Question about D-Link Dns 323 2-Bay Network Storage Enclosure - Nas Server (S6070845)
Dns-323 automatically shutdown few seconds after startup
My dns-323 automatically shutdown few seconds after it finished the start-up routing. after it shutdown itself, no chance to turn it on using the power button. the only way to turn it on is by unplugging the power supply. once power was applied, it will automatically turn on, then same thing it will shutdown itself after completing the startup. it has 2x1TB WD caviar green. i tried only 1 harddisk on different slot and without harddisk, same result. i already did a factory reset, same result.
Had you found a solution ? i'm front the same problem :(
Posted on Sep 27, 2011
MY SYSTEM IS HANG & AUTOMATIC SHUTDOWN IN A FEW SECOND
Please check your cpu fan properly connected and working or SMPS fan.
Jan 21, 2014 | Intel Computers & Internet
My system is hang automatically & shutdown in a few second
Firstly checking processor fan dust and heat compound is dust, then paste new compound
Dlink 323 password reset
If you still need help resetting your D-Link 323 password, have you tried checking out the user manual? You can get it here:
Link DNS 323 manual
Aug 25, 2013 | D-Link DNS-323 (DNS323) Hard Drive Array
Can't connect to my dns-323
If you disabled the firewall and the Easy Search utility still can't find it, you could try searching for the answer in the device's user manual:
Link DNS 323 manual
Aug 04, 2012 | D-Link DNS-323 (DNS323) Hard Drive Array
Can't access recovery disk on partition
well first off, i don't think you have a dns changer, that would simply render your internet useless. when you get a blue screen what error message are you getting? i'd try and unplug the computer and remove the cmos battery. wait for like 10 minutes and plug it back in and try again.you can download the windows recovery console from microsoft, just do a google search.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 18, 2012 | Sony VAIO Computers & Internet
My laptop is automatically shutdown when they normally boot-up
if you can, hit start, if it is xp hit "run", type "shutdown -a" without the quotes, then hit enter. you will have to do this fast before the 10 seconds. if it is vista just hit start, then type "shutdown -a" and hit enter. if you are quick enough, the shutdown will abort. now, go to the startup folder in start>all programs>startup and delete anything there if you don't know what it is. this might stop it from happening again. someone might have put a shutdown command in the folder as a joke. it could also be a virus. so if this fixed it, download spybot search and destroy and run a scanmobile crusher http://www.lzcrusher.com
May 09, 2012 | Toshiba Computers & Internet
D-Link DNS 323 Bittorrent doesn't start
Make sure that the ports for the application are open in both your modem and router
Dec 29, 2009 | D-Link Dns 323 2-Bay Network Storage...
Mapping of D-link DNS-323 drive doesn't succeed.
I had the same problem when I was attempting to map the drive using the hostname of the DNS-323. I solved the problem by typing in the IP address instead. Do the following:
1. Login to the DNS-323 as admin
2. Make sure you use static IP's to make sure that the address does not change in the future.
3. Go to the drive mapping page and use IP address instead of hostname in the drive mapping (e.g. \\192.168.1.1\Volume_1)
4. Make sure you use a valid username and password.
5. Check the connection configuration by clicking on the Test button.
You should get a successful outcome, otherwise check all the settings again until you are successful
Nov 20, 2009 | D-Link Dns 323 2-Bay Network Storage...
I am setting up the D Link DNS 323 but I cannot get6 past the admin password screen. it says in the manual to leave it blank, but this does not work
If it's a brand new out of the box DNS-323 it should be:
Username: admin
Password: <leave blank>
If this is not working, check for CAPS-lock, or perform a reset of the device (see the manual).
Oct 17, 2009 | D-Link DNS-323 (DNS323) Hard Drive Array
I try to connect DLINK dns 323 to WD TV by USB cable but it not work how can i solve this
The USB port on the D-Link DNS 323 NAS is for a printer only. It won't work with your WD TV. Your best bet would be to plug the WD TV into a PC that is connected to your network along with the D-Link DNS 323 NAS and serve your media files that way.
Sep 04, 2009 | D-Link Dns 323 2-Bay Network Storage...
D-Link Dns 323 2-Bay Network Storage Enclosure - Nas Server (S6070845) Logo
383 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
