovery?
I have this same issue but figured out it is just the energy savings system regulating the change in temperature it doesn't really mean anything It is only for your system but if you place your thermostat on a temperature hold it won't go through the auto recovery system
Jul 14, 2012 | Hunter Fan Company 5/1/1 Programmable...
I want to turn off the adaptive intelligent recovery feature on my TH8000 Series programmable Honeywell thermostat. How do I do that?
You only need to turn it off if you are using program mode. Very nice stat btw. Heres a link to the pdf and I will also explain. http://customer.honeywell.com/techlit/pdf/PackedLit/69-1896EF.pdf Use the system select button so that the heat option is flashing. Look at the bottom of the screen and you will see 7 boxes. First one done and seventh one cancel with all boxes in between blank. Now at the same time hold the 3rd and 5th box (buttons) for approx 5 sec. A new screen will appear with a number sytem staring at 0120 with up or down arrows and 20 with up or down arrows. Push the left up arrow till the left number reads 0530. The right number will read 1 if its on. To turn it off select the down arrow so it reads 0. Then select done and your all set.
Feb 26, 2011 | Honeywell Programmable Thermostat Heater
I need to change the thermostat
REMOVAL
  1. Remove upper intake manifold.
  2. Partially drain cooling system below the thermostat level.
  3. Remove upper radiator hose from outlet connector.
  4. Remove coolant recovery system hose from outlet connector.
  5. Remove coolant outlet connector bolts.
  6. Remove thermostat assembly, and clean sealing surfaces.
INSTALLATION
  1. Place the new thermostat assembly into the coolant outlet connector, aligning air bleed with the location notch on outlet connector.
  2. Install coolant outlet connector with thermostat in position onto thermostat housing. Tighten bolts to 12.5 Nm (110 inch lbs.).
  3. Install upper radiator hose.
  4. Connect the coolant recovery system hose.
  5. Install upper intake manifold.
  6. Fill cooling system.
  7. see thermostat mounting are below
Oct 19, 2010 | 2002 Chrysler PT Cruiser
Replace thermastat where is it and i need a easy fix solution
2.0L & 2.4L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect battery negative cable from remote negative terminal on shock tower and properly isolate to prevent accidental reconnection.
    CAUTION This operation must only be performed on a cold engine.
  3. Drain cooling system to the thermostat level or below.
  4. Remove or disconnect the following:
    Coolant recovery system hose Thermostat/engine outlet connector bolts Inlet hose and coolant elbow from thermostat housing
  5. Remove thermostat assembly and clean sealing surfaces.
    Fig. Thermostat and housing-2.0L and 2.4L engines
To install:
  1. Place the new thermostat assembly into the engine outlet connector. Align air bleed with notch on the cylinder head.
  2. Install engine outlet connector onto cylinder head and tighten bolts to 110 inch lbs. (12.5 Nm)
  3. Connect the coolant recovery system hose.
  4. Fill cooling system.
  1. Drain cooling system to the thermostat level or below.
  2. Remove the Coolant Recovery System (CRS) hose and thermostat/engine outlet connector bolts.
  3. Remove the thermostat assembly, and clean sealing surfaces.
    Fig. Thermostat assembly-2.0L engine
    Fig. Thermostat assembly-2.4L engine
To install:
    1. Align air vent upward with notch on the cylinder head (2.0L engine).
    2. Make sure spring side of thermostat faces cylinder head.
  2. Install the engine outlet connector onto cylinder head and tighten bolts to 110 inch lbs. (12.5 Nm)
  3. Connect the Coolant Recovery System (CRS) hose.
2.4L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the cooling system to the thermostat level or below.
  3. Remove the Coolant Recovery System (CRS) hose and thermostat/engine outlet connector bolts.
  4. Remove the thermostat assembly, and clean sealing surfaces.
To install:
  2. Make sure the spring side of the thermostat faces the cylinder head.
  3. Install the engine outlet connector onto cylinder head and tighten bolts to 110 inch lbs. (12.5 Nm)
  4. Connect the CRS hose.
  5. Fill the cooling system to the proper level.
Hope help with this (remember rated this post).
Apr 15, 2010 | 2002 Chrysler Sebring
Auto recovery mode raises the temperature above
Hummm... how far is your Thermostat from your heater? I am reading your extensive manual but there is no mention of that distance? There was a early mention of batteries? Are yours fresh?
Is this a 'new' problem? Has it worked properly before?
Then there is this from the manual:
The installer can set SYSTEM functions once the thermostat is installed. The
default settings are shown in bold in the following list. Options are listed inside the
parentheses. Example: the default SYSTEM TYPE is CONVENTIONAL with (HEAT PUMP) as a second option. See pages 28-29 to change these settings.
Have you tried resetting your Thermostat?? Sometimes these basic 'onboard' computers get confused... especially true with lots of 'options'...
It's a little hassle to get a DIGITAL copy of your manual (I am not a Robot ~ etc) ~ but here it is:
Download manual
TROUBLESHOOTING begins at Page 68
Anthony
Dec 22, 2017 | Hunter Fan Company 5/1/1 Programmable...
THERMOSTAT DOES NOT FOLLOW SCHEDULE. COMES ON
sounds like it is in smart recovery mode check installer set up
Dec 18, 2009 | Honeywell Programmable Thermostat Heater
Where do i refill coolant? message reading low engine coolant.
please rate, thx Coolant Recovery System NOTE: When the water thermostat (8575) is closed, there is no flow through the radiator coolant recovery reservoir (8A080).
Trapped air in the cooling system must be removed. A pressurized radiator coolant recovery reservoir system is used which continuously separates the air from the cooling system.
  • When the water thermostat is open, coolant flows through the small hose from the top of the radiator outlet tank to the radiator coolant recovery reservoir.
  • The radiator coolant recovery reservoir separates any trapped air from the coolant and replenishes the system through its radiator coolant recovery hose to the water thermostat housing.
  • The radiator coolant recovery reservoir serves as the location for:
    • service fill
    • coolant expansion during warm-up
    • system pressurization from the pressure relief cap and
    • air separation during operation
  • The radiator coolant recovery reservoir is designed to have approximately 0.5-1 liter (0.53-1.06 quarts) of air when cold to allow for coolant expansion.
Jul 08, 2009 | 1995 Lincoln Continental
Error Message RE CO on Indiglo
Auto recovery – allows heating and cooling systems
to gradually recover from an energy-saving setpoint
temperature to a comfort setpoint temperature. Auto recovery
calculates the time needed to adjust the temperature to
the next program setting. When the thermostat is in Auto
Recovery mode, the display will flash alternating messages of
RECO and the time. Auto Recovery can be disabled by sliding
the recovery switch on the back of the circuit board to the
disable position.
(Auto Recovery will not operate if Permanent or Temporary holds
are on.)
Press Hold/Return during the Auto Recovery process to
manually cancel the recovery.
Jan 05, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
