Question about Xerox Phaser 6130 Laser Printer
Test page There are frequent power outages in my district. Every time the power goes out and then comes back on, the printer prints out a two page test page in colour. This is waste of paper and toner. Is there any way to arrest this tendency?
    President:
  • 2,571 Answers
Yes...Dont let the power get cut from your printer before you switch it off.
Use a UPS battery backup, this comes with software to shut your pc down if you are not at the pc when the power is cut.
Switch the printer off when not in use.
Posted on Aug 01, 2010
  • Roy
    Roy Aug 01, 2010
    Your problem was due to power outages...................
    If you have no way of preventing this, plugging the printer into a UPS will stop it from having the power cut to it, and you wont get the problem of wasted paper and ink.
    thanks for the unhelpfull rating
  • Keith Bumgarner May 06, 2013
    This is a useless suggestion. The inherent voltage spike associated with a restart of a printer that uses heat to transfer or affix image to the page will blow the fuse on the UPS most of the time on reboot.
HP laserjet 1518
HP printers frequently time how long a page takes to run through the machine. If it is too slow, they signal a jam error.
Try cleaning all the rollers and pinch wheels etc within the laser.
Dec 10, 2013 | HP LaserJet Office Equipment & Supplies
HP Color LaserJet CP1215 jamming on print a lot
Printers can be finicky. Ours at church works with no problems until we bought a different brand/weight of paper, then it jammed frequently. That is the first thing I would check. Then, the next thing is the rollers can get slightly worn. When you're talking less-than paper thickness tolerances, it doesn't take much to make a difference between working and jamming. Unfortunately getting these worked on is close to if not right at the cost of a new one.
Dec 02, 2017 | HP LaserJet CP1215 Color Printer
I just inserted new ink jets into my Canon MP 490. When I request a print test page, it goes through the motions but the page is blank.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 08, 2013 | Office Equipment & Supplies
I work for a school district, Macintosh environment. A networked laserjet 1320n printer prints out test pages at random. How can I stop this?
Hi. This is tricky to diagnose so just a few general thoughts.
1. The obvious thing is that the printer could have developed a fault and its own processor is causing it to happen.
2. Someone sending a print job is also sending a command (unknown to them) to tell the printer to print the test pages.
3. This is what I think is probably happening. Some printers are set to print out a test page when they are powered up, the two HPs that we have and the Apple laser we had before all did that. What could be happening is that there is a problem with the mains socket or lead - perhaps it's loose? and the power is going off periodically - even for just a moment or two. When the power comes back on - the printer prints out the test.
Let me know if I'm close.
May 05, 2011 | Office Equipment & Supplies
HP 5Si printer, multiple images on one sheet HP 5Si, Windows XP, Networked Jetdirect card, 20MB memory, duplex option. Unit worked fine before. Power outage occurred, seemed to have knocked out the...
If this is a "ghost" image like whats on the top of the page is re-appearing on the middle and/or bottom. The fuser is defective and needs to be replaced. Part # RG5-4447
Jan 03, 2011 | HP LaserJet 5si Printer
My computer says that my printer is offline.
Please follow the steps given below to perform a self test on the printer:
1. Switch off the printer.
2. Press and hold down the paper feed button.
3. While keeping the paper feed button depressed, turn the power back on.
4. When the printer starts to print, release the paper feed button.
5. When the first page is printed, switch off the power (otherwise the printer will keep on printing).
Apr 04, 2009 | Lexmark X73 All-In-One InkJet Printer
Alignment/selftest sheets print whenever I turn on the printer.
its up to you if you want to make self test..but you can cancelled it if you dont want to make self test..
Mar 07, 2009 | HP DeskJet 920c InkJet Printer
Power went out and back on; now printer won't print
I had the same problem after a resent power outage. Here's what fixed mine.
Turn the power switch off.
Wait a 15-20 seconds
While holding the button on the front panel down turn the power switch on.
After the drum light comes on release the button wait then press the button again.
Turn the machine off then back on again and you should be back in business.
To prevent the problem in the future if you are not using the printer turn it off and if the power goes off while printing get the printer turned off before the power comes back.
Oct 14, 2008 | Brother HL 1440 Laser Printer
Print size
Try going to Start>Control Panel>Make sure your in classic view>Printers And Faxes>Right click on your printer>choose properties>click "Print Test Page"
Is the text small on the page that comes out?
Jan 17, 2008 | Epson Stylus C84 InkJet Printer
Flashing red light on display
1st step - print a self test report Press and hold the OK button. Then press the left arrow key one time. Release the OK button. The test page prints OR Press the OK and Help keys simultaneously. The test page prints print the test pages 4 time minimum 2nd step - reset the printer If the printer is not off, press the Power button to turn it off. Unplug the power cord from the wall outlet. Unplug the power cord from the back of the printer. Unplug the universal serial bus (USB) cable from the back of the printer, if connected. Wait 30 seconds, then plug the power cord back into the printer. Plug the power cord back into the wall outlet. Press the Power button to turn the printer on. Ensure that the memory card has been removed from the memory card slot. Make sure plain paper is loaded in the In Tray. Hold down the OK button and press the Right arrow button four times. If the test page prints, re-connect the USB cable to the printer. OR IF YOU ARE NOT ABLE TO DO SO THEN start - printers & faxes - click on the printer icon highlighted with a correct symbol ( ensure the proper printer is highlighted )- right click on the icon - properties - print test page option at the bottom of the properties screen. 3rd step - if the USB is connected to a USB Hub then disconnect it from the HUB and connect it directly to the wall socket.Make sure the USB cord is of the proper measurement as mentioned for the printer in the User Manual. 4th step - visit www.hp.com left side of the screen you shall see an option SOFTWARE & DRIVERS DOWNLOAD click on that in the next screen a tab comes up mentioning FOR PRODUCT enter PHOTOSMART D 5160 and hit enter / click on the arrow beside it choose the OS under DRIVER YOU HAVE OPTIONS LIKE - » HP Basic Driver (recommended) » HP Full Software and Driver (before downloading it uninstall the s/w & then download it )-DO THIS ONLY IF THE 1ST OPTION DOES NOT MAKE THE PRINTER FUNCTION FINE STILL ERROR PERSISTS : - replace if under warranty/service the printer in the service centre
Sep 19, 2007 | HP Photosmart D5160 InkJet Printer
Xerox Phaser 6130 Laser Printer Logo
94 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
