Question about Fisher and Paykel GWL11 Top Load Washer
Pump source??? Hey there, Topram. Where did you ever find any part for a F/P GWL11 for $30.00??? I'm having the same problem with the high pitch sqeal and the water just dribbles into the tub. The dealer who sold it to me said it would be a $100 service call & $105 for the part. I evenwent online looking for the valve and they wanted $100 + tax + shipping, etc. Any assistance is appreciated.
    Problem Solver:
  • 13 Answers
Hi. I suspect the solenoid valve could be the issue here (not opening). turn off your machine (unplug it) and open the control panel and remove the solenoid in question. you could try washing the solenoid valve out and opening it by applying power to it directly a few times. I have also used some electronic cleaning spray before to get these going. If you have a multimeter you can measure the coil of the solenoid (select ohms on your meter) to see if it has failed altogether, you should see a reading in ohms, if you dont, try selecting a higher range on your meter. check against another working solenoid to see if the value of resistance (ohms) is similar (ie check the reading of resistance on the hot water solenoid).
Posted on May 04, 2008
What is the cause of loud sqealing sound when cycling through brewing process.
CoffeeGeek - Coffee: Machines and Brewing Methods, Bunn MCP ...
coffeegeek.com > Discussions > Coffee > Machines
May 17, 2011 - 10 posts - ‎2 authors
Cycled the power, tried again, same problem...this time I cut the pump process .... The power switch was one of the reasons I like the MCP over the MC in general. .... It's definitely NOT a vibe...those are loud and vibrate like crazy, ..... of the noise you hear is that "honking" sound (the high pitched squeal) that ...
Why I Almost Killed Somebody When I Cleaned my Coffee ...
www.pauljenkins.tv/why-i-almost-killed-somebody-when-i-cleaned-my-...
Dec 19, 2015 | Gaggia Titanium Espresso Machine
Belt pulley squeal
Th cam shaft pulley has to be turning if motor running. Maybe fan is equipped with clutch that is bad.
Jan 28, 2018 | Toyota 4Runner Cars & Trucks
Mazda protege 2000 squealing from serpentine belt area check engine light on
it is the belt it is either to tight or not tight enough
Dec 14, 2012 | 2000 Mazda Protege
Has a high pitch sqeal while running (not during the drain cycle) I've had it all apart, nothing in any hoses or screens. A little coorsion on main pump motor, possible leakage? Maybe enough to make the...
Check motor bearings and replace with identical part and type. Check for water leakage through shaft to the bearings. Replace the oil seals as a full set along with bearing replacement.
Jul 13, 2010 | KitchenAid 24 in. KUDS01DLSS Built-in...
When i turn the power on there is a high pitch sqeal and ozone smell. then the power goes off
If there is an ozone smell, that usually indicates arching high voltage which should also be visible through the back cover vents (or back cover removal-better yet) if arching (blue sparking) is observed it is usually on the left side -back - rear and is likely the flyback transformer that has a crack in the casing - check there first- if the source of arching is identified post back here with details.Caution since High voltage is present.
Oct 14, 2009 | RCA F36444 36" TV
My 98 Villager makes a high pitch sqealing noise
go here for villager help.http://groups.yahoo.com/group/villagerquest/
Driver side or passenger side noise?
Jun 23, 2009 | 2000 Mercury Villager
Sqeal in the motor
CHECK FOR VACUUME LEAKS
Dec 10, 2008 | 2005 Ford F-150
High pitch sqealing noise
This is caused be a bad record switch. As a temporary solution, incert a blank tape, push the record switch, then stop. Repeat about 10 times. This may clean the contacts of the record/Play switch but it will probably need to be replaced.
May 20, 2008 | Panasonic RR-830 Desktop Cassette...
RCA D52W19 - High Picth sqealing noise
Thats usually a sign of the flyback or HV Splitter nearing the end of their operational lifespan. However its not an exspensive fix unless done ay a repair shop then it can be a few hundred.
Apr 21, 2008 | RCA D52W19 52" Rear Projection Television
Fisher and Paykel GWL11 Top Load Washer Logo
79 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
