Question about GE A730 Digital Camera
Write Protect When I turn the camera on to take a picture, a warning comes on saying. "WRITE PROTECT." I don't know how to take it off, or what caused it to come up.
  • 1 more comment
  • tiffster08 May 26, 2008
    write protect is showing up on my camera!!
  • playboyplay Jul 19, 2008
    when i try to take a picture write protect comes on
  • Adriennemart Feb 02, 2009
    when i turn my camera on{its a ge A835} its saying write protect how do i get this off{when i take the flash memory card out it ok}
I Had The Same Problem With My Camera. I Figured It Out That It Was Not The Camera, But There Is A Little Switch On The Side Of Your Memory Card, Just Slide That Switch And You Should Be Good To Go.
Posted on Jul 15, 2008
    Scholar:
  • 186 Answers
Try using another card and see if it gives the same error. Might be a formatting problem.
Posted on Apr 25, 2008
I dont know how to delete a protected picture off my canon power shot a470 camera. Can you help?
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
Jan 20, 2011 | Canon PowerShot A470 Digital Camera
Every time I turn on my camera a message appears on the screen that says "write protect". What is "write protect" and how do I get rid of the message?
1) It could be your camera has write protect switched on. Go through your camera's menu and look for picture protect and remove it.
2) Your SD card could be write protected. Take out the SD card and check, there's probably a sliding notch on the left hand side, move the to write enable.
Jun 27, 2010 | Olympus FE-190 Digital Camera
Canon PowerShot SX20 IS Digital Camera keeps giving me a memory card error. The memory card is a 4gig PNY memory card (lower budget)
Make sure the slide switch on the side of the card is unlocked. Your camera may just want you to format the card in the camera. Download any pics from it first using a card reader if necessary.
Jun 22, 2010 | Canon PowerShot SX20 IS Digital Camera
It won't take a picture. It says
Take the card out, there should be a small notch on the left hand side, move the notch to "Write Enable" or Unlock position.
If that's not the issue, you camera could have photo protect switched on. Its part of the camera menu. You'll have to search it out and turn the protect function off.
Jun 06, 2010 | Vivitar ViviCam 8025 Digital Camera
Write protect.
go to menu and find whether sttings is kept in protect pictures , set it to default and try again.
Feb 17, 2009 | Vivitar ViviCam 3750 Digital Camera
My camera says write protect and won't let me take pics
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Feb 07, 2009 | Olympus Cameras
What does write protect mean?
"Write Protect" means that something is locked and your device (camera) cannot "write" to it's storage area.
What type of "storage media" are you using?
For example:  the camera's internal memory, a CompactFlash card, a Memory Stick, an "xD-Picture Card" (micro, mini or regular sized), or a Secure Digital/MultiMediaCard.
[Did you put something  (a small plastic card of some sort) into a slot on the camera before or after turning it on?
Those little cards usually have a tiny button (also called a switch or lever) on them that will move back and forth to lock (write protect) or unlock it. This sounds like the memory card inside your camera is locked or "Write Protected.
To fix this simply take it out, closely examine the memory for the button- the button will be closer to the word "lock" or "protect" and all you need to do is gently slide it in the opposite direction from where it currently is. Put it back into the camera and see if it still says "Write Protect."
Let me know...
Rae
Nov 27, 2008 | GE A730 Digital Camera
"Overheating warning"
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)
Sep 14, 2007 | Mitsubishi WS-65613 65" Rear Projection...
GE A730 Digital Camera Logo
69 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
Are you a GE Camera Expert? Answer questions, earn points and help others
