Question about Samsung HL-P6163W 61" TV
HLP6163W-loud annoying noise comes from the back, tv shuts off, three lights flash
TV is made in 2004. On 1/1/08 I bought a new lamp because I was hearing noise and seeing flashing lights/poor picture. After only about 3 months I started hearing the noise again (usually for a few minutes after turning the TV on after it was powered off for a couple hours) thinking it may be the color wheel. Now, the noise has become really loud and annoying, the TV powers off, all three lights flash. The lamp doesn't even turn on now, but when it did: the screen would display all kinds of colors. It doesn't appear that the lamp is defective after looking at it closely. What would be the diagnosis? Color wheel? Base Socket? Thank you for reply.
  • derekvair Jan 21, 2009
    I have the same problem the 3 lights flash on front. The tv is out replaced bulb. Comes on 10-15sec then goes out. I replaced the Ballast Mod. Still does the same. Then replace the Power Board STILL the same thing. Can someone help me.
    Champion:
  • 252 Answers
Your plyback had a problem,change it with a new one
Posted on Oct 16, 2008
Samsung hlp6163w dlp tv not working, new lamp, new ballast, still three blinking lights
If color wheel does not run lamp will not fire----with lamp removed have you looked at the wheel----if not running it will cause almost instant shutdown of lamp and the set.
If the DMD board is bad time for a new set as it is well over 500 .
Mar 28, 2012 | Samsung HLP6163W 61" Rear Projection...
Samsung tv was humming and now quit working
You color wheel would have been the source of the humming noise. It is not terrible difficult to replace. I believe there are a few tutorials on this website that can assist you if you want to DiY this repair. Just remember to trip the lamp door switch and test the unit prior to replacing the back cover... it will same you time if you need to correct a mistake.
Mar 14, 2010 | Televison & Video
I have been trying to fix my hlp6163wx/xaa I replace the light bulb and ballast I have no sound or picture what else could it be!?
could be the colorwheel. listen right after the power button is press you should hear a slight wind up noise coming from the rear of the tv. if you dont hear that the colorwheel may be bad
Jan 30, 2010 | Samsung HLP6163W 61" Rear Projection...
Tv making a loud noise and the lamp status light
Replaced the lamp.Might also be light engine blast too.
Dec 17, 2009 | Televison & Video
Lamp
you might need the ballast as well
Dec 26, 2008 | Samsung HLP6163W 61" Rear Projection...
Samsung projection tv
change lamp change fans
and replace color wheel.
make shure to remove jumper when replacing samsung color weel.
the jumper is black on the back panel of dmv modual.
jumper needs to be removed due to the new air cor motors thay are yousing, i had this same situation at one time.
Dec 16, 2008 | Samsung HLP6163W 61" Rear Projection...
Samsung HLP6163W wont turn on
I went to sleep my tv was play i woke up and don't work so i turn it on popping crack sound and it shut down what do nowno tv
Sep 13, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Blank Screen Problem
Does the menu come up? If it does, then, the source could be the problem, such as the cable or DVD player. If the source is not the issue, then, the problem would be in the Digital or Analog PCBs. If the menu does not come on, then, the problem is more than likely the DMD. If it is not the source then call a local authorized Samsung servicer in your area. Contact 1-800-Samsung. Hope this helps.
Apr 01, 2007 | Samsung HLP6163W 61" Rear Projection...
Samsung HL-P6163W 61" TV Logo
310 people viewed this question
Henry  Thomas
Henry Thomas
