Question about HP Photosmart C5180 All-In-One InkJet Printer
How do you fix ink system failure Error
How do you fix ink system failure Error :0xc19a0021
  • humec Aug 01, 2010
    That did the trick and I thank so much.
  • HP Master
  • 6,993 Answers
to fix the problem, you need to reset the printer. Follow the procedures below to successfully reset your printer:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the printer.
  3. Wait for the "Insert Cartridge" message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Good luck.
Posted on Aug 01, 2010
4 Suggested Answers
mace1mace
  • 1138 Answers
SOURCE: error: 0xc19a0021 Ink system failure
These errors that always come out starting with 0xc.. - only means that there are internal error inside the printer.
These errors can only be remove if you reset the printer.
here's the step to reset your printer
1. While your printer is on.. disconnect the usb cable from the back of your printer.
2. Remove the cartridges.
3. Wait until the message "Insert Cartridge" display on the control panel.
4. Disconnect the power cord from the back of the printer.
5. Wait for 60 seconds.
6. Plug the power cord at the back of the printer...If printer does not automatically on..press the "Power" button.
7. Reinsert the cartridge and close any open doors of the printer.
8. If prompted to Calibrate, do so..
9. Reconnect the usb at back of the printer...and try printing again..
Hope that solve your problem..
Much appreciated if you rate this help..thanks..
Posted on May 24, 2010
SOURCE: ink system failure error 0xc19a0021
Refer to my cure for error 0xc19a0035 My machine was doing all sorts of stupid things, different error messages, power looping at switch on, paper getting jammed, cracking and grinding because the print head motor was trying to drive the head through the side of the machine and all caused by a faulty capacitor in the internal power supply on the systems control printed circuit board.
I hope this is some help to you all with various faults on what is a superb machine when it is working ok.
Robert t
Posted on Dec 03, 2010
Ink system has failed.Unable to print. Error:0xc19a0021.What can I do?
Hewlett Packard Ink System Failure Error Fix (tested C6180) 1- Press and hold the "*" key. 2- Press the "#" key and release both keys. Display should say "Enter Special Key Combo" 3- Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M 4. Press and release the right arrow button until the display says "System Configuration Menu". 5. Press and release the "OK" button. 6. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", 7. Press and release the "OK" button. 8. Display should say "Hardware failure status: Clear. Press OK to clear". 9. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". 10. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 11. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 12. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 13. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
I hope this helps Regards GM
Jul 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
ECHEC DU SYSTEME D ENCRE
Applicable error codes
This document applies to Ink System Failure error messages with any of the following codes:
0xC19A0001, 0xC19A0002, 0xC19A0003, 0xC19A0006, 0xC19A0008, 0xC19A0009, 0xC19A0013, 0xC19A0014, 0xC19A0015, 0xC19A0020, 0xC19A0021, 0xC19A0022, 0xC19A0023, 0xC19A0024, 0xC19A0025, 0xC19A0026, 0xC19A0027, 0xC19A0028, 0xC19A0030, 0xC19A0033, 0xC19A0034, 0xC19A0035, 0xC19A0036, 0xC19A0037, 0xc19A0040, 0xc19A0041, 0xc19A0042, 0xC19AC001, 0xC19AC002, 0xC19AC004, 0xC19AC008, 0xC19AC010, 0xC19AC020, 0xC19AC040, 0xC19AC063, 0xC19AC080, 0xC19AC0a5, 0xC19AC0c6, 0xC19AC0e7, 0xC19AC100, 0xC19AC129, 0xC19AC14a, 0xC19AC16b, 0xC19AC18c, 0xC19AC1ad, 0xC19AC1ce, 0xC19AC1ef, 0xC19AC200, 0xC19AC231, 0xC19AC252, 0xC19AC273, 0xC19AC294, 0xC19AC2b5, 0xC19AC2d6, 0xC19AC2f7, 0xC19AC318, 0xC19AC339, 0xC19AC35a, 0xC19AC37b, 0xC19AC39c, 0xC19AC3bd, 0xC19AC3de, 0xC19AC3ff, 0xC19AC400
HP Photosmart C6380 and others
Hi
There is to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 25, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink failer
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
Feb 21, 2010 | HP Photosmart C6280 Printer
Hp 6380 error message 0xc19a0023
Hi
Feb 21, 2010 | HP Photosmart C6380 All-In-One InkJet...
My photosmart c5180 gives me the error code 0xc19a0021 and says ink system has failed. if i unplug it and restart it it will print for a few minutes until the error comes up again
The kind of error you are getting is due to fault in the ink and print section so you can clean the print head with soft tissue and install the cartridge properly and check the vent of it and now reset the printer by turning on and disconnecting by pressing power button for 20 seconds
and hopefully everything will work out it the problem persists then you might have to replace the print head
Thanks And Regards
May 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
Sep 06, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
200 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
