Question about Canon PowerShot A510 Digital Camera
E18 error message - Canon PowerShot A510 Digital Camera
  • 415 Answers
Check the link to repair and understand the e18 error which is a lens error i Have answered the question before and have copy pasted after the link,
http://www.e18error.com/repair.html
START
If the camera is under guarantee take it back,
the lens error is that the lens isnt locking properly, to do this (and this is going to sound nuts) you must take the battery out wait 2-3 minutes then whack the camera (side) on a hard surface like a solid wood desk( not too hard), this will help unblock the lens to close/open correctly),
this is a fault with this particular model and its going to continue happening to you,
END
Posted on Aug 01, 2010
2 Suggested Answers
lock123
  • 6831 Answers
SOURCE: e18 error message tried new batteries but lens cov...
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 19, 2010
I am getting a message E18
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
In this link could check additional details: e18error.com
Hope helps (remember tp rate this answer).
Mar 29, 2011 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon powershot sd500 e18 error message
E18 is lens error , it means that the lens are stuck.
Oct 15, 2008 | Cameras
Error message E18
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 12, 2009 | Canon PowerShot S1 IS Digital Camera
E18 error on Canon ixus40 - lens stuck
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
How can i ix the cannon message e18?
The E18 error happens on Canon cameras usually when the lens is jammed when extending.
The error is so (in)famous that it has it own website where you can find help and advice on how to fix it. You can view the site by clicking the link underlined in blue below:
There is also a Wikipedia entry which you may find helpful:
http://en.wikipedia.org/wiki/E18_error
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Sep 20, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
E18
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
It's important that you fix the E18 error first, as the blur of colors may be symproms of a failing CCD. If so, Canon would fix this for you for free IF the camera has no other problems (ie no E18 lens error). Please see the following info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
May 27, 2008 | Canon PowerShot A70 Digital Camera
Canon powershot sd300 e18 error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 16, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Camera got wet and is now showing a e-18 message
e18 is a general error code for canon. if you got from best buy repost if you got the accidental plan from them
Apr 29, 2008 | Canon PowerShot A75 Digital Camera
E18 Message - Beeping.
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 13, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot A510 Digital Camera Logo
215 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
