Question about Dell Latitude D600 Notebook
I have a inspirion 6000 it says cant find hard
I have a inspirion 6000 it says cant find hard drive , i have tried a new hard drive , i have reloaded xp , finaly got it to take after much troouble, then go to boot , cant find drive any help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 77 Answers
the Dell inspiron 6000 battery hard disk partition problem, you must completely format and re-partition.
Posted on Aug 03, 2010
    Novelist:
  • 145 Answers
You may have a bios setting to check, it also may be damage on the connector or on the actual south bridge from over heating. I would load up into the bios and see if your drive is being detected and has the proper settings, try a default bios setting and see if that helps.
Posted on Aug 01, 2010
    Problem Solver:
  • 5 Answers
Dell inspiron 6000 laptop battery 4400mAh 6 cells Brand New,Li-ion, NO Memory effect, Replacement Dell Inspiron 6000 Battery. 4400mAh 11.1v 6-cell Inspiron 6000 battery Capacity: 4400mAh Size: 209.40×71.80×19.80mm Cell Qty: 6-cell product type: replacement Voltage: 11.1v Battery type: Lithium ion Color: Blackweight: 481.95g http://www.laptopbatteryok.com/dell-inspiron-6000-laptop-battery-4400mah-6-cells.html
Posted on Jan 12, 2011
    Problem Solver:
  • 8 Answers
Your battery has some bugs
please choose a new one!
http://www.laptop-battery-charger.net/batteries/dell/latitude-d600-series.htm
Posted on Sep 06, 2010
  • 734 Answers
H There,
I'm a pro laptop repair specilaist. I've dealt with a great many of the Inspiron 6000s and their newer cousins the 6400/e1505s. You problem was one of the most frustrating I ever had to tackle.
Your hard drive slides into a metal enclosure whih guides it to the female plug-in for the pins on the HD. But that is not a direct connection to the motherboard inside. The pins plugging in horizontally enter a plastic plug that receives them and then the tiny wires inside make an instant 90 degree turn through this plastic block (which is permanently attached to the metal slide-in enclosure) and become a male plug which plugs down into the motherboard vertically from above.
When that connections fails partially (as in your case), whether through an unknown spill, drop or just time gone by, it will never again properly recognise and run a hard drive. The fact that you installed a new drive and had the results you describe make me almost certain this is the problem. While that one part is replaceable physically, it's crazy-making trying to find that single part (I never did) and I was forced in all 3 occassions I encountered this issue to replace the entire motherboard.
I hate to be the bringer of bad news so I'll ask you don't "shoot the messenger" with an "unhelpful" rating. You're at the stage in the age of that laptop model where some of them just chug along for a few more years and others develop expensive problems.
I'm sorry that it seems you've encountered one. Still, if you look on eBay and the net nationwide, someone may be offering this part as a stand-alone sale. They weren't when I last encountered the issue a year ago.
Best of Luck
3 Suggested Answers
Trust Me
  • 26 Answers
SOURCE: No boot sector
The other post is correct, but you don't want to try and take out Hard Drives from laptops.
The easiest option is to use a Dell XP CD for recovery
There is a little known fact though, there is a factory shipped Dell Partition that is hidden for recovery.
There is a tool (slightly technical) to 'properly' deal with repairing the MBR (as regular XP disks can ruin Dell MBR's)
Dsrfix Quick-Start This section should give you a quick idea how Dsrfix is used. However, be sure to also read the following sections to get a clearer idea of the details and potential pitfalls.
Dsrfix is a DOS program. It does not work in Windows. It does not work in a XP command-prompt window. It does not work in the Windows PE (preinstallation environment) or RE (recovery environment) -- those are not DOS. You need to boot to real DOS. If you need to, CLICK HERE FOR HOW , you can just download the 98SE DOS Bootdisk to a floppy.
This will get you into DOS (if you need that help) and then you can follow directions below)
It's a bit overwhelming, but it's the safe and real way
Download dsrfix.zip from DSRFIX LINK (Updated 09-20-2007, version 3.11)
  • Extract dsrfix.com from the archive.
    (Note to reader: The other files in the archive are supplemental. The only file you need to copy to floppy disk is dsrfix.com.)
  • Boot from your DOS boot disk.
  • Run the command " DSRFIX ". Review the results to assess whether your system is a good candidate for restoring Dell's DSR feature.
