Question about Refrigerators
Have an older chest freezer that i had to tip on end to move out of a tight spot. Worked fine before, now it just runs, but doesn't freeze. What happened?
    President:
  • 1,218 Answers
Good day,
If it's running, there is little else you can do. Unlike a refrigerator, all of the refrigeration lines are bonded to the inside of the cabinet walls. They can give out sometimes with the littlest twist or movement.
Unless you can see a line that is exposed going to the compressor damaged, then nothing can be done. Recharging is out of the question since it will simply leak out.
Sorry for the bad news.
Posted on Aug 01, 2010
Woods chest freezer when top is lift light comes on but the wire hook up broke
You can put the wires back together by twisting stripped ends together and sealing the repaired spot with "Heat shrink tubing". Most hardware stores carry the tubing (or can help you to find some). Put the tubing on one of the ends, twist them together good and tight, bend the wire flat against either wire, move the tubing down over it and heat with a lighter to shrink it. Get the right size so it shrinks tight for a good seal. Make it long enough to extend an inch or so past the twisted wires on both sides. If the wiring can't be repaired for some reason, an exact replacement would need to come the manufacturer. If regular lamp cord will work, the hardware store should have that too. If you need to pull a new wire through the insulation, let me know. I can give you a tip or two to make it easier. Good luck.
Nov 20, 2013 | Woods Freezers
My whirlpool chest freezer not freezing at all
it not freezing because it cooling system must be damaged,you bought another cooling machine it has mini size and it fixed at the point of older cooling placce.
Mar 22, 2013 | Whirlpool 14.8 cu. ft. / 419 liter Chest...
I have deep freezer chest that does not freeze but when you plug it in you can hear it click on but will not get cold at all has been unplugged for a few years but stored in a dry building
If it doesn't get cold at all, then your compressor is not running. Which could be the start relay or start capacitor or even the compressor. The relay and capacitor are not that expensive and pretty easy to replace, but if it is the compressor then you might not want to put that much money into an older unit.
Aug 13, 2011 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Black & Decker BF53 Chest Freezer wont freezer after moving to another state. It worked fine and now its just freezing to a frost is all. I'm scared my food is going to spoil. Bought it second hand and...
dear sir,
i think after long trasporatation your freezer has been leek from any pipe so please contect to your service technician for find out that leek and refill the refrigrant gas .after that your freezer will be able to good cool.
hope the question,s answer
thank you .
Jul 09, 2010 | Freezers
Does the kenmore cold spot chest freeze model 253.8193610 have a defrost timer
Chest freezers don't normally self defrost. They just freeze. To defrost them, you must shut them off.
May 02, 2010 | Kenmore Freezers
Chest freezer repair
I had the same problem with an upright and so I bought a piercing valve and charged the compressor with 134R and has been working great since.
Jul 05, 2009 | Freezers
Freezer is freezing but the outer wall are extremly hot
This is a normal condition.  The condensor coils are in the cabinet and their job is to remove heat which is why it is hot.  You will want to make sure the freezer isn't in a tight spot where air from the room can't flow across it.  Without good air flow it will become too hot and not cool properly and lead to the compressor failing too soon.
Oct 13, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
