Question about Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range
We have a stoves Gas cooker G900 its quite old it was here at our house when my partner moved into it and we are looking for an instruction book as the oven keeps switching off and you need to turn on the grill till the corner bit flash s and then you can light the oven again
2 Suggested Answers
  • 7 Answers
SOURCE: i have no instructions for my stoves envoy cooker,
You can ring stoves on 08712222502 they will usually email over a manual for free you just need your model and serial number of your oven.
This can be found usually just behind the door to the grill.
hope this helps :)
Posted on Jun 01, 2009
Why is there air flow from under the pellet chute?
PVC Technology - Page 662 - Google Books Result
https://books.google.com/books?isbn=9400956142
M.V. Titow - 2012 - ā€ˇTechnology & Engineering
13.82(B)) is similar to the first, except that there are no mechanically moved parts ... the air flow so that the pellets are kept in a state of gradually sinking suspension. ... Both are chute conveyors employing the fluidised bed principle, and both use ... thepellets are moved forward by micro-propulsion under both horizontal and ...
All comments on Rocket Stove Heater/Cooker Pellet ...
https://www.youtube.com/all_comments?v=fD1YaDmJkHI
The amount of roar depends on the velocity of air flowing through the pellets, ... top of the door and at the bottom of the door if there is not sufficient oxygen for a hot ... and some tends to be drawn under the pellet chute/slide and collect behind ...
Rocket Stove Heater/Cooker Pellet Performance - YouTube
Dec 12, 2015 | Home
We have just moved house and have been left a Belling Platinum Dual Fuel db2 Cooker and cant get the ignition to work. Can anyone suggest what we should do?
by cooker,do you mean a stove? is it gas?is the gas knob in the "on" position?is the stove plugged in?
i clean out apartments to get them ready for new tenants. if the ignition clicks on,but the burner isn't lighting,it might be dirty. i soak the burners in hot water overnight. scrub with a wirebrush.poke a needle in all the openings & on the ones in the stove. dry thoroughly & see if it works.
if the ignition isn't clicking at all,one of the components in the electrical box might be broken.i wouldn't mess with gas or electric.call your gas & electric supplier or a repairman to find out what's wrong & see if it's worth fixing or not.
Mar 30, 2015 | Belling Kitchen Ranges
Small gas leak smelled inside house from GE Adora (just 2 yrs old). Have moved stove and have put soapy water with paint brush on every connection including regulator...don't see any leak evidence...any...
You may have to use dish soap straight, do not use the brush. I use an old spray bottle and dish soap straight, not watered down, to find my leaks. Gas is a very low psi. Soapy water will not bubble up. It can and will just be pushed out of the way. Do not forget any other gas appliances in the house, hot water heater, stove, any thing that uses gas. Please check all. Recheck your stove and even any connections inside, on/off valve etc. Hope this helps Fixya up.
Dec 13, 2010 | Microwave Ovens
Model No LD-14AWZ Wash rinse and dry lights flashing. IE flashes on display board.Model no LD-14AWZ
not sure if im on the rite page we have move into a house that has a disherwasher LG Model LD/14AW2 there was no instruction book left at the house cant seem to get it to work even though it looks quite a new dishwasher do anyone know where i could get a instruction book from thanks noelene
Jun 26, 2010 | LG 24 in. LD-12BW5 Free-standing...
Stoves richmond 1000df - no instructions for which knob operates which oven - dont know how to use slow oven
The book that came with the cooker only explains the symbols on the knobs not which knob to use with what cooker. It is very confusing. Does anyone know where I can get something more comprehensive?
May 14, 2010 | Stoves Richmond RM1000DF Dual Fuel...
Gas cooker
Probably. Speak with your propane supplier about what will need to be done with your stove.
May 03, 2010 | Belling DB2 Dual Fuel (Electric and Gas)...
Any chance of mailing me instruction manual.
All I wanted was a copy of the instruction book, never mind I will get one somewhere else.
Jun 11, 2009 | Creda Ovens
Pressure cooker safety
From the point of view of the pressure cooker, there shouldn't be any problem at all provided you follow the pressure cooker instructions.
From the point of view of the stove, the only thing you might want to watch out for is point loading - some older pressure cookers can get a bit domed at the bottom. On a flat surfaced stove, this will concentrate all the weight of what is after all quite a heavy pot onto a small part of the stove top. If the bottom of the pressure cooker is still nice and flat, I don't see any problem.
A.
Mar 08, 2008 | GE Spectra JBP78 Electric Kitchen Range
Low Gas Pressure on Smeg Range cooker
there should be a regulator on back of the stove where the gas line connects.you will see a plug that unscrews,remove this plug and run the unit.if this solves your problem clean the plug really good and put back on.
Dec 25, 2007 | Kitchen Ranges
Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range Logo
54 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
marley mcelhinney
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