  • Optional: save a dumpfile before making any changes. This may be useful if you later need the information for forensic reconstruction.
  • If you decide your system is a good candidate for repairing Dell's DSR feature, rerun Dsrfix with the command " DSRFIX /F ". The program will repeat its summary report, then prompt you to queue any changes to be made. Accept or deny each fix proposed by Dsrfix. After proposals have been queued, confirm whether you want Dsrfix to go ahead and write those changes to your hard disk.
  • Rerun Dsrfix again for a new report to check the results.
If Dsrfix's report shows no fatal errors and no alerts, the Dell-specific restore feature should be functional on your system. You should see a blue "www.dell.com" banner across the top of the screen when the computer starts to boot. Pressing the Ctrl+F11 keys at that moment should divert the boot process to Dell's custom restore utility.
Hope that helps,
TrustMe
Posted on Apr 14, 2008
rohntech
  • 422 Answers
SOURCE: my dell latitude c400 will not boot from external
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Posted on Feb 15, 2011
.dell inspiron shuts off before boot. when charger is connected it periodically flashes once on charging light. battery is good and is charged
Hello, The hard drive operating software or the hard drive is bad. You will have to try using the recovery cd to reload the software.
May 15, 2014 | Dell Inspiron 6000 Notebook
Dell inspirion 6000 is showing "loading PBR2.....done. NTLDR IS MISSING.HOW TO FIX
Use the Restoration Disk. When asked choose Repair.
(Non-Destructive Installation)
You are missing basic Windows files. Boot loader files.
Also you may have to prepare to replace the harddrive. May have bad Sectors on it.
Means I would copy off all personal information, after getting that laptop going again, or you may lose it.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/NTLDR
http://computer.howstuffworks.com/hard-disk.htm
http://computer.howstuffworks.com/hard-disk7.htm
Dec 19, 2012 | Dell Inspiron 6000 Notebook
2005 Dell Inspiron 6000, I need to reload the operating software, my hard drive crashed and I have a new hard drive I am going to install. How do I go about loading in the software??
If you have your windows disc, go into your bios. Make sure your disc drive is the FIRST BOOT DEVICE. Then restart your pc and it should load from the cd.
Mar 23, 2011 | Dell Inspiron 6000 Notebook
Dell Inspiron 600 - trying to reload, but not
You might need to go into the computer's BIOS and see if it's set to boot from a bootable CD or USB device. If it's set to only boot from the hard drive, it won't even look at other drives. Different computers use different ways to access the BIOS: you might try pressing the F12 key when the boot logo appears. Check your owner's documentation - it should tell you the procedure for your computer.
Mar 31, 2010 | Dell Inspiron 6000 Notebook
Trying to Wipe Hard drive but Dvd player dosent reconize the disk
Try cleaning the CD, first. If still a problem, the CD may be bad - try in another computer to test.
Jun 15, 2009 | Dell Inspiron 6000 Notebook
Upgraded hard drive, from 80gb to 250gb. I have had to reload my os twice. it appears that the bios is not recognizing my hd. a friend said that the inspiron 6000 does not do well with a hd bigger then...
I dont think we can use a hard disk of 160gb in an inspiron 6000. and make sure you bought a ATA hard drive and not a SATA drive. For the Western digital try to reinstall XP and install the device drivers before installing application s/w.
Dec 19, 2008 | Dell Inspiron 6000 Notebook
Inspiron 6000
Your instalation is screwed. Get the original disks that came with the laptop and reinstall everything and you should be good to go. Dont forget to change the bios settings to boot from cdrom/dvdrom first so as when you power up, it loads from the cd, not the hard drive.
Sep 18, 2008 | Dell Inspiron 6000 Notebook
Blue screen
The blue screen indicates either an operating system error that will need either a system repair or reload using the system recovery disc or an operating system disc, or it indicates a hard drive failure, in which you will need a new hard drive. Start by trying a system repair, then reload if the repair doesn't work. If the machine has issues during or after the repair/reload, then it's the hard drive. The blue screen should have an error code. Sometimes it's helpful if you list the error code, it could tell us exactly which it is. I won't be back until tomorrow, but if you want to try the repair/reload tonight, and if it doesn't work let me know and I'll see if I can tell you what the code means.
Jun 22, 2008 | Dell Inspiron 6000 Notebook
Dell Latitude D600 Notebook Logo
125 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
