Question about Avanti FF1101W Top Freezer Refrigerator
Fan in the freezer of refrigertor runs all the time is it suppose to?
  • 3,051 Answers
Hello there:
Yes the fan will always continue to run to allow for the air to be circulated in the freezer compartment
If this fan is not running
than this will need immediate attention to prevent further problems with the appliance ok
Hope this is very helpful for you
Best regards mike
Posted on Aug 01, 2010
Is the internal fan supposed to run continuously in a Hitachi freezer or does it give short interval runs? (Hitachi fridge rs700ggs8)
normally the fan on most can run all the time while the freezer is supposed to be cooling but in this might be an issue with any controls not working as it should otherwise it maybe normal
Apr 17, 2017 | Refrigerators
Is the fan supposed to run all the time?
I would leave it alone. IT gets cold that is all that you can ask. The fan could be stuck on because of a switch issue.
Aug 10, 2012 | Coldtech 10 cu. ft. Commercial Freezer...
Fails to cool
is the condenser fan at the bottom of the refrigerator blower air is there ice build up in the freezer side behind the wall is the refrigertor running at all is the fan in the freezer working
Sep 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Kitchen Aid Md# KBLA20ERSS The
Lack of airflow up to the refrigerator. could be a defrost problem, a fan motor not running, a damper staying closed, a food obstruction, or something else altogether.
May 09, 2010 | KitchenAid (KBLA22ER) Bottom Freezer...
Refrigertor not cooling but freezer working
your temp control fan has probibly gone out. The way you find out is to find the fan which should be located near the temp control switch behind a plastic vent. If this fan is out there will be cooling in the freezer but not in the fridge. Also, if you open that area and find a large chunk of ice you defroster rod has gone out. Would recommedn replacing both at that time. Get model and serial number of unit and take to an appliance parts house they can assist you in the right part and any type of installation problems. Good Luck
Jul 15, 2009 | Refrigerators
Refrigertor run alot
check to see if you have frost build up on rear wall of freezer section. you could possibly be low on freon
Jun 21, 2009 | Kenmore Refrigerators
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerator repairs
check freezer for frost build up on back wall and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Avanti FF1101W Top Freezer Refrigerator Logo
162 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
