Question about Samsung SW 308 (SW-308BE) CD-RW/DVD-ROM (Combo) Burner
How to connect mobile to my peugeot 308 sw?? - Samsung SW 308 (SW-308BE) CD-RW/DVD-ROM (Combo) Burner
Peugeot 308 Space wagon 1.6HDI, screeching noise from alternator area? 2010 model.?
possibly the bearings are going south and it needs replaced soon
Nov 02, 2016 | 2010 Peugeot 308 SW
Peugeot 308 right rear cluster not working, i've checked the bulbes and fuses that i can find
Bet no electricity reaching the cluster. Get a hold of the schematic and check out all of the components in line between the cluster and battery.and switch. And do not overlook the ground connection.
Mar 29, 2016 | 2010 Peugeot 308 HDi
Engine oil pressure too low
First make sure that the crankcase is filled with oil to specs. If so then the hassle has to be with either the oil pressure sender, the indicator, or the oil pump not doings it job.
Sep 04, 2015 | 2010 Peugeot 308 SW
Peugeot 308 sw 1.6hdi90. Code poo93 and poo87 .engine takes sometime to start. Cold or hot.
fuel system issue--regulator--pump--sensors cud be worn----turn key on and off 3 times-- on 4 try startn engine--if it goes then fuel pressure was low and ull need a new pump or module or other parts of the system--get car scanned also to help pinpoint
Jan 05, 2015 | Cars & Trucks
If l change my battery 308 sw pueguot I will lose my radio cod
yes, and in case if I need to change the battery on any other car then before replacing the car battery I simply attach a 12 volt trasformer (rated at DC 12volts and 3Amps) or a jumpstart-battery to car-battery-terminals using clips to avoid the loss of car radio code, clock settings or other BSi settings.
Dec 25, 2014 | 2010 Peugeot 308 SW
Peugeot 308 problems
is it a 1.6 engine?
Jul 05, 2014 | 2008 Peugeot 308 1.6
Where can i find chassis number on peugeot 308
I find them with I connect my code reader/computer to car and get chassis number. look on side of engine. here is youtube video that will show you where to look even though its in foreign language.
May 22, 2014 | 2010 Peugeot 308 1.6
WINDSCREEN WIPERS WORK BUT WASHERS DONT PEUGEOT 308 SW
new motor needed ,test it when removed across the battery first in case its the switch though
Dec 27, 2010 | Peugeot Liberte Cars & Trucks
Samsung SW 308 (SW-308BE) CD-RW/DVD-ROM (Combo) Burner Logo
63 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
