Question about Weber Summit S-470 Propane Grill
Uneven heat and sound rushing gas
Grill hard to light, uneven heat and a hear the sound of rushing gas
  • 2,272 Answers
Although not considered normal, a possible cause for uneven heat is a blockage in the burner venturi tubes. It is possible for small insects to get inside the venturi tubes of the burner. Any blockage inside of the venturi tubes could cause uneven heat.The burners needs to be cleaned and then checked. Your burner port holes may be blocked, thus not allowing and even flame across your burner. To correct this, simply clear the debris out by poking blocked holes with a paper clip (or another tool small enough). Check out.Thanks.
Posted on Aug 01, 2010
  • vintners Aug 01, 2010
    Venturi and and screens next to what I beleive is the venturi appear to be free of any bugs or other obstructions. Any other ideas
    Thanks
    Any ideas?
Why southbend temp various over the grill ? set on same settings but will be hotter in spots
This uneven heating is something "grillers" have dealt with since we started cooking...the heat is higher directly over the source and gets progressively cooler as you move away.. This is more pronounced with gas or electric grill/cookers..because the heat source is in a fixed position...WITH charcoal, you can spread the coals out (if you use enough).. and get even heat over a larger area.... I have a NEW 4 burner(w/hot pad) Charbroil gas grill and a old Charbroil charcoal grill...I HAVE NEVER used the gas grill...and I grill 1-2 times a week!! ..(it was a gift/two years ago.... wanna buy it?)
May 31, 2017 | Grilling
Troubleshooting nexgrill charcoal gas grill
did you replace the battery in the igniter?
less than 100 degrees indicates a safety has engaged, close gas valve, open burner valves.....wait 5 minutes. keep lid open, close burner valves, open gas valve until you hear the regulator click
turn on "ignition burner" and ignite (with switch or at specified port).
After this part is lit open other burners one at a time , waiting until each lights before opening the next.
Dec 07, 2013 | Nexgrill Charcoal and Gas Grill Combo
2003 ford taurus rush of air sound when gas is pressed
may be a leak in the intake hose check it all the way from the filter to ththe tb
Dec 22, 2012 | 2003 Ford Taurus
Can I use lava rock in my genesis silver gas grill?
No, it will cause uneven heating, flare ups and there is no rack to place the lava rock on. For safeties sake, never try to alter a gas grill to make it what you want it to be. If it didn't come that way from the factory, don't do it.
Hope this helped answer your question. Thnaks for choosing FixYa and Happy Grilling.
Aug 07, 2011 | Weber Genesis Silver B Grill
My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Dec 01, 2009 | Char-Broil Commercial Stainless Steel...
There is a high pitch that people over approx age 30 cannot detect. My son and daughter complained of a high pitched noise coming from our gas grill, but I could hear nothing. I turned the gas tank off,...
What they are hearing is the regulator. There is a diaphragm in the regulator that is vibrating due to the rush of gas flowing through it. This is easily corrected. First, the next time you light the grill, turn the tank valve only one quarter to one half of a turn and light the grill, once the grill is lit, if you have trouble bringing the grill to the temperature you want, you can open the tank valve more and the noise shouldn't start. The reason the noise won't start then is because by that time, the regulator's diaphragm is at the temperature of the gas flowing through it and, subsequently, will not vibrate. If the noise starts again, you can go to just about any home improvement store and get a replacement regulator.
Nov 18, 2009 | Kenmore 16322
Regulator hums when in use and barbeque gets excessively hot
You have the bottle valve opened all the way, the gas is rushing through the regulator making the diaphragm vibrate which is the humming noise you are hearing. With the gas flowing like that, you are basically preventing the ability to control temperature so the grill gets way hot. The best thing to do is to open the valve one full turn only and then light the grill...if you can't get it hot enough after that, then open the valve another full turn...you should never have to open that valve all the way...if you start having to do that then the bottle is almost empty and needs to refilled.
Sep 24, 2009 | Weber Genesis Silver A Grill
One side won't light.
Prior to attching the hose from the regulator to the tank, I turned on all five burners, opened the gas to the tank, allowed the gas to run a few minutes to equalize, be careful when turning on as the gas has built up. I have had no problems since.
I belive part of the problem is that my grill has an automatic ignitor, that can be problematic after changing to a new tank. Thats why I had the burners on (open) prior to attaching the new tank prior then opening the valve on the tank so it doesn't ignite.
May 29, 2009 | Thane Q-BBQ Grill
Spiders love the smell of the gas and sometimes crawl into the small tiny orifice and fill with web where the pilot lights since that is the area where the first part of the gas enters the burner-try using a needle or straight pin to clean
Nov 08, 2017 | Thane Q-BBQ Grill
Weber Summit S-470  Propane Grill Logo
80 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
