Question about Craftsman Garden
My Craftsman GT 6000 (20 Hp) lawn tractor has lost its front wheel. The cotter pin is worn and loose; it has fallen out of the slot and will not securely sit in place. The cotter pin is ring like, it measures 5/8" inside to fit the shaft slot and the shaft measures 3/4". You would think this would be a common part! This lawn tractor is about 20 years old, and the best little machine you'd ever want.
    Sergeant:
  • 216 Answers
The item you are referring to is called a snap ring. You can purchase a small collection of snap rings from you local hardware store or automotive dealer. These snap rings can be viewed at the bottom of this filehttp://www.rotorclip.com/cat_pdfs/de.pdf or ordered from http://www.rotorclip.com/.
These links should get you the information you need to go to the local hardware store and get your parts.
Posted on Aug 04, 2010
How do I take a front tire off a craftsman lawn tractor
some have a plastic hub cap that you pry off then either a cotter pin or a c clip that needs to be removed .
Aug 26, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Adjusting tow in on craftsman pro riding lawn mower
You can try streightening the steering link rod. or just buy a new one. also make sure the holes on the axle brackets arent wallard out.
Jun 30, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna YTH 2448 Hydrostatic stuck in neutral
There is a brake assy. located on your transaxle right rear side. There is a nut with a cotter pin. First check to make sure there is no debris clogging the assy. Clean it first. you can use a garden hose. If that does not work remove cotter pin and turn nut clockwise until slotted nut lines up with hole. replace cotter pin. Start mower and see if it will engage. these transaxles are notorious for not having the pads snug enough to catch. Good luck. Hope you don't need a new transaxle.
Apr 29, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hit fence and right front tire is towing out. how do you get the alignment right?
kevin plumag, you may have bent the tie rod. It's an easy fix: each end of the tie rod connects to the axle, keeping the wheels at the right distance. Each end of the tie rod has a small cotter pin. Remove the cotter pin (a washer will fall off), lift out the bent tie rod, and put a new one back in, reinstalling the washer and cotter pin on each end.If your tie rod is straight, something else is wrong (which is why I'm searching the boards!). You can order a tie rod from Sears; check your manual for the part number.
Aug 30, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
How do i take the deck out from the mower
Catfish howdy,
If it's a craftsman there should be cotter pins to detach the deck on the arms of the deck and then just slip the belt off the main drive pully near the front of the tractor.
Aug 24, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Adjusting front wheels
Grease the zerks with a general grease, tighten any loose points, check your wheel bushings. They might be worn, causing the wheels to camber or off-toe.
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Problem for Craftsman 20 hp 42 in. Deck Lawn Tractor - ca model wheel alignment: both wheels point outwards
the bar connecting the wheels is bent. this is easy to change. just pull the pins out on both sides and lift the rod out. you can straighten it in a vise or order a new one through sears. cost about $12. our local repair shop keeps them on hand.
May 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Aug 22, 2009 | Garden
Garden Logo
215 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
