Question about Ovens
My 16 month old whirlpool inegrated oven has a fault code F03 on screen. How can i fix this myself?
    President:
  • 949 Answers
The F 03 code indicates a failure with the temperature sensor.
The sensor comes into the oven cavity on the back wall and is a little smaller than a pencil. The most common reason for this error is a wire connection between the sensor and the control board.
You can measure the sensor if you have access to a good ohm meter. It should read about 1080 ohms at room temperature if it is good.
Posted on Aug 01, 2010
MY WHIRLPOOL OVEN KEEPS RESETTING A PROGRAMME BY ITSELF EVEN IN MID COOKING. THE OVEN IS ONLY 18 MONTHS OLD. WHIRLPOOL WONT HELP ONLY AT A COST.
Although the manufacturer only give a 12 month guarantee it is down to the retailer to sort faults. Under statutory rights you have up to 5 years to male a complaint. Get a quote for repairs and issue a claim in the small claims court.
Sep 30, 2014 | Whirlpool Ovens
Ariston wall oven error code f53 f03
I managed to resolve that problem. When you have BOTH F53 and F03 error codes, it's not a sensor fault (although F03 is the big cavity sensor and F53 is the top one)... it's a faulty capacitor trouble. On the main board there are 4 electrolytic capacitors, just replace all of them and you're ok again. It's quite simple and very cheap. :-)
Nov 26, 2013 | Ariston Technologies Ovens
Whirlpool oven fault f03
Hi
Code F03 usually means that the oven temperature sensor is 'open circuit', that is not working at all.
The remedy is to have it replaced.
Dec 19, 2010 | Whirlpool AKZ159IX Oven
Cooker has code f03
Needs programming sometimes they leave the factory without it or they can lose the programme.
Feb 16, 2010 | Whirlpool AKZ159IX Oven
Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
F03 Displays
I bought a new oven found this one way to complex anyway. Afterall i just want to cook in it.
Regards
Ken Mc
Sep 14, 2009 | Whirlpool RBS305PDS Electric Single Oven
I bought a Whirlpool double oven AKZ161 and error code F03 appear
On this model, F03 indicates a faulty power control board (also known as the "Capricorn" board by Whirlpool technicians). A new oven with no guarantee? There is usually a reason something has no guarantee, in your case, a faulty control board. It is a relatively expensive part unfortunately.
You can try disconnecting from power, removing top panel from oven. The large square electronic board you see on the top of oven is the power control board. Check all plug connections are OK, especially the large thin multi plug that goes to the display board- I have had a poor connection at this plug causes F03 faults. If still no go, power control board will need replacing
Aug 17, 2009 | Ovens
Whirlpool range gas model GS445LEMS
i have the same problem oven comes on but goes back off. help
Jun 26, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool oven fault f03 shown
f03 error is a sensor error.you could have taken an ohm reading on the thermistor to see if it was bad.if you replaces the t-mistor then the only other component responsible is the board.make sure all the connections on the board are clean and tight before you replace it.
Sep 28, 2007 | Ovens
Ovens Logo
580 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
