Question about Cub Cadet Garden
Need help with cub cadet lt 1045 engine running erratic after a minute on full throttle Engine starts fine and idles fine. once you put it in full throttle after about a minute or five minutes it starts to run very erratic and wants to stall. I have replaced the spark plug--fuel filter--drained and refilled the gas tank--blew out all lines and cleaned the carburetor and swapped out the fuel pump and same results.
  • 26 Answers
Anthony, this could be from the governer linkage which is intended for maintaining a specified top rotation per minute speed ( R.P.M ) is a possability im not sure of your specific adjustment procedure allthough most are a simple lossening of the linkage mounting to the shaft bolt while this bolt is loose you push the linkage to full throttle travel activation allowing the control linkage that was lossened to turn in its mount ( pivot) and keeping the threw the block mounting at full activation range ( travel ) in its farthest position re tighten the arms securing bolt,to secure it at its proper activation range ( at the pivoting point) I hope this helps if your unfamiliar with this type of governer control linkage, i would seek to locate a diagram on line that you can view to assist in your specific engine's linkage adjustment , and another possability is your carbuerator's High speed needle valve is to lean or to rich hope you analysis the problem Steve
Posted on Aug 01, 2010
I have a 2006 Cub cadet LT 1045. My model only has one idle pulley. I am having a hard time keeping belts on. Does anyone know a fix for this
have you got the belt on the right side of the idler pulley
the back of the belt should be running on the pulley
Sep 25, 2015 | Cub Cadet Garden
Why does my Vintage Cub Cadet 125, Kohler 12HP engine pop/backfire and die when given any throttle?
Carburetor needs adjusted. May need rebuilt or just cleaned. Could be one of the jets is plugged.
Jul 19, 2014 | Cub Cadet Garden
I need part no. for manufacture date 2005 cub cadet lt 1045 modle ps-sv600 0009 pto clutch
I have a 2005 Cub Cadet LT1042, Spec. No. PS-SV590-0003, but my parts manual also lists part numbers for the LT1045. The clutch part no. given for your model is 717-04174.
Hope this is helpful.
Paul
May 10, 2013 | Oregon Scientific Electric PTO Clutch for...
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Aug 07, 2012 | Cub Cadet Garden
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Engine will not start
you have atleast 2 safety switches on there. one under the seat and one one the brake. if either one would fail, the engine will not turn over! i had to replace mine last yr
Jun 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet dead as a door nail
I have the same mower. The wires do need to be connected. It is a safety feature on the cubs. The engine will not start if the electric PTO is engaged. I just went into the garage, pulled the pto lever out to engage, pushed down brake, tried to start and it would not start. I suggest reattatching the wires and trying it. Hope this helps.
Apr 24, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
708 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
